Topic: Using LED Matrix in free Running Mode  (Read 303 times) previous topic - next topic
flitschi
I recently started a project where I do a FFT on a line input signal. I want to use the "free running mode" of the adc to get a high sampling rate of my signal.
I am using this led matrix to visualise the bins: https://www.adafruit.com/product/420
The Matrix uses some of the Analog Pins to adress the rows in the matrix.
My question is, is it possible to use this display when in "free running mode" or vice versa will the display interfere with this mode?
So far I had no luck getting solid results like this, only when I use analog read.
Grumpy_Mike
That display is going to take most of the processing power of your Arduino so I can't see you getting good results with your components.
