Topic: Stepping down 12V Power Supply to 9V at high amperage (20+ Amps) (Read 76 times) previous topic - next topic
jeggv
Hello, in my project I am using a power supply rated at 12V, 0-60A. I will only be drawing around 20A.
My components work at 9V. Is there an easy/cheap way to do this?
I've been looking at voltage regulators but I can't seem to find one that works with that many amps.
herbschwarz
Hello Jeggv,
Am I understanding you correctly? You have
a power supply that can deliver 12V @ 60A
but you want 9V @ about 20A for your
project. Can you show us a schematic
diagram of the power supply you have?
My thought is that its internal reference
or feedback loop can be revised to change
the output voltage to 9 volts. Then that
would be the easiest/cheapest way to do
that.
Herb
jeggv
Hello Jeggv,
that.
Herb
This is the power supply I am using:
https://www.amazon.com/dp/B01LZ4QXLH/ref=sspa_dk_detail_2?psc=1&pd_rd_i=B01LZ4QXLH
It only has 5% adjustable voltage.
And yep you're understanding correctly.
Thank you Herb
