Topic: avrdude: stk500_recv(): programmer is not responding (Read 95155 times) previous topic - next topic
coubyouatt
Arduino: 1.8.11 (Windows 10), Board: "Arduino Nano, ATmega328P"
Sketch uses 12072 bytes (39%) of program storage space. Maximum is 30720 bytes.
Global variables use 1030 bytes (50%) of dynamic memory, leaving 1018 bytes for local variables. Maximum is 2048 bytes.
C:\Program Files (x86)\Arduino\hardware\tools\avr/bin/avrdude -CC:\Program Files (x86)\Arduino\hardware\tools\avr/etc/avrdude.conf -v -patmega328p -carduino -PCOM5 -b115200 -D -Uflash:w:C:\Users\YACOUB~1.OUA\AppData\Local\Temp\arduino_build_942576/MultiWii.ino.hex:i
avrdude: Version 6.3-20190619
         Copyright (c) 2007-2014 Joerg Wunsch
         System wide configuration file is "C:\Program Files (x86)\Arduino\hardware\tools\avr/etc/avrdude.conf"
         Using Port                    : COM5
         Using Programmer              : arduino
         Overriding Baud Rate          : 115200
avrdude: stk500_getsync() attempt 1 of 10: not in sync: resp=0xf9
avrdude: stk500_getsync() attempt 2 of 10: not in sync: resp=0xf9
avrdude: stk500_getsync() attempt 3 of 10: not in sync: resp=0xf9
avrdude: stk500_getsync() attempt 4 of 10: not in sync: resp=0xf9
avrdude: stk500_getsync() attempt 5 of 10: not in sync: resp=0xf9
avrdude: stk500_getsync() attempt 6 of 10: not in sync: resp=0xf9
avrdude: stk500_getsync() attempt 7 of 10: not in sync: resp=0xf9
avrdude: stk500_getsync() attempt 8 of 10: not in sync: resp=0xf9
avrdude: stk500_getsync() attempt 9 of 10: not in sync: resp=0xf9
avrdude: stk500_getsync() attempt 10 of 10: not in sync: resp=0xf9
avrdude done.  Thank you.
Problem uploading to board.  See http://www.arduino.cc/en/Guide/Troubleshooting#upload for suggestions.
This report would have more information with
"Show verbose output during compilation"
option enabled in File -> Preferences.
pert
Select Tools > Processor > ATmega328P (Old Bootloader) and then try uploading again.
vadityap2013
I am working fine with arduino mega 2560 but arduino nano every thing is fail...
Arduino: 1.8.12 (Windows 10), Board: "Arduino Nano, ATmega328P"
Sketch uses 924 bytes (3%) of program storage space. Maximum is 30720 bytes.
Global variables use 9 bytes (0%) of dynamic memory, leaving 2039 bytes for local variables. Maximum is 2048 bytes.
An error occurred while uploading the sketch
avrdude: stk500_getsync() attempt 1 of 10: not in sync: resp=0x43
avrdude: stk500_getsync() attempt 2 of 10: not in sync: resp=0x43
avrdude: stk500_getsync() attempt 3 of 10: not in sync: resp=0x43
avrdude: stk500_getsync() attempt 4 of 10: not in sync: resp=0x43
avrdude: stk500_getsync() attempt 5 of 10: not in sync: resp=0x43
avrdude: stk500_getsync() attempt 6 of 10: not in sync: resp=0x43
avrdude: stk500_getsync() attempt 7 of 10: not in sync: resp=0x43
avrdude: stk500_getsync() attempt 8 of 10: not in sync: resp=0x43
avrdude: stk500_getsync() attempt 9 of 10: not in sync: resp=0x43
avrdude: stk500_getsync() attempt 10 of 10: not in sync: resp=0x43
pert
pumazote
Arduino:1.8.12 (Windows 7), Tarjeta:"Arduino Nano, ATmega328P"
El Sketch usa 4054 bytes (13%) del espacio de almacenamiento de programa. El máximo es 30720 bytes.
Las variables Globales usan 504 bytes (24%) de la memoria dinámica, dejando 1544 bytes para las variables locales. El máximo es 2048 bytes.
C:\Users\puma\AppData\Local\Arduino15\packages\arduino\tools\avrdude\6.3.0-arduino17/bin/avrdude -CC:\Users\puma\AppData\Local\Arduino15\packages\arduino\tools\avrdude\6.3.0-arduino17/etc/avrdude.conf -v -patmega328p -carduino -PCOM8 -b115200 -D -Uflash:w:C:\Program Files (x86)\Arduino/BrainSerialTest.ino.hex:i
         System wide configuration file is "C:\Users\puma\AppData\Local\Arduino15\packages\arduino\tools\avrdude\6.3.0-arduino17/etc/avrdude.conf"
         Using Port                    : COM8
avrdude: stk500_getsync() attempt 1 of 10: not in sync: resp=0x1f
avrdude: stk500_getsync() attempt 2 of 10: not in sync: resp=0x1f
avrdude: stk500_getsync() attempt 3 of 10: not in sync: resp=0x1f
avrdude: stk500_getsync() attempt 4 of 10: not in sync: resp=0x1f
avrdude: stk500_getsync() attempt 5 of 10: not in sync: resp=0x1f
avrdude: stk500_getsync() attempt 6 of 10: not in sync: resp=0x1f
avrdude: stk500_getsync() attempt 7 of 10: not in sync: resp=0x1f
avrdude: stk500_getsync() attempt 8 of 10: not in sync: resp=0x1f
avrdude: stk500_getsync() attempt 9 of 10: not in sync: resp=0x1f
avrdude: stk500_getsync() attempt 10 of 10: not in sync: resp=0x1f
Problema subiendo a la placa. Visita http://www.arduino.cc/en/Guide/Troubleshooting#upload para sugerencias.
Este informe podría contener más información con
"Mostrar salida detallada durante la compilación"
opción habilitada en Archivo -> Preferencias.
pert
         Using Port                    : COM8
amskuy
Hello.. i have the proplem, can you help me, please?
i have arduino uno and bluetooth hc-05
My problem is:
         Using Port                    : COM4
avrdude: stk500_getsync() attempt 1 of 10: not in sync: resp=0x64
avrdude: stk500_getsync() attempt 2 of 10: not in sync: resp=0x64
avrdude: stk500_getsync() attempt 3 of 10: not in sync: resp=0x64
avrdude: stk500_getsync() attempt 4 of 10: not in sync: resp=0x64
avrdude: stk500_getsync() attempt 5 of 10: not in sync: resp=0x64
avrdude: stk500_getsync() attempt 6 of 10: not in sync: resp=0x64
avrdude: stk500_getsync() attempt 7 of 10: not in sync: resp=0x64
avrdude: stk500_getsync() attempt 8 of 10: not in sync: resp=0x64
avrdude: stk500_getsync() attempt 9 of 10: not in sync: resp=0x64
avrdude: stk500_getsync() attempt 10 of 10: not in sync: resp=0x64
pert
Remove any connections to pins 0 and 1 on your Arduino board. These pins are used for communication with your computer, including uploads. Connecting anything to these pins can interfere with uploads.
amskuy
after i remove any connections to pins 0 and 1 on my arduino board,
i have error:
         Using Port                    : COM4
         AVR Part                      : ATmega328P
         Chip Erase delay              : 9000 us
         PAGEL                         : PD7
         BS2                           : PC2
         RESET disposition             : dedicated
         RETRY pulse                   : SCK
         serial program mode           : yes
         parallel program mode         : yes
         Timeout                       : 200
         StabDelay                     : 100
         CmdexeDelay                   : 25
         SyncLoops                     : 32
         ByteDelay                     : 0
         PollIndex                     : 3
         PollValue                     : 0x53
         Memory Detail                 :
                                  Block Poll               Page                       Polled
           Memory Type Mode Delay Size  Indx Paged  Size   Size #Pages MinW  MaxW   ReadBack
           eeprom        65    20     4    0 no       1024    4      0  3600  3600 0xff 0xff
           flash         65     6   128    0 yes     32768  128    256  4500  4500 0xff 0xff
           lfuse          0     0     0    0 no          1    0      0  4500  4500 0x00 0x00
           hfuse          0     0     0    0 no          1    0      0  4500  4500 0x00 0x00
           efuse          0     0     0    0 no          1    0      0  4500  4500 0x00 0x00
           lock           0     0     0    0 no          1    0      0  4500  4500 0x00 0x00
           calibration    0     0     0    0 no          1    0      0     0     0 0x00 0x00
           signature      0     0     0    0 no          3    0      0     0     0 0x00 0x00
         Programmer Type : Arduino
         Description     : Arduino
         Hardware Version: 3
         Firmware Version: 4.4
         Vtarget         : 0.3 V
         Varef           : 0.3 V
         Oscillator      : 28.800 kHz
         SCK period      : 3.3 us
Reading | ################################################## | 100% 0.00s
avrdude: Device signature = 0x1e950f (probably m328p)
avrdude: reading input file "C:\Users\ASUS\AppData\Local\Temp\arduino_build_500142/sketch_mar13b.ino.hex"
avrdude: writing flash (3918 bytes):
Writing | ################################################## | 100% 0.61s
avrdude: 3918 bytes of flash written
avrdude: verifying flash memory against C:\Users\ASUS\AppData\Local\Temp\arduino_build_500142/sketch_mar13b.ino.hex:
avrdude: load data flash data from input file C:\Users\ASUS\AppData\Local\Temp\arduino_build_500142/sketch_mar13b.ino.hex:
avrdude: input file C:\Users\ASUS\AppData\Local\Temp\arduino_build_500142/sketch_mar13b.ino.hex contains 3918 bytes
avrdude: reading on-chip flash data:
Reading | ################################################## | 100% 0.47s
avrdude: verifying ...
avrdude: 3918 bytes of flash verified
amskuy
i have error:
         Using Port                    : COM4
         PAGEL                         : PD7
         BS2                           : PC2
         RETRY pulse                   : SCK
         Timeout                       : 200
         StabDelay                     : 100
         CmdexeDelay                   : 25
         SyncLoops                     : 32
         ByteDelay                     : 0
         PollIndex                     : 3
         PollValue                     : 0x53
         Memory Detail                 :
         Hardware Version: 3
         Vtarget         : 0.3 V
         Varef           : 0.3 V
         SCK period      : 3.3 us
Help me please..
Budvar10
#85
Apr 21, 2020, 08:30 am Last Edit: Apr 21, 2020, 08:31 am by Budvar10
Error? It doesn't seem.
PS: Please, put the log into the code tags.
Arduino clone with ATmega1284P   http://forum.arduino.cc/index.php?topic=277260.0
pyqahsyu
Arduino: 1.8.12 (Windows 10), Board: "Arduino Uno"
Sketch uses 4530 bytes (14%) of program storage space. Maximum is 32256 bytes.
Global variables use 334 bytes (16%) of dynamic memory, leaving 1714 bytes for local variables. Maximum is 2048 bytes.
C:\Program Files (x86)\Arduino\hardware\tools\avr/bin/avrdude -CC:\Program Files (x86)\Arduino\hardware\tools\avr/etc/avrdude.conf -v -patmega328p -carduino -PCOM6 -b115200 -D -Uflash:w:C:\Users\AFIQAH~1\AppData\Local\Temp\arduino_build_356052/Testingdht11.ino.hex:i
         Using Port                    : COM6
avrdude: stk500_getsync() attempt 1 of 10: not in sync: resp=0x45
avrdude: stk500_getsync() attempt 2 of 10: not in sync: resp=0x45
avrdude: stk500_getsync() attempt 3 of 10: not in sync: resp=0x45
avrdude: stk500_getsync() attempt 4 of 10: not in sync: resp=0x45
avrdude: stk500_getsync() attempt 5 of 10: not in sync: resp=0x45
avrdude: stk500_getsync() attempt 6 of 10: not in sync: resp=0x45
avrdude: stk500_getsync() attempt 7 of 10: not in sync: resp=0x45
avrdude: stk500_getsync() attempt 8 of 10: not in sync: resp=0x45
avrdude: stk500_getsync() attempt 9 of 10: not in sync: resp=0x45
avrdude: stk500_getsync() attempt 10 of 10: not in sync: resp=0x45
af0ns0uwuwu
Arduino: 1.8.12 (Windows Store 1.8.33.0) (Windows 10), Placa:"Arduino Nano, ATmega328P"
O rascunho usa 12326 bytes (40%) do espaço de armazenamento do programa. O máximo é 30720 bytes.
Variáveis globais usam 1069 bytes (52%) de memória dinâmica, restando 979 bytes para variáveis locais. O maximo é 2048 bytes.
C:\Program Files\WindowsApps\ArduinoLLC.ArduinoIDE_1.8.33.0_x86__mdqgnx93n4wtt\hardware\tools\avr/bin/avrdude -CC:\Program Files\WindowsApps\ArduinoLLC.ArduinoIDE_1.8.33.0_x86__mdqgnx93n4wtt\hardware\tools\avr/etc/avrdude.conf -v -patmega328p -carduino -PCOM3 -b115200 -D -Uflash:w:C:\Users\FX503VD\AppData\Local\Temp\arduino_build_334009/MultiWii.ino.hex:i
        System wide configuration file is "C:\Program Files\WindowsApps\ArduinoLLC.ArduinoIDE_1.8.33.0_x86__mdqgnx93n4wtt\hardware\tools\avr/etc/avrdude.conf"
        Using Port                    : COM3
avrdude: stk500_getsync() attempt 1 of 10: not in sync: resp=0x84
avrdude: stk500_getsync() attempt 2 of 10: not in sync: resp=0x84
avrdude: stk500_getsync() attempt 3 of 10: not in sync: resp=0x84
avrdude: stk500_getsync() attempt 4 of 10: not in sync: resp=0x84
avrdude: stk500_getsync() attempt 5 of 10: not in sync: resp=0x84
avrdude: stk500_getsync() attempt 6 of 10: not in sync: resp=0x84
avrdude: stk500_getsync() attempt 7 of 10: not in sync: resp=0x84
avrdude: stk500_getsync() attempt 8 of 10: not in sync: resp=0x84
avrdude: stk500_getsync() attempt 9 of 10: not in sync: resp=0x84
avrdude: stk500_getsync() attempt 10 of 10: not in sync: resp=0x84
Problema a carregar para a placa. Vê http://www.arduino.cc/en/Guide/Troubleshooting#upload para sugestões.
Este relatório teria mais informação com a
opção «Mostrar mensagens detalhadas durante a
compilação» seleccionada nas Preferências.
[/quote]
billtubbs
For me, the problem was I had Arduino Uno selected but then I found out my board is Arduino Leonardo.
This caused the error messages above and its repeatable.
Not sure why Arduino didn't design the boards to be recognizable by the software.
rogerdrouby
         Using Port                    : COM3
avrdude: stk500_getsync() attempt 1 of 10: not in sync: resp=0x6a
avrdude: stk500_getsync() attempt 2 of 10: not in sync: resp=0x6a
avrdude: stk500_getsync() attempt 3 of 10: not in sync: resp=0x6a
avrdude: stk500_getsync() attempt 4 of 10: not in sync: resp=0x6a
avrdude: stk500_getsync() attempt 5 of 10: not in sync: resp=0x6a
avrdude: stk500_getsync() attempt 6 of 10: not in sync: resp=0x6a
avrdude: stk500_getsync() attempt 7 of 10: not in sync: resp=0x6a
avrdude: stk500_getsync() attempt 8 of 10: not in sync: resp=0x6a
avrdude: stk500_getsync() attempt 9 of 10: not in sync: resp=0x6a
avrdude: stk500_getsync() attempt 10 of 10: not in sync: resp=0x6a
