Topic: avrdude: stk500_recv(): programmer is not responding (Read 102610 times) previous topic - next topic
henrique_coder
Please do this:
  • (In the Arduino IDE) File > Preferences
  • Uncheck the checkbox next to "Show verbose output during: compilation"
  • Check the checkbox next to "Show verbose output during: upload
  • Click "OK"
  • Sketch > Upload
  • After the upload fails, you'll see a button on the right side of the orange bar "Copy error messages" (or the icon that looks like two pieces of paper at the top right corner of the black console window in the Arduino Web Editor). Click that button.
  • In a forum reply here, click on the reply field.
  • Click the </> button on the forum toolbar. This will add the forum's code tags markup to your reply.
  • Press "Ctrl + V". This will paste the upload output between the code tags.
  • Move the cursor outside of the code tags before you add any additional text to your reply.
I have the same problem, and this appears:
avrdude: Version 6.3, compiled on Jan 17 2017 at 12:00:53
         Copyright (c) 2007-2014 Joerg Wunsch
         System wide configuration file is "C:\Program Files (x86)\Arduino\hardware\tools\avr/etc/avrdude.conf"
         Using Port                    : COM1
         Using Programmer              : arduino
         Overriding Baud Rate          : 115200
avrdude: stk500_getsync() attempt 1 of 10: not in sync: resp=0x0d
avrdude: stk500_getsync() attempt 2 of 10: not in sync: resp=0x0d
avrdude: stk500_getsync() attempt 3 of 10: not in sync: resp=0x0d
avrdude: stk500_getsync() attempt 4 of 10: not in sync: resp=0x0d
avrdude: stk500_getsync() attempt 5 of 10: not in sync: resp=0x0d
avrdude: stk500_getsync() attempt 6 of 10: not in sync: resp=0x0d
avrdude: stk500_getsync() attempt 7 of 10: not in sync: resp=0x0d
avrdude: stk500_getsync() attempt 8 of 10: not in sync: resp=0x0d
avrdude: stk500_getsync() attempt 9 of 10: not in sync: resp=0x0d
avrdude: stk500_getsync() attempt 10 of 10: not in sync: resp=0x0d
avrdude done.  Thank you.
TechGraphix
I think this might work:
First check if you can perform a loop test:  connect 0 to 1 (RxD to TxD)  and reset to Gnd.. Type something in the Serial Monitor and press Send.. If you see the same appear in the output, your connection is fine.
Getting the board-info should also mean the connection is fine. (i think)
Then you might have a problem with the bootloader on the Atmega..  a blinking LED should mean that the bootloader is ok, but i found that if a processor was programmed over ISP it seems to be blocked to upload a program when it is placed in the arduino again, although the led is blinking...
Try to get a processor with only a bootloader and try it again..
Kees
not_in_use
I think the moderators should take note of this issue; it seems to be a larger overall problem as it is happening to a lot of people who are otherwise doing things properly on their end.
 I'm having the same issues/problems on several nano boards that were working perfectly before:
-did not find any USB device "usb" (0x03eb:0x2104)
-avrdude: stk500_recv(): programmer is not responding
-avrdude: stk500_getsync() attempt 10 of 10: not in sync: resp=0x06
-and various other error codes, similar to other people
I have tried/verified:
Windows 10 pro machines (three different machines.)
USB 2.0 and 3.0.
Arduino 1.8.9.
Arduino 1.8.13.
No bluetooth interferences.
No COM port conflicts or problems.
I am using the correct port.
I have tried 5 different known good cables.
I can verify it is not static - I always use wrist straps, anti-static mat, and ground monitoring system.
I have tried 5 brand new nano boards with nothing connected.
I can see the boards when I check board info.
I am a fart smeller... I mean smart feller... it is nothing I have done. Maybe it is a Windows update, or something needs to be changed in the ide program to work around this.
I will be happy to help in any way I can.  Just let me know how. I want this fixed so I can use my boards.
pert
How do you know that they are doing things properly? I've been working with Arduino for 8.5 years and, for the most part, the times I've had this sort of error was when I had the wrong board selected or had destroyed my board by subjecting it to conditions outside its rated specifications. Are you sure that all those posts you find weren't caused by people doing the same?
It's easy enough to do, and probably every Arduino user is going to do it if they stick with it for more than a few days. With millions of people using Arduino, it's only to be expected that you'll see a lot of reports. People might think that, as long as they pretend that funny smoke never came out of their board, the board might magically heal itself.
0x03eb:0x2104 is the VID/PID of the AVRISP mkII ISP programmer. You will get this error if you try to do a Tools > Burn Bootloader or a Sketch > Upload Using Programmer (or hold Shift while doing an "Upload") with Tools > Programmer > AVRISP mkII selected, but a AVRISP mkII is not detected by your computer. Do you own a AVRISP mkII ISP programmer?
Please do this:
  • Click "OK"
  • Sketch > Upload
ballscrewbob
Not sure what you want moderators to actually do as for the very most part we are simply users like yourself that are simply tasked with order in the forum.
You seem to have tried almost everything I would have suggested so that may leave the issue with some problem in your setup and or your additional security.
There are plenty of posts regarding the NANO series boards both the newer ones (that have thier own sections) and the older series.
All those topics are fully searchable (upper right of your screen).
Bob.
It may not be the answer you were looking for but its the one I am giving based on either experience, educated guess, google (who would have thunk it ! ) or the fact that you gave nothing to go with in the first place so I used my wonky crystal ball.
Fredsmith
Hi, my Arduino Uno was working on my old computer Mac Pro 2009 Mac Os 10.10. I got a slightly newer similar computer Mac Pro 2010 and upgraded to Mac Mojave 10.14.6. The Arduino quit working and gives me the avrdude error.
I've tried a new USB cable and a new Arduino, which rules out a hardware issue.
I can select the USB modem in Tools, if I use an older version of Arduino IDE (otherwise the modem doesn't show up in the newer versions).
However, I'm still getting a connection error. I've tried many of the things on this thread and more such as googling for Mac specific or Mojave specific things, but haven't had any luck. I don't have the wherewithal to go through the entire thread. I've already spent hours and days on this. There is nothing connected to the Arduino.
Help????
Code: [Select]
Arduino: 1.8.8 (Mac OS X), Board: "Arduino/Genuino Uno"
Sketch uses 2160 bytes (6%) of program storage space. Maximum is 32256 bytes.
Global variables use 52 bytes (2%) of dynamic memory, leaving 1996 bytes for local variables. Maximum is 2048 bytes.
/private/var/folders/l9/531kxknd7jx3gc5_g__cjl3c0000gn/T/AppTranslocation/3D37422B-B252-487B-BE59-B02CD1BEF05E/d/Arduino.app/Contents/Java/hardware/tools/avr/bin/avrdude -C/private/var/folders/l9/531kxknd7jx3gc5_g__cjl3c0000gn/T/AppTranslocation/3D37422B-B252-487B-BE59-B02CD1BEF05E/d/Arduino.app/Contents/Java/hardware/tools/avr/etc/avrdude.conf -v -patmega328p -carduino -P/dev/cu.usbmodem5D101 -b115200 -D -Uflash:w:/var/folders/l9/531kxknd7jx3gc5_g__cjl3c0000gn/T/arduino_build_816135/Servo_Sweep_Test.ino.hex:i
avrdude: Version 6.3-20171130
         System wide configuration file is "/private/var/folders/l9/531kxknd7jx3gc5_g__cjl3c0000gn/T/AppTranslocation/3D37422B-B252-487B-BE59-B02CD1BEF05E/d/Arduino.app/Contents/Java/hardware/tools/avr/etc/avrdude.conf"
         User configuration file is "/Users/name/.avrduderc"
         User configuration file does not exist or is not a regular file, skipping
         Using Port                    : /dev/cu.usbmodem5D101
avrdude: stk500_getsync() attempt 1 of 10: not in sync: resp=0x00
avrdude: stk500_getsync() attempt 2 of 10: not in sync: resp=0x00
avrdude: stk500_getsync() attempt 3 of 10: not in sync: resp=0x00
avrdude: stk500_getsync() attempt 4 of 10: not in sync: resp=0x00
avrdude: stk500_getsync() attempt 5 of 10: not in sync: resp=0x00
avrdude: stk500_getsync() attempt 6 of 10: not in sync: resp=0x00
avrdude: stk500_getsync() attempt 7 of 10: not in sync: resp=0x00
avrdude: stk500_getsync() attempt 8 of 10: not in sync: resp=0x00
avrdude: stk500_getsync() attempt 9 of 10: not in sync: resp=0x00
avrdude: stk500_getsync() attempt 10 of 10: not in sync: resp=0x00
Problem uploading to board.  See http://www.arduino.cc/en/Guide/Troubleshooting#upload for suggestions.
option enabled in File -> Preferences.
Fredsmith
I was able to do an upload the Blink sketch with my original Arduino board and USB cable with an old Mac laptop running Mac Os 10.5 and Arduino IDE 1.0.5.
Is this a clue of something that helps the problem I posted above?
nickwagner
Solved mine!!!  Tried every suggestion but none worked, and finally only re-burn bootloader fixed the problem.
New to Arduino, bought one uno kit from banggood, really annoyed for not able to upload any sketches.  Ended up buying another elegoo uno from amazon, which worked without problem.  Then followed the steps here,
   https://support.arduino.cc/hc/en-us/articles/360012048080-How-to-burn-the-bootloader-between-two-Arduino-UNO
One note, before the burning, select your programmer as "Arduino as ISP", and that fixed it once for all!
Hope this helps!
Fredsmith
Ha, I've totally given up. Instead, I have purchased a cheap older laptop with an older OS. It arrives in a few days. Hopefully, that will work.
bhaveshpandy92
for me this same issue came and when I removed Arduino uno 5v and GND pins connection with GLCD, code uploading worked for me. Thanks all for other valuable comments :)
avandel
#175
Feb 21, 2021, 06:26 pm Last Edit: Feb 21, 2021, 06:28 pm by avandel
Im relatively new to Arduino, Rpi and more, and I'm not into making things on daily basis, but this problem occurred today on my pc and my laptop, and the worrying part is, I did not do anything out of the ordinary.
Now before everybody wants to know the size of my big left toe, I'd state this simple: Arduino IDE f*cks up ports.
This is my opinion and it brought me to realize that this is the end for me, because if it does not work out of the box, it is a childstoy that is not even finished.
A pity really, because I am not in the mood to search for updates, even if Arduino provides them and my pc's don't accept the drivers, and then keep trying, pulling out the last hairs I have and .......
Nope, sorry, for those who want to help, make this kind of problems go AWAY!!!!!!!
Maybe then I will try it again.
Good luck people..
avandel
#176
Feb 21, 2021, 07:02 pm Last Edit: Feb 21, 2021, 07:05 pm by avandel
Bob.
In the name of a product, software or anything that is used by a lot of people, they decide to let someone or do it themselves, create a forum.
Now, in this example, we are having the assumption that this forum is some sort of shortcut to the makers of the software to make them aware that there is a problem. We are having this problem from 2019, so it is nothing new, and not that forummembers did not give them pointers to the problem, it is only to the makers to make a clear statement so that this topic does not have to keep growing with unsatisfied people, the makers could make this happen.
As long as this endless topic is open for members to spit their problem (do not spit now, according to covid-19 rules, that's forbidden) the members assume they either know of the problem, working on it, or don't give a damn about it.
If they are working on it, please, let us know.....
So, tell us your progress, ask us what info you need, lets try to solve this for once and forever...
ballscrewbob
#177
Feb 21, 2021, 07:26 pm Last Edit: Feb 21, 2021, 07:31 pm by ballscrewbob
@avandel
Rather than just "ranting" aimlessly wasting your time and others you might want to fully outline YOUR PARTICUAR ISSUE ?
If you could point me to the perfect bit of Microsoft software that does not need updates or drivers or other software to do what everybody wants we may be able to get your point but as it stands it is a random jumble of thoughts and has zero details.
Could you also take a few moments to Learn How To Use The Forum.
Other general help and troubleshooting advice can be found here.
vucko26
Arduino: 1.8.13 (Windows 10), Board: "Arduino Uno"
Sketch uses 20988 bytes (65%) of program storage space. Maximum is 32256 bytes.
Global variables use 527 bytes (25%) of dynamic memory, leaving 1521 bytes for local variables. Maximum is 2048 bytes.
C:\Program Files\Arduino\hardware\tools\avr/bin/avrdude -CC:\Program Files\Arduino\hardware\tools\avr/etc/avrdude.conf -v -patmega328p -carduino -PCOM7 -b115200 -D -Uflash:w:C:\Users\ALEKSA~1\AppData\Local\Temp\arduino_build_932456/ssd1306_128x64_i2c.ino.hex:i
avrdude: Version 6.3-20190619
         System wide configuration file is "C:\Program Files\Arduino\hardware\tools\avr/etc/avrdude.conf"
         Using Port                    : COM7
         AVR Part                      : ATmega328P
         Chip Erase delay              : 9000 us
         PAGEL                         : PD7
         BS2                           : PC2
         RESET disposition             : dedicated
         RETRY pulse                   : SCK
         serial program mode           : yes
         parallel program mode         : yes
         Timeout                       : 200
         StabDelay                     : 100
         CmdexeDelay                   : 25
         SyncLoops                     : 32
         ByteDelay                     : 0
         PollIndex                     : 3
         PollValue                     : 0x53
         Memory Detail                 :
                                  Block Poll               Page                       Polled
           Memory Type Mode Delay Size  Indx Paged  Size   Size #Pages MinW  MaxW   ReadBack
           eeprom        65    20     4    0 no       1024    4      0  3600  3600 0xff 0xff
           flash         65     6   128    0 yes     32768  128    256  4500  4500 0xff 0xff
           lfuse          0     0     0    0 no          1    0      0  4500  4500 0x00 0x00
           hfuse          0     0     0    0 no          1    0      0  4500  4500 0x00 0x00
           efuse          0     0     0    0 no          1    0      0  4500  4500 0x00 0x00
           lock           0     0     0    0 no          1    0      0  4500  4500 0x00 0x00
           calibration    0     0     0    0 no          1    0      0     0     0 0x00 0x00
           signature      0     0     0    0 no          3    0      0     0     0 0x00 0x00
         Programmer Type : Arduino
         Description     : Arduino
         Hardware Version: 3
         Firmware Version: 4.4
         Vtarget         : 0.3 V
         Varef           : 0.3 V
         Oscillator      : 28.800 kHz
         SCK period      : 3.3 us
avrdude: AVR device initialized and ready to accept instructions
Reading | ################################################## | 100% 0.00s
avrdude: Device signature = 0x1e950f (probably m328p)
avrdude: reading input file "C:\Users\ALEKSA~1\AppData\Local\Temp\arduino_build_932456/ssd1306_128x64_i2c.ino.hex"
avrdude: writing flash (20988 bytes):
Writing | ################################################## | 100% 3.94s
avrdude: 20988 bytes of flash written
avrdude: verifying flash memory against C:\Users\ALEKSA~1\AppData\Local\Temp\arduino_build_932456/ssd1306_128x64_i2c.ino.hex:
avrdude: load data flash data from input file C:\Users\ALEKSA~1\AppData\Local\Temp\arduino_build_932456/ssd1306_128x64_i2c.ino.hex:
avrdude: input file C:\Users\ALEKSA~1\AppData\Local\Temp\arduino_build_932456/ssd1306_128x64_i2c.ino.hex contains 20988 bytes
avrdude: reading on-chip flash data:
Reading | avrdude: stk500_recv(): programmer is not responding
avr_read(): error reading address 0x0000
    read operation not supported for memory "flash"
avrdude: failed to read all of flash memory, rc=-2
the selected serial port
 does not exist or your board is not connected
I need to post this because i didnt solve a problem. I tried to use OLED display example from SSD1306 library and i get these error messages. If some had a similar problem and know how to fix it please answer.
rudolfm001
Code: [Select]
Sketch uses 444 bytes (1%) of program storage space. Maximum is 32256 bytes.
Global variables use 9 bytes (0%) of dynamic memory, leaving 2039 bytes for local variables. Maximum is 2048 bytes.
C:\Program Files (x86)\Arduino\hardware\tools\avr/bin/avrdude -CC:\Program Files (x86)\Arduino\hardware\tools\avr/etc/avrdude.conf -v -patmega328p -carduino -PCOM3 -b115200 -D -Uflash:w:C:\Users\Rudolf\AppData\Local\Temp\arduino_build_508931/sketch_feb24b.ino.hex:i
         Using Port                    : COM3
avrdude: stk500_getsync() attempt 1 of 10: not in sync: resp=0x72
avrdude: stk500_getsync() attempt 2 of 10: not in sync: resp=0x72
avrdude: stk500_getsync() attempt 3 of 10: not in sync: resp=0x72
avrdude: stk500_getsync() attempt 4 of 10: not in sync: resp=0x72
avrdude: stk500_getsync() attempt 5 of 10: not in sync: resp=0x72
avrdude: stk500_getsync() attempt 6 of 10: not in sync: resp=0x72
avrdude: stk500_getsync() attempt 7 of 10: not in sync: resp=0x72
avrdude: stk500_getsync() attempt 8 of 10: not in sync: resp=0x72
avrdude: stk500_getsync() attempt 9 of 10: not in sync: resp=0x72
avrdude: stk500_getsync() attempt 10 of 10: not in sync: resp=0x72
Getting this error while trying to upload sketch to Arduino Uno Rev.3
Had to change main IC from,
Atmega328p U to Atmega328p-pu.
Please assist if possible.
Thank you.
Rudolf.
