Topic: Newcomers, change the IDE default BareMinimum.ino file. (Read 1 time) previous topic - next topic
larryd
To newcomers.
Save programming time when you start new Arduino projects.
Modify your BareMinimum.ino file which is a template for new programs.
When you use File/New in your IDE, this is the template that is presented.
Attached below is the template I use.  BareMinimum.ino
(EDIT: I have included SwitchManagerWithFilter.h too, see below.)
When you have decided on a style you like, save it to the directory as see above.
No technical PMs.
If you are asked a question, please respond with an answer.
If you are asked for more information, please supply it.
If you need clarification, ask for help.
Power_Broker
"The desire that guides me in all I do is the desire to harness the forces of nature to the service of mankind."
   - Nikola Tesla
larryd
No technical PMs.
neiklot
Here's mine:
//ref
//date
  Serial.println(".... description ....");
  Serial.print("Created: ");
  Serial.print(__TIME__);
  Serial.print(", ");
  Serial.println(__DATE__);
  //turn off L13
  pinMode(LED_BUILTIN, OUTPUT);
  digitalWrite(LED_BUILTIN, LOW);
} //setup
} //loop
Erik_Baas
There is one problem: Windows won't let you edit any file in that folder (or any other folder in C:\Program Files (x86)). You have to move the file to - for example - C:\Temp, edit it and then move it back! And don't try to start the IDE or create a new project in the mean time, the IDE will crash.
larryd
You can edit the file if you run under administrator privileges.
No technical PMs.
Erik_Baas
Nope. I could not save it, in spite of being logged in as administrator. (Windows 7/64)
larryd
No technical PMs.
dougp
I just got it done like this:
Windows assumed
Create new file.  It'll be named sketch<date>
Modify as desired and save it in the user folder and close
Navigate to the user folder and to the folder containing the newly created .ino file
Copy the .ino file.
Navigate to the bare minimum folder as illustrated above
Paste your new custom file to the folder
Rename the existing bareMinimum, I used 'BareMinimum orig'
Rename the new file to BareMinimum
Done
Thanks, larryd!
Everything we call real is made of things that cannot be regarded as real.  If quantum mechanics hasn't profoundly shocked you, you haven't understood it yet. - Niels Bohr
No private consultations undertaken!
larryd
On the Mac     / Java / examples / 01.Basics / BareMinimum
See post #6 and 8
https://forum.arduino.cc/index.php?topic=611876.msg4148957#msg4148957
No technical PMs.
GypsumFantastic
See post #6 and 8
It's probably worth adding that on Mac the file is replaced every time you upgrade the IDE so if the changes are non-trivial it might be worth keeping a backup copy somewhere outside the Arduino.app package.
