Topic: avrdude: stk500_recv(): programmer is not responding (Read 94240 times) previous topic - next topic
calebjnz
I got this problem because i cooked one of the usb ports on my computer, now i have to remember to use the other usb port.
m0n0zen
Arduino: 1.8.12 (Windows 10), Board: "Arduino Uno"
Sketch uses 444 bytes (1%) of program storage space. Maximum is 32256 bytes.
Global variables use 9 bytes (0%) of dynamic memory, leaving 2039 bytes for local variables. Maximum is 2048 bytes.
C:\Program Files (x86)\Arduino\hardware\tools\avr/bin/avrdude -CC:\Program Files (x86)\Arduino\hardware\tools\avr/etc/avrdude.conf -v -patmega328p -carduino -PCOM6 -b115200 -D -Uflash:w:C:\Users\jelle\AppData\Local\Temp\arduino_build_627339/sketch_jun29a.ino.hex:i
avrdude: Version 6.3-20190619
         Copyright (c) 2007-2014 Joerg Wunsch
         System wide configuration file is "C:\Program Files (x86)\Arduino\hardware\tools\avr/etc/avrdude.conf"
         Using Port                    : COM6
         Using Programmer              : arduino
         Overriding Baud Rate          : 115200
         AVR Part                      : ATmega328P
         Chip Erase delay              : 9000 us
         PAGEL                         : PD7
         BS2                           : PC2
         RESET disposition             : dedicated
         RETRY pulse                   : SCK
         serial program mode           : yes
         parallel program mode         : yes
         Timeout                       : 200
         StabDelay                     : 100
         CmdexeDelay                   : 25
         SyncLoops                     : 32
         ByteDelay                     : 0
         PollIndex                     : 3
         PollValue                     : 0x53
         Memory Detail                 :
                                  Block Poll               Page                       Polled
           Memory Type Mode Delay Size  Indx Paged  Size   Size #Pages MinW  MaxW   ReadBack
           eeprom        65    20     4    0 no       1024    4      0  3600  3600 0xff 0xff
           flash         65     6   128    0 yes     32768  128    256  4500  4500 0xff 0xff
           lfuse          0     0     0    0 no          1    0      0  4500  4500 0x00 0x00
           hfuse          0     0     0    0 no          1    0      0  4500  4500 0x00 0x00
           efuse          0     0     0    0 no          1    0      0  4500  4500 0x00 0x00
           lock           0     0     0    0 no          1    0      0  4500  4500 0x00 0x00
           calibration    0     0     0    0 no          1    0      0     0     0 0x00 0x00
           signature      0     0     0    0 no          3    0      0     0     0 0x00 0x00
         Programmer Type : Arduino
         Description     : Arduino
         Hardware Version: 3
         Firmware Version: 4.4
         Vtarget         : 0.3 V
         Varef           : 0.3 V
         Oscillator      : 28.800 kHz
         SCK period      : 3.3 us
Reading | ################################################## | 100% 0.00s
avrdude: Device signature = 0x1e950f (probably m328p)
avrdude: reading input file "C:\Users\jelle\AppData\Local\Temp\arduino_build_627339/sketch_jun29a.ino.hex"
avrdude: writing flash (444 bytes):
Writing | ################################################## | 100% 0.08s
avrdude: 444 bytes of flash written
avrdude: verifying flash memory against C:\Users\jelle\AppData\Local\Temp\arduino_build_627339/sketch_jun29a.ino.hex:
avrdude: load data flash data from input file C:\Users\jelle\AppData\Local\Temp\arduino_build_627339/sketch_jun29a.ino.hex:
avrdude: input file C:\Users\jelle\AppData\Local\Temp\arduino_build_627339/sketch_jun29a.ino.hex contains 444 bytes
avrdude: reading on-chip flash data:
Reading | ############avrdude: stk500_recv(): programmer is not responding
#############avrdude: stk500_recv(): programmer is not responding
avr_read(): error reading address 0x0000
    read operation not supported for memory "flash"
avrdude: failed to read all of flash memory, rc=-2
avrdude done.  Thank you.
the selected serial port
 does not exist or your board is not connected
This report would have more information with
"Show verbose output during compilation"
option enabled in File -> Preferences.
Feldur
I also have this problem. I've gone through all the recommended checks, and in fact the blynk-ser.sh script loads up and starts to cycle properly. The board is an Uno Wifi rev 2. I'm running macOS Big Sur beta, and some days ago had success uploading to an Uno (not Wifi). Here's my upload messages:
Arduino: 1.8.13 (Mac OS X), Board: "Arduino Uno WiFi"
Sketch uses 9212 bytes (28%) of program storage space. Maximum is 32256 bytes.
Global variables use 395 bytes (19%) of dynamic memory, leaving 1653 bytes for local variables. Maximum is 2048 bytes.
/Users/press/Library/Arduino15/packages/arduino/tools/avrdude/6.3.0-arduino17/bin/avrdude -C/Users/press/Library/Arduino15/packages/arduino/tools/avrdude/6.3.0-arduino17/etc/avrdude.conf -v -patmega328p -carduino -P/dev/cu.usbmodem143302 -b115200 -D -Uflash:w:/var/folders/x3/8mq7t3fj3h95_4q1nxzm2yv80000gn/T/arduino_build_820518/Button_-_Serial_USB.ino.hex:i
        System wide configuration file is "/Users/press/Library/Arduino15/packages/arduino/tools/avrdude/6.3.0-arduino17/etc/avrdude.conf"
        User configuration file is "/Users/press/.avrduderc"
        User configuration file does not exist or is not a regular file, skipping
        Using Port                    : /dev/cu.usbmodem143302
avrdude: stk500_getsync() attempt 1 of 10: not in sync: resp=0x00
avrdude: stk500_getsync() attempt 2 of 10: not in sync: resp=0x00
avrdude: stk500_getsync() attempt 3 of 10: not in sync: resp=0x00
avrdude: stk500_getsync() attempt 4 of 10: not in sync: resp=0x00
avrdude: stk500_getsync() attempt 5 of 10: not in sync: resp=0x00
avrdude: stk500_getsync() attempt 6 of 10: not in sync: resp=0x00
avrdude: stk500_getsync() attempt 7 of 10: not in sync: resp=0x00
avrdude: stk500_getsync() attempt 8 of 10: not in sync: resp=0x00
avrdude: stk500_getsync() attempt 9 of 10: not in sync: resp=0x00
avrdude: stk500_getsync() attempt 10 of 10: not in sync: resp=0x00
Problem uploading to board.  See http://www.arduino.cc/en/Guide/Troubleshooting#upload for suggestions.
kp99
I tried everything but no luck. Then I replace my hardware with new one (Nano) and everything is OK.
pert
With the old one, did you try both the Tools > Processor > ATmega328P (Old Bootloader) and Tools > Processor > ATmega328P options?
lxndr33
Hi
worked fine for my Nano 3.0 on windows 8
Thx
pert
You're welcome. I'm glad to hear it's working now. Enjoy!
Per
brown2bob
Newbie here.... I've got another failure to communicate with the programmer:
avrdude: stk500_recv(): programmer is not responding (10x) whew... the retries are wearing me out!  :o
I have a custom design matching the Adafruit Metro: ATmega328P, cp2102n, please see the attached schematic clip for reference.  I've been successful installing the Arduino Uno Bootloader via AVR Pocket Programmer.  ATmega seems fine, executes the 1-sec blink test ok. Uploading sketches via programmer is working ok.
My challenge is trying to upload over USB.  The CP2102n enumerates fine, creates a new Port 10 which is visible in Device Manager.  SiLabs drivers are loaded and identify correctly in Device Manager.  Checked the port settings, baud = 9600. Updated the settings in Arduino for programmer = Arduino ISP, port = 10. Serial looks ok on O'scope.
Probably something simple and silly on my end.  Thanks in advance for your time and wisdom.
Best Regards,
Bob
pert
When you do that, you erase the bootloader. So you need to do another Burn Bootloader before you can upload via your CP2102.
brown2bob
That was it!  Guess I blew away the bootloader with the programmer upload.  A million thanks!!!!
Best Regards,
Bob
pert
Per
ahkt714
Hello, I am having the same problem with my official Arduino Uno board that has been working flawlessly for the past month.  I have tried the official Uno on 2 macs and 1 PC with the same uploading error.  My generic SMD Uno board has no problems with uploading and works on all three computers with the same setup i.e. USB cable.  I am using MacOS Catalina 10.15.6 and have not installed any new updates or apps prior to the Uno board errors.
I have tried to reflash the bootloader using my generic UNO to my official Arduino but getting an error as well.  I will copy and post it on another message.
Arduino: 1.8.12 (Mac OS X), Board: "Arduino Uno"
Sketch uses 924 bytes (2%) of program storage space. Maximum is 32256 bytes.
/Users/atsang/Library/Arduino15/packages/arduino/tools/avrdude/6.3.0-arduino17/bin/avrdude -C/Users/atsang/Library/Arduino15/packages/arduino/tools/avrdude/6.3.0-arduino17/etc/avrdude.conf -v -patmega328p -carduino -P/dev/cu.usbmodem143301 -b115200 -D -Uflash:w:/var/folders/11/vp62rx8566x2z_nhzktf27b80000gn/T/arduino_build_460647/Blink.ino.hex:i
         System wide configuration file is "/Users/atsang/Library/Arduino15/packages/arduino/tools/avrdude/6.3.0-arduino17/etc/avrdude.conf"
         User configuration file is "/Users/atsang/.avrduderc"
         Using Port                    : /dev/cu.usbmodem143301
Any help would be helpful.  Thanks.
thanghustk58
Arduino: 1.8.9 (Windows 10), Board: "Arduino/Genuino Uno"
Sketch uses 10186 bytes (31%) of program storage space. Maximum is 32256 bytes.
Global variables use 264 bytes (12%) of dynamic memory, leaving 1784 bytes for local variables. Maximum is 2048 bytes.
C:\Users\admin\AppData\Local\Arduino15\packages\arduino\tools\avrdude\6.3.0-arduino14/bin/avrdude -CC:\Users\admin\AppData\Local\Arduino15\packages\arduino\tools\avrdude\6.3.0-arduino14/etc/avrdude.conf -v -patmega328p -carduino -PCOM8 -b115200 -D -Uflash:w:C:\Users\admin\AppData\Local\Temp\arduino_build_215105/HelloWorld.ino.hex:i
avrdude: Version 6.3-20171130
         System wide configuration file is "C:\Users\admin\AppData\Local\Arduino15\packages\arduino\tools\avrdude\6.3.0-arduino14/etc/avrdude.conf"
         Using Port                    : COM8
avrdude: stk500_getsync() attempt 1 of 10: not in sync: resp=0x8a
avrdude: stk500_getsync() attempt 2 of 10: not in sync: resp=0x8a
avrdude: stk500_getsync() attempt 3 of 10: not in sync: resp=0x8a
avrdude: stk500_getsync() attempt 4 of 10: not in sync: resp=0x8a
avrdude: stk500_getsync() attempt 5 of 10: not in sync: resp=0x8a
avrdude: stk500_getsync() attempt 6 of 10: not in sync: resp=0x8a
avrdude: stk500_getsync() attempt 7 of 10: not in sync: resp=0x8a
avrdude: stk500_getsync() attempt 8 of 10: not in sync: resp=0x8a
avrdude: stk500_getsync() attempt 9 of 10: not in sync: resp=0x8a
avrdude: stk500_getsync() attempt 10 of 10: not in sync: resp=0x8a
pert
Remove any connections to pins 0 and 1 on your Arduino board. These pins are used for communication with your computer, including uploads. Connecting anything to these pins can interfere with uploads.
Make sure you have the correct board selected from the Tools > Board menu. Note that there are multiple boards with "Nano" in their name. The board you have selected in the Arduino IDE's menu is for the classic Nano. If you have a Nano 33 IoT, Nano Every, or Nano 33 BLE, you need a different board selection.
Make sure you have selected the port of your Arduino board from the Tools > Port menu.
Sometimes the port will be labeled with the board name in the menu. Other times it will not. If you don't know which port is your Arduino board, you can find it like this:
  • Unplug your Arduino board from the computer.
  • Tools > Port
  • Note the ports, if any, listed in the menu.
  • Close the Tools menu. The ports list is only updated when the Tools menu is re-opened, so this step is essential.
  • Plug your Arduino board into the computer.
  • Tools > Port - The new port listed in the menu is your Arduino board.
corm
Have the same problem connect the Arduino Uno WiFi Rev 2 with hosts (Ubuntu and Win10) with different USB cables, on the board the LED L is blinking amber since the first power up and LED ON is solid green. Used both IDEs web and local version 1.8.13.
Under Tools the selected board is "Arduino Uno", and the port is /dev/ttyACM0 (Arduino Uno WiFi Rev2)
Board Info returns:
BN: Arduino Uno WiFi Rev2
VID: 03eb
PID: 2145
SN: 3E6A63C0EF2A705141A3
Compilation of the Blink code is error free and here is the upload log:
        System wide configuration file is "/home/admin/snap/arduino/41/.arduino15/packages/arduino/tools/avrdude/6.3.0-arduino17/etc/avrdude.conf"
        User configuration file is "/home/admin/snap/arduino/41/.avrduderc"
        Using Port                    : /dev/ttyACM0
