Topic: problem in communication serial (Read 421 times) previous topic - next topic
jpaulo69
Apr 06, 2019, 03:13 am Last Edit: Apr 06, 2019, 07:19 pm by jpaulo69
How to perform a serial configuration in Python ,Azure ,windows10, i have used this code without success in my Arduino  no have comunication
Code: [Select]
import serial
import time
ser = serial.Serial('COM5', 9600)
i=0
while i<180:
ser.write(str(chr(116)))
#t = raw_input("teste")
#print type(teste)
#ser.println((str(chr(1160))))
#time.sleep(1000)
print (ser.readline())
I receive this error      {Module 'serial' has no 'Serial' member; maybe 'serial'?}
groundFungus
This is an Arduino forum.  We gladly offer help for the Arduino compatible boards and the Arduino IDE.  While someone with Python ,Azure or windows10 experience may be able to help, it may be a while before they come along.  Better to find a forum that deals with the language that you want to use.
Idahowalker
Code: [Select]
import serial
import time
i=0
while i<180:
#print type(teste)
#time.sleep(1000)
You are loading Python into your Arduino? You are looking for Arduino serial code to receive code from a external serial device? You are looking for Python code that will talk to an Arduino?
jpaulo69
The error continues even if the door is changed.
Idahowalker
The fly ate the yellow bird, 7, 9, 9 4.
jpaulo69
I'm calling a Python code from Arduino (which controls a motor) through the python scipt on the pc
