Topic: avrdude: stk500_recv(): programmer is not responding (Read 95167 times) previous topic - next topic
pert
avrdude: stk500_getsync() attempt 1 of 10: not in sync: resp=0x6a
Remove any connections to pins 0 and 1 on your Arduino board. These pins are used for communication with your computer, including uploads. Connecting anything to these pins can interfere with uploads.
Make sure you have the correct board selected from the Tools > Board menu.
Make sure you have selected the port of your Arduino board from the Tools > Port menu.
Sometimes the port will be labeled with the board name in the menu. Other times it will not. If you don't know which port is your Arduino board, you can find it like this:
  • Unplug your Arduino board from the computer.
  • Tools > Port
  • Note the ports, if any, listed in the menu.
  • Close the Tools menu. The ports list is only updated when the Tools menu is re-opened, so this step is essential.
  • Plug your Arduino board into the computer.
  • Tools > Port - The new port listed in the menu is your Arduino board.
superwiku
Arduino: 1.8.12 (Windows Store 1.8.33.0) (Windows 10), Board: "Arduino Nano, ATmega328P (Old Bootloader)"
<Sketch uses 3418 bytes (11%) of program storage space. Maximum is 30720 bytes.
Global variables use 369 bytes (18%) of dynamic memory, leaving 1679 bytes for local variables. Maximum is 2048 bytes.
avrdude: initialization failed, rc=-1
         Double check connections and try again, or use -F to override
         this check.
Problem uploading to board.  See http://www.arduino.cc/en/Guide/Troubleshooting#upload for suggestions.
This report would have more information with
"Show verbose output during compilation"
option enabled in File -> Preferences./>
nitran87700
Select Arduino or file basis operating system you use and select preferences. Under preferences find "Proxy" and change the value to No Proxy. That fixes the communication error
mohir
Hello,
I have a very strange situation,
I fail to upload programs to my Uno boards, tried 2 different ones on 2 computers, all I get is 'programmer is not responding'. com port is fine. and I uploaded many times to uno boars before
to all other kinds of boards, Nano, ESP8266, and ESP32 all uploads without any problem.
please help :)
Regards
pert
Please do this:
  • (In the Arduino IDE) File > Preferences
  • Uncheck the checkbox next to "Show verbose output during: compilation"
  • Check the checkbox next to "Show verbose output during: upload
  • Click "OK"
  • Sketch > Upload
  • After the upload fails, you'll see a button on the right side of the orange bar "Copy error messages" (or the icon that looks like two pieces of paper at the top right corner of the black console window in the Arduino Web Editor). Click that button.
  • In a forum reply here, click on the reply field.
  • Click the </> button on the forum toolbar. This will add the forum's code tags markup to your reply.
  • Press "Ctrl + V". This will paste the upload output between the code tags.
  • Move the cursor outside of the code tags before you add any additional text to your reply.
mohir
Thank you,
now it got even stranger, :)
the problem disappeared, on both computers,
really don't know what was going on.
Thanks again
pert
You're welcome. I'm just glad to hear that it's working for you now. Certainly none of my instructions would be expected to fix the problem. They were only intended to get information that could be used to diagnose the issue.
kaspiuxz
Hello, i just got my arduino nano 3.0. Tried first time to upload and this happened:
Arduino: 1.8.12 (Windows 10), Board: "Arduino Nano, ATmega328P (Old Bootloader)"
Sketch uses 924 bytes (3%) of program storage space. Maximum is 30720 bytes.
Global variables use 9 bytes (0%) of dynamic memory, leaving 2039 bytes for local variables. Maximum is 2048 bytes.
avrdude: stk500_getsync() attempt 1 of 10: not in sync: resp=0x94
avrdude: stk500_getsync() attempt 2 of 10: not in sync: resp=0x94
avrdude: stk500_getsync() attempt 3 of 10: not in sync: resp=0x94
avrdude: stk500_getsync() attempt 4 of 10: not in sync: resp=0x94
avrdude: stk500_getsync() attempt 5 of 10: not in sync: resp=0x94
avrdude: stk500_getsync() attempt 6 of 10: not in sync: resp=0x94
avrdude: stk500_getsync() attempt 7 of 10: not in sync: resp=0x94
avrdude: stk500_getsync() attempt 8 of 10: not in sync: resp=0x94
avrdude: stk500_getsync() attempt 9 of 10: not in sync: resp=0x94
avrdude: stk500_getsync() attempt 10 of 10: not in sync: resp=0x94
pert
Select Tools > Processor > ATmega328P and then try uploading again.
pert
Make sure you have the correct board selected from the Tools > Board menu. Note that there are multiple boards with "Nano" in their name. The board you have selected in the Arduino IDE's menu is for the classic Nano. If you have a Nano 33 IoT, Nano Every, or Nano 33 BLE, you need a different board selection.
  • Tools > Port
forbrains
Under-voltage.
Check the voltage on RAW & VCC.
You'll get this is your voltage drops to 4.6v during the Write / verification Read phases.
It's common if using a USB to TTL adapter to see the voltage drop too much when programming the chip.
wooyoungyoon
C:\Program Files (x86)\Arduino\hardware\tools\avr/bin/avrdude -CC:\Program Files (x86)\Arduino\hardware\tools\avr/etc/avrdude.conf -v -patmega328p -carduino -PCOM5 -b57600 -D -Uflash:w:C:\Users\v-woyoon\AppData\Local\Temp\arduino_build_86211/sketch_jun01b.ino.hex:i
avrdude: Version 6.3-20190619
         Copyright (c) 2007-2014 Joerg Wunsch
         System wide configuration file is "C:\Program Files (x86)\Arduino\hardware\tools\avr/etc/avrdude.conf"
         Using Port                    : COM5
         Using Programmer              : arduino
         Overriding Baud Rate          : 57600
avrdude: stk500_getsync() attempt 1 of 10: not in sync: resp=0x39
avrdude: stk500_getsync() attempt 2 of 10: not in sync: resp=0x39
avrdude: stk500_getsync() attempt 3 of 10: not in sync: resp=0x39
avrdude: stk500_getsync() attempt 4 of 10: not in sync: resp=0x39
avrdude: stk500_getsync() attempt 5 of 10: not in sync: resp=0x39
avrdude: stk500_getsync() attempt 6 of 10: not in sync: resp=0x39
avrdude: stk500_getsync() attempt 7 of 10: not in sync: resp=0x39
avrdude: stk500_getsync() attempt 8 of 10: not in sync: resp=0x39
avrdude: stk500_getsync() attempt 9 of 10: not in sync: resp=0x39
avrdude: stk500_getsync() attempt 10 of 10: not in sync: resp=0x39
avrdude done.  Thank you.
pert
lucaf69
Arduino:1.8.12 (Windows 10), Scheda:"Anet V1.0"
Lo sketch usa 111980 byte (88%) dello spazio disponibile per i programmi. Il massimo รจ 126976 byte.
Le variabili globali usano 4511 byte di memoria dinamica.
C:\Program Files (x86)\Arduino\hardware\tools\avr/bin/avrdude -CC:\Program Files (x86)\Arduino\hardware\tools\avr/etc/avrdude.conf -v -patmega1284p -carduino -PCOM3 -b57600 -D -Uflash:w:C:\Users\Luca\AppData\Local\Temp\arduino_build_67896/Marlin.ino.hex:i
         Using Port                    : COM3
avrdude: stk500_getsync() attempt 1 of 10: not in sync: resp=0xc8
avrdude: stk500_getsync() attempt 2 of 10: not in sync: resp=0xc8
avrdude: stk500_getsync() attempt 3 of 10: not in sync: resp=0xc8
avrdude: stk500_getsync() attempt 4 of 10: not in sync: resp=0xc8
avrdude: stk500_getsync() attempt 5 of 10: not in sync: resp=0xc8
avrdude: stk500_getsync() attempt 6 of 10: not in sync: resp=0xc8
avrdude: stk500_getsync() attempt 7 of 10: not in sync: resp=0xc8
avrdude: stk500_getsync() attempt 8 of 10: not in sync: resp=0xc8
avrdude: stk500_getsync() attempt 9 of 10: not in sync: resp=0xc8
avrdude: stk500_getsync() attempt 10 of 10: not in sync: resp=0xc8
Problema di caricamento sulla scheda. Guarda http://www.arduino.cc/en/Guide/Troubleshooting#upload per suggerimenti
I have tried everything found on the net to solve this problem but I have not had any results
Can anyone help me
i am trying to mount the marlin 1.1.9 on my anet a6
the motherboard was just repaired with the replacement of the processor that had burned out.
Thank you.
