Topic: error on chinese clone (wavgat) (Read 198 times) previous topic - next topic
camilozk
Hi!
I get the following error when trying to program a chinese board:
Warning: platform.txt from core 'Arduino AVR Boards' contains deprecated recipe.ar.pattern="{compiler.path}{compiler.ar.cmd}" {compiler.ar.flags} {compiler.ar.extra_flags} "{build.path}/{archive_file}" "{object_file}", automatically converted to recipe.ar.pattern="{compiler.path}{compiler.ar.cmd}" {compiler.ar.flags} {compiler.ar.extra_flags} "{archive_file_path}" "{object_file}". Consider upgrading this core.
In file included from C:\Users\leo\Documents\Arduino\libraries\Conceptinetics\Conceptinetics.cpp:28:0:
C:\Program Files (x86)\Arduino\hardware\WAV\avr\variants\lgt8fx8p/pins_arduino.h:34:14: error: 'uint8_t' does not name a type
 static const uint8_t DAC0 = 4;
exit status 1
Error compiling for board WAVGAT UNO R3.
The board is a wavgat arduino uno
The code follows:
Code: [Select]
#include <Conceptinetics.h>
#define DMX_MASTER_CHANNELS   1
#define RXEN_PIN              2
DMX_Master  dmx_master  (DMX_MASTER_CHANNELS, RXEN_PIN);
int fogValue = 0;
  dmx_master.enable ();
  dmx_master.setChannelRange (1,25,127);
  int pote = analogRead(A0);
  fogValue = map(pote, 0, 1023, 0, 255);
  dmx_master.setChannelValue (1, fogValue);
I dont really understand what does this mean. any help?
thanks!
DrAzzy
The WAVGAT "clones" use a different processor (an almost-clone of the '328p by some chinese semiconductor company) and need a special core from wavgat, and even with it there are problems.
Avoid that brand like the plague.
ATTinyCore for x4/x5/x61/x7/x8/x41/1634/828/x313 megaTinyCore for the megaavr ATtinies - Board Manager:
http://drazzy.com/package_drazzy.com_index.json
ATtiny breakouts, mosfets, awesome prototyping board in my store http://tindie.com/stores/DrAzzy
camilozk
Thank you for the information. I will in the future. For now, I would really appreciate a solution!
camilozk
Problem was sorted out by replacing uint8_t with char
