Yes to the multiple boards. The dude happens with or without any hook ups. Is there a way to check if boards are damaged, cause the ones I used were not new. I have tried a number of Sketch's that comply and have uploaded before without issue . Now I get this dude error when I try them also. I also tried a different computer same issue. I took all Arduino files off computer and started over that did not work either. {uninstalled also}.I just made the lego bulldozer 3 x scaled up and have been trying for 3 weeks to solve this issue and get it running. I haven't run into any dude I couldn't get along with but I guess there is always the first one . got to keep pushing on, maybe I'll get lucky. This is My issue message
Arduino: 1.8.9 (Windows Store 1.8.21.0) (Windows 10), Board: "Arduino/Genuino Uno"
Sketch uses 3322 bytes (10%) of program storage space. Maximum is 32256 bytes.
Global variables use 76 bytes (3%) of dynamic memory, leaving 1972 bytes for local variables. Maximum is 2048 bytes.
C:\Program Files\WindowsApps\ArduinoLLC.ArduinoIDE_1.8.21.0_x86__mdqgnx93n4wtt\hardware\tools\avr/bin/avrdude -CC:\Program Files\WindowsApps\ArduinoLLC.ArduinoIDE_1.8.21.0_x86__mdqgnx93n4wtt\hardware\tools\avr/etc/avrdude.conf -v -patmega328p -carduino -PCOM5 -b115200 -D -Uflash:w:C:\Users\frank\AppData\Local\Temp\arduino_build_7910/sketch_apr16ajoystick.ino.hex:i
avrdude: Version 6.3-20171130
Copyright (c) 2000-2005 Brian Dean,
http://www.bdmicro.com/ Copyright (c) 2007-2014 Joerg Wunsch
System wide configuration file is "C:\Program Files\WindowsApps\ArduinoLLC.ArduinoIDE_1.8.21.0_x86__mdqgnx93n4wtt\hardware\tools\avr/etc/avrdude.conf"
Using Port : COM5
Using Programmer : arduino
Overriding Baud Rate : 115200
avrdude: stk500_getsync() attempt 1 of 10: not in sync: resp=0xa3
avrdude: stk500_getsync() attempt 2 of 10: not in sync: resp=0xa3
avrdude: stk500_getsync() attempt 3 of 10: not in sync: resp=0xa3
avrdude: stk500_getsync() attempt 4 of 10: not in sync: resp=0xa3
avrdude: stk500_getsync() attempt 5 of 10: not in sync: resp=0xa3
avrdude: stk500_getsync() attempt 6 of 10: not in sync: resp=0xa3
avrdude: stk500_getsync() attempt 7 of 10: not in sync: resp=0xa3
avrdude: stk500_getsync() attempt 8 of 10: not in sync: resp=0xa3
avrdude: stk500_getsync() attempt 9 of 10: not in sync: resp=0xa3
avrdude: stk500_getsync() attempt 10 of 10: not in sync: resp=0xa3
avrdude done. Thank you.
Problem uploading to board. See
http://www.arduino.cc/en/Guide/Troubleshooting#upload for suggestions.
option enabled in File -> Preferences.
