Topic: ArduinoOTA on MKR1010 WIFI (Read 1 time) previous topic - next topic
mladek89
Dear all,
I am trying to get the arduinoOTA running on a MKR1010 Wifi.
The script and the library is compiling without any problems (with WIFININA), but I can't see the COM port via WIFI?
Has anyone get this running on a MKR1010?
Thanks so much!
Juraj
#1
Apr 09, 2019, 03:28 pm Last Edit: Apr 09, 2019, 03:59 pm by Juraj
ArduinoOTA library?
the problem with port is in OS or IDE. try the beta version 1.9 of the IDE
Bjain
I have got this running on MKR1000 board.
Try using "WiFi101OTA" library.
Juraj
#3
Apr 30, 2019, 10:21 am Last Edit: Apr 30, 2019, 10:24 am by Juraj
WiFi101OTA is for MKR1000 or WiFi101 shield on Zero
ArduinoOTA library is my modification of WiFi101OTA for other boards and networking libraries
hebrwhammer587
Juraj. I have tried using your library and looked at the Github #7 & #8. They have not helped and I am still getting the same issue. No wireless com port is showing and I even switched to beta 1.9.0. Do you perhaps have any other idea what to do?
reinderb
#5
Dec 07, 2019, 02:19 am Last Edit: Dec 22, 2019, 02:16 am by reinderb
I have the same problem. Turns out that the anti-virus program somehow causes it. I'm using Avast (free) and only after completely removing Avast, the WiFi port shows up, reliably, and the OTA updating works flawlessly. Disabling Avast is not enough.  I've done this on two different computers, same result on both IDE 1.8.10 and 1.9.0.
Of course this is not a sustainable solution, but it seems another AV is needed.
ballscrewbob
#6
Dec 26, 2019, 03:45 pm Last Edit: Dec 26, 2019, 03:47 pm by ballscrewbob
@reinderb
Some security programs can identify programming environments as malicious.
This is known as a false positive.
Avast has an EXCLUSIONS list to which you can add known good sources / programs / folders, etc.
You should re-install your antivirus and add the Arduino locations to its list.
Slow compiles or driver errors under Windows
Add the Arduino directories to your antivirus / anti malware / other security exclusions.
So that would be at least two of the following.
C:\Program Files (x86)\Arduino
C:\Users\yourname\AppData\Local\Arduino15 (depends on IDE install type/location)
C:\Users\yourname\AppData\Roaming\Arduino15 (depends on IDE install type/location)
If you have your sketches set up in a different location it's also worth adding that directory to the exclusions also.
Additionally if you also use the online IDE "CREATE" the following directories.
C:\Users\yourname\AppData\Roaming\ArduinoCreateAgent
C:\Users\yourname\AppData\.arduino-create
If you have installed to a different drive swap the drive letter as needed.
If you also have an unzipped IDE installed that path should also be added to exclusions
Bob.
It may not be the answer you were looking for but its the one I am giving based on either experience, educated guess, google or the fact that you gave nothing to go with in the first place so I used my wonky crystal ball.
