Topic: (Solved)BSSL: Connection *will* fail, no authentication method is setup.  (Read 440 times) previous topic - next topic
tasmod
Still trying to send a mail via Gmail and getting the title message via BearSSL.
Obviously at the moment I'm getting connection failed message.
A search brought only two hits.........
One was to roll back the library to an earlier version due to upgrades in certification. (How do I rollback a core library?)
Second was to add the line 'client.setInsecure();'  although very vague as to where to use the line and I thought somewhat self defeating.
Anyone any ideas for a solution?
tasmod
OK. After much googling it seems web sockets has yet to catch up on authentication.
An almost fix is to change
Code: [Select]
WiFiClientSecure client;
to
Code: [Select]
BearSSL::WiFiClientSecure client;
but it wdt times out at  "--- Sending EHLO" in around 6 seconds.
Seems from the google comments that I need to extend the connection loop as it becomes much much slower with the Bear command.
Anyone any experience at all sending Gmail with the NodeMCU ?
tasmod
Got it !  It wasn't clearly put but it meant roll back the board library.  I rolled back to the last version and it all works.
Happy chappy now :-)
Marty_1982
Hi! I have the same issue with telegrambot library and wemos. I want to know if rolling back the library or adding the lines Berssl...will solutionate the issue.
Thanks in advance!!
