Topic: Problem with connector between Arduino and MS SQL Server (Read 965 times) previous topic - next topic
fernando1828
Apr 08, 2019, 06:59 pm Last Edit: Apr 08, 2019, 07:02 pm by fernando1828
Hi everybody. After having surfed the network for a long time I found a direct connector between MS SQL server and arduino. The project I try to do is based on sending sensor values and recording them in the database. The idea is to not use any connector between arduino and SQL.
The problem is that the program does not compile (I mean the connector library example). I attach the libraries. Is there any other direct connector between SQL and Arduino?
Thanks!!
Link: https://github.com/mustafakemalgilor/arduino-mssql
PaulS
I'm not opening zip files. Post your sketch directly. Post links to the libraries. Post your error messages.
Thee_Captain
I find it fairly straight forward to make an HTTP endpoint and handle the SQL on the server. It also creates an opportunity for a good API.
Throw a little karma my way. What goes around comes around.
fernando1828
Links:
Arduino to sql:  https://github.com/mustafakemalgilor/arduino-mssql
UIPethernet: https://github.com/UIPEthernet/UIPEthernet
//Included by myself!!!
#include <Dhcp.h>
#include <Dns.h>
#include <ethernet_comp.h>
#include <UIPClient.h>
#include <UIPEthernet.h>
#include <UIPServer.h>
#include <UIPUdp.h>
#include <Ethernet.h>
#include "sqlard.h"
uint8_t Ethernet_MacAddr[6] = { 0x74, 0x69, 0x69, 0x2D, 0x30, 0x31 }; /* MAC ADRESİ */
static byte Static_IPAddr[] = { 172, 16, 1, 2 };
static byte Gateway_IPAddr[] = { 172, 16, 1, 1 };
static byte Subnet_Mask[] = { 255, 255, 0, 0 };
EthernetClient client;
SQLard MSSQL(Gateway_IPAddr, 1433, &client);
  while (!Serial);
  Ethernet.begin(Ethernet_MacAddr, Static_IPAddr, Gateway_IPAddr, Gateway_IPAddr, Subnet_Mask);
  if (MSSQL.connect())
    MSSQL.setCredentials(L"arduino", L"ard_login", L"ard_password", L"hostx");
    MSSQL.login();
  int loop_count = 0;
  delay(5000);
  long affected_rows = MSSQL.executeNonQuery(L"INSERT INTO [dbo].[test]([data]) VALUES('deger1234') ");
  long yeni = MSSQL.executeNonQuery(L"DROP TABLE [dbo].[test23]");
  Serial.print(affected_rows);
  Serial.println(" row(s) affected.");
  if (!client) {
    Serial.println("disconnecting.");
    client.stop();
  if (++loop_count == 10)
    MSSQL.executeNonQuery(L"DELETE FROM [dbo].[test]");
    loop_count = 0;
Errors (some of them):
In file included from sqlard_test.ino:5:0:
C:\Users\Fer\Documents\Arduino\libraries\arduino_uip-master/UIPClient.h:25:2: warning: #import is a deprecated GCC extension [-Wdeprecated]
 #import "Client.h"
C:\Users\Fer\Documents\Arduino\libraries\arduino_uip-master/UIPClient.h:26:2: warning: #import is a deprecated GCC extension [-Wdeprecated]
 #import "utility/mempool.h"
C:\Users\Fer\Documents\Arduino\libraries\arduino_uip-master/UIPClient.h:29:4: warning: #import is a deprecated GCC extension [-Wdeprecated]
   #import "utility/uip.h"
In file included from C:\Users\Fer\Documents\Arduino\libraries\arduino_uip-master/UIPEthernet.h:34:0,
                 from sqlard_test.ino:6:
C:\Users\Fer\Documents\Arduino\libraries\arduino_uip-master/UIPServer.h:23:2: warning: #import is a deprecated GCC extension [-Wdeprecated]
 #import "Server.h"
C:\Users\Fer\Documents\Arduino\libraries\arduino_uip-master/UIPServer.h:24:2: warning: #import is a deprecated GCC extension [-Wdeprecated]
 #import "UIPClient.h"
In file included from C:\Users\Fer\Documents\Arduino\libraries\arduino_uip-master/UIPUdp.h:23:0,
                 from C:\Users\Fer\Documents\Arduino\libraries\arduino_uip-master/Dhcp.h:7,
                 from sqlard_test.ino:2:
C:\Users\Fer\Documents\Arduino\libraries\arduino_uip-master/ethernet_comp.h:5:24: error: redefinition of 'class UIPClient'
 #define EthernetClient UIPClient
C:\Program Files (x86)\Arduino\libraries\Ethernet\src/EthernetClient.h:8:7: note: in expansion of macro 'EthernetClient'
 class EthernetClient : public Client {
C:\Users\Fer\Documents\Arduino\libraries\arduino_uip-master/UIPClient.h:63:7: error: previous definition of 'class UIPClient'
 class UIPClient : public Client {
C:\Users\Fer\Documents\Arduino\libraries\arduino_uip-master/ethernet_comp.h:6:24: error: redefinition of 'class UIPServer'
 #define EthernetServer UIPServer
C:\Program Files (x86)\Arduino\libraries\Ethernet\src/EthernetServer.h:8:7: note: in expansion of macro 'EthernetServer'
 class EthernetServer :
C:\Users\Fer\Documents\Arduino\libraries\arduino_uip-master/UIPServer.h:26:7: error: previous definition of 'class UIPServer'
 class UIPServer : public Server {
C:\Users\Fer\Documents\Arduino\libraries\arduino_uip-master/ethernet_comp.h:4:18: error: conflicting declaration 'EthernetClass UIPEthernet'
 #define Ethernet UIPEthernet
Error de compilación
PaulS
#include <Dhcp.h>
#include <Dns.h>
#include <UIPUdp.h>
Why? Why did you stuck a bunch of useless #include statements in your code?
fernando1828
Oh, some of them are useless, but I only need one or two. Otherwise, I get another error.
ieee488
How about put your money where your mouth is and show some code?
PaulS
Which one(s)? What error?
The compiler is VERY specific. You need to learn to be, too.
fernando1828
PaulS
The compiler asked me for the UIPethernet library.
Show us the code without all the unnecessary #include statements, and exactly how the compiler asked you for the UIPethernet library.
The compiler is I is a crusty old f*ck, and doesn't ask for anything. It simply demands perfection.
fernando1828
#10
Apr 09, 2019, 07:16 pm Last Edit: Apr 09, 2019, 07:18 pm by fernando1828
#include "sqlard.h"
uint8_t Ethernet_MacAddr[6] = { 0x74,0x69,0x69,0x2D,0x30,0x31 }; /* MAC ADRESİ */
static byte Static_IPAddr[] = { 172,16,1,2 };
static byte Gateway_IPAddr[] = { 172,16,1,1 };
static byte Subnet_Mask[] = { 255,255,0,0 };
  while (!Serial);
  if(MSSQL.connect())
      MSSQL.setCredentials(L"arduino", L"ard_login",L"ard_password",L"hostx");
      MSSQL.login();
  int loop_count = 0;
  delay(5000);
  if (!client) {
    client.stop();
  if(++loop_count == 10)
    loop_count = 0;
Sure, I'm not perfect, thats why I am here!!!. I am using Arduino 1.6.5.
Error:
Opciones de compilación cambiadas, reconstruyendo todo
In file included from sqlard_test.ino:2:0:
C:\Users\Fer\Documents\Arduino\libraries\arduino-mssql-master/sqlard.h:13:27: fatal error: UIPEthernet.h: No such file or directory
compilation terminated.
PaulS
If you think that that means that you need to add the same single statement to your sketch, what happens when you do that?
What it looks to me like is that you haven't downloaded and/or properly installed the UIPEthernet library.
fernando1828
I got many errors, I've posted them before. (see my post # 2)
I think the same, but I don't realice what Im doing wrong.
Thee_Captain
#13
Apr 10, 2019, 02:10 am Last Edit: Apr 10, 2019, 02:54 am by Thee_Captain
Challenge accepted.
This is based off the ESP32 BasicHttpClient.ino example sketch. I thinned out some of it and moved the get request to its own function. That way it can be called by specialty "sensor" (anything really) functions.
You could do a similar sketch with Arduino's Ethernet WebClient example.
 * BasicHTTPClient.ino
 *  Created on: 24.05.2015
#include <Arduino.h>
#include <WiFi.h>
#include <WiFiMulti.h>
#include <HTTPClient.h>
#define USE_SERIAL Serial
WiFiMulti wifiMulti;
const char* ssid = "your_SSID";
const char* pass = "your_password";
char getURI[128] = "http://example.com/index.html";
//char getURI[128] = "http://example.com/flabberwab.html"; //404 Not Found - Test Response
//char getURI[128] = "http://example.com/device/5/sensor/251";
#define SENSOR_PIN 26
    USE_SERIAL.begin(115200);
    delay(3000);
    wifiMulti.addAP(ssid, pass);
    pinMode(SENSOR_PIN, INPUT);
    getRequest(getURI);
    delay(2000);
//  getRequest(getURI);
//  delay(5000);
  saveSensorValue();
  delay(5000);
void saveSensorValue(){
  char myDeviceEndPoint[128] = "http://example.com/device/5"; //your device endpoint
  int sensorVal = -1;
  char buf[12] = "";
  sensorVal = digitalRead(SENSOR_PIN);
  strcat(myDeviceEndPoint, "/sensor/"); //your sensor endpoint concatenated to your device endpoint
  strcat(myDeviceEndPoint, itoa(sensorVal, buf, 10) );
  getRequest(myDeviceEndPoint);
void getRequest(char* requestURI){
    // wait for WiFi connection
    if((wifiMulti.run() == WL_CONNECTED)) {
        HTTPClient http;
        USE_SERIAL.println("");
        http.begin(requestURI);
        USE_SERIAL.print("[HTTP] GET...\n");
        USE_SERIAL.println(requestURI);
        // start connection and send HTTP header
        int httpCode = http.GET();
        // httpCode will be negative on error
        if(httpCode > 0) {
            // HTTP header has been send and Server response header has been handled
            USE_SERIAL.printf("[HTTP] Response code: %d\n", httpCode);
            //request made it to the server
            //and has sent back a response
            if(httpCode == HTTP_CODE_OK) {
                String payload = http.getString();
                USE_SERIAL.println(payload);
          //Request did not reach the server
          USE_SERIAL.printf("[HTTP] Request failed, error: %s\n", http.errorToString(httpCode).c_str());
        http.end();
fernando1828
Hey thank you very much for the answers, but let's not lose the goal:I want to connect the arduino with SQL directly with the program I've posted before.
Thanks!
