Topic: Pass variable in IFTTT Webhook (Read 445 times) previous topic - next topic
jld13
Hello,
I'm looking for a way to  push sensor data to a Google spreadsheet.  Using IFTTT, I can get the webhook to trigger and create/update a spreadsheet, but I can't figure out how to pass a variable into the webhook URL.
I can successfully trigger the webhook and create/update a spreadsheet using:
https://maker.ifttt.com/trigger/<event>/with/key/<key>?value1=<something>&value2=<something2>
I need the something to be my sensor variable temp that is updating to the IoT Cloud.  Do I need to do something in the code or is it just a simple syntax in the URL?
ubidefeo
hello @jld13
We have published this tutorial not long ago.
Please have a look and let us know if it helps :)
https://create.arduino.cc/projecthub/Arduino_Genuino/arduino-iot-cloud-google-sheets-integration-71b6bc?ref=user&ref_id=65561&offset=0
jld13
I did get the setup in the tutorial working and that is a solution I can work with, thanks.  I am still wondering if there is a way to pass a variable in the IFTTT webhook address though.
