Topic: Need help (Read 642 times) previous topic - next topic
SydWalters
Apr 12, 2019, 07:21 am Last Edit: Oct 05, 2019, 11:46 am by SydWalters
What should and shouldn't you do when composting your food?
It is a very healthy lifestyle to lead if you are recycling your food waste. It is even best if you are becoming a gardener. A dual-purpose action benefits your life and the surrounding environment. However, you might need to know some things before starting your recycling.
✪✪✪ Check Over Here: The List Of Product Reviewed - Top Best Product In The World TheKingLive.com
Not all kinds of food waste can become material for the composting process. Below, we recommend what you should and shouldn't put into the composter. We have also found you the best products for your composting, which will also replace the traditional composting process.
1. What should you put into your composter?
5 best foods for composting:
Grass or leaves: when grass or leaves are green, they bring the best nutrients (including nitrogen) for your composting. In turn, nitrogen is vital for sustaining growing plants.
Tomatoes contain rich sources for the development of your plants. They will grow faster and sooner.
Coffee grounds increase plants' ability to fight against diseases as well as provide a rich soil base for seeding plants.
Eggshells enrich the soil with calcium, which helps plants grow stronger.
Peanuts enhance the shape of your plants.
Mix up the food waste with your grass cuttings and leaves. It will help the aerating process and prevent your material from clumping inside the composter.
Dampen the composting pile, but never soak it in water.
If you want to add more food waste, remember to mix it with paper, grass, or leaves to avoid engaging gnawers.
Read The Article: Review comparison
2. What shouldn't you put into your composter?
Do not add the following items into your composting process: coffee or tea bags, fish, meat, or dairy products. There are two main reasons why you should not compost them. First, they contain elements that are toxic to your plants or attracts the animals attacking your plants. Second, these elements are harmful to you in the long term.
Avoid using weeds because they include a lot of seeds which are not easily killed during the composting process.
Never use dog or cat poop. It is full of bacteria, viruses, and germs which are very harmful and proactive, even though the poop is totally broken down in the composter.
3. Some composters we can recommend for you.
Worm Factory 360 WF360 Worm Composter, a top reviewed product with over 85% positive ratings out of 810 on Amazon.com. With the price of $110, you can have the best worm composter, saving you time, money, and space. You will find composting is never easier than that. It will fit your kitchen, garage, or any other space of your choice.
The FCMP Outdoor IM4000 Tumbling Composter - one of the best of products for your outdoor composting, with a large capacity, excellent aeration, and durability, at just $77 on Amazon.com.
Miracle-Gro Small Composter - Compact Single Chamber Outdoor Garden Compost Bin: the best seller on Amazon.com at $60. It is a tremendous little composter, and it is easy to put together, sturdy, and performs the job excellently. It helps to drive the composting time faster, and its spinning ability is very useful for mixing it all up. Moreover, the instructions are straightforward and user friendly.
✫✫✫ Selected For You: Compare reviews
The above are just our recommendations based on Amazon's customer reviews and Amazon's choice. You can make your own decision following your searching results. In addition, you need to read the manual and instructions before starting.
BJHenry
As a rule of thumb, if you have to ask questions like that then you shouldn't be playing around with mains power at all.
Best bet would just be to get a mains plug pack that puts out about 7V DC and use that to power the Arduino.
