Topic: Erro compilando para a placa Arduino/Genuino Uno (Read 558 times) previous topic - next topic
eng-newton
Somente em um netbook não consigo compilar, o montor serial funciona, mas dá erro ao compilar.
Já desinstalei a IDE e a reinstalei. o erro continua.
Aparece a seguinte mensagem de erro:
Arduino: 1.8.9 (Windows 7), Placa:"Arduino/Genuino Uno"
Using core 'arduino' from platform in folder: C:\Users\ASUS\AppData\Local\Arduino15\packages\arduino\hardware\avr\1.6.22
Detecting libraries used...
"C:\\Users\\ASUS\\AppData\\Local\\Arduino15\\packages\\arduino\\tools\\avr-gcc\\5.4.0-atmel3.6.1-arduino2/bin/avr-g++" -c -g -Os -w -std=gnu++11 -fpermissive -fno-exceptions -ffunction-sections -fdata-sections -fno-threadsafe-statics -flto -w -x c++ -E -CC -mmcu=atmega328p -DF_CPU=16000000L -DARDUINO=10809 -DARDUINO_AVR_UNO -DARDUINO_ARCH_AVR "-IC:\\Users\\ASUS\\AppData\\Local\\Arduino15\\packages\\arduino\\hardware\\avr\\1.6.22\\cores\\arduino" "-IC:\\Users\\ASUS\\AppData\\Local\\Arduino15\\packages\\arduino\\hardware\\avr\\1.6.22\\variants\\standard" "C:\\Users\\ASUS\\AppData\\Local\\Temp\\arduino_build_890717\\sketch\\ReadASCIIString.ino.cpp" -o nul
Generating function prototypes...
"C:\\Users\\ASUS\\AppData\\Local\\Arduino15\\packages\\arduino\\tools\\avr-gcc\\5.4.0-atmel3.6.1-arduino2/bin/avr-g++" -c -g -Os -w -std=gnu++11 -fpermissive -fno-exceptions -ffunction-sections -fdata-sections -fno-threadsafe-statics -flto -w -x c++ -E -CC -mmcu=atmega328p -DF_CPU=16000000L -DARDUINO=10809 -DARDUINO_AVR_UNO -DARDUINO_ARCH_AVR "-IC:\\Users\\ASUS\\AppData\\Local\\Arduino15\\packages\\arduino\\hardware\\avr\\1.6.22\\cores\\arduino" "-IC:\\Users\\ASUS\\AppData\\Local\\Arduino15\\packages\\arduino\\hardware\\avr\\1.6.22\\variants\\standard" "C:\\Users\\ASUS\\AppData\\Local\\Temp\\arduino_build_890717\\sketch\\ReadASCIIString.ino.cpp" -o "C:\\Users\\ASUS\\AppData\\Local\\Temp\\arduino_build_890717\\preproc\\ctags_target_for_gcc_minus_e.cpp"
"C:\\Program Files\\Arduino\\tools-builder\\ctags\\5.8-arduino11/ctags" -u --language-force=c++ -f - --c++-kinds=svpf --fields=KSTtzns --line-directives "C:\\Users\\ASUS\\AppData\\Local\\Temp\\arduino_build_890717\\preproc\\ctags_target_for_gcc_minus_e.cpp"
Compilando sketch...
"C:\\Users\\ASUS\\AppData\\Local\\Arduino15\\packages\\arduino\\tools\\avr-gcc\\5.4.0-atmel3.6.1-arduino2/bin/avr-g++" -c -g -Os -Wall -Wextra -std=gnu++11 -fpermissive -fno-exceptions -ffunction-sections -fdata-sections -fno-threadsafe-statics -MMD -flto -mmcu=atmega328p -DF_CPU=16000000L -DARDUINO=10809 -DARDUINO_AVR_UNO -DARDUINO_ARCH_AVR "-IC:\\Users\\ASUS\\AppData\\Local\\Arduino15\\packages\\arduino\\hardware\\avr\\1.6.22\\cores\\arduino" "-IC:\\Users\\ASUS\\AppData\\Local\\Arduino15\\packages\\arduino\\hardware\\avr\\1.6.22\\variants\\standard" "C:\\Users\\ASUS\\AppData\\Local\\Temp\\arduino_build_890717\\sketch\\ReadASCIIString.ino.cpp" -o "C:\\Users\\ASUS\\AppData\\Local\\Temp\\arduino_build_890717\\sketch\\ReadASCIIString.ino.cpp.o"
Compiling libraries...
Compiling core...
Usando arquivo compilado anteriormente: C:\Users\ASUS\AppData\Local\Temp\arduino_build_890717\core\wiring_pulse.S.o
Usando arquivo compilado anteriormente: C:\Users\ASUS\AppData\Local\Temp\arduino_build_890717\core\hooks.c.o
Usando arquivo compilado anteriormente: C:\Users\ASUS\AppData\Local\Temp\arduino_build_890717\core\wiring.c.o
Usando arquivo compilado anteriormente: C:\Users\ASUS\AppData\Local\Temp\arduino_build_890717\core\WInterrupts.c.o
Usando arquivo compilado anteriormente: C:\Users\ASUS\AppData\Local\Temp\arduino_build_890717\core\wiring_analog.c.o
Usando arquivo compilado anteriormente: C:\Users\ASUS\AppData\Local\Temp\arduino_build_890717\core\wiring_digital.c.o
Usando arquivo compilado anteriormente: C:\Users\ASUS\AppData\Local\Temp\arduino_build_890717\core\wiring_shift.c.o
Usando arquivo compilado anteriormente: C:\Users\ASUS\AppData\Local\Temp\arduino_build_890717\core\wiring_pulse.c.o
Usando arquivo compilado anteriormente: C:\Users\ASUS\AppData\Local\Temp\arduino_build_890717\core\Tone.cpp.o
Usando arquivo compilado anteriormente: C:\Users\ASUS\AppData\Local\Temp\arduino_build_890717\core\WString.cpp.o
Usando arquivo compilado anteriormente: C:\Users\ASUS\AppData\Local\Temp\arduino_build_890717\core\PluggableUSB.cpp.o
Usando arquivo compilado anteriormente: C:\Users\ASUS\AppData\Local\Temp\arduino_build_890717\core\USBCore.cpp.o
Usando arquivo compilado anteriormente: C:\Users\ASUS\AppData\Local\Temp\arduino_build_890717\core\abi.cpp.o
Usando arquivo compilado anteriormente: C:\Users\ASUS\AppData\Local\Temp\arduino_build_890717\core\WMath.cpp.o
Usando arquivo compilado anteriormente: C:\Users\ASUS\AppData\Local\Temp\arduino_build_890717\core\CDC.cpp.o
Usando arquivo compilado anteriormente: C:\Users\ASUS\AppData\Local\Temp\arduino_build_890717\core\new.cpp.o
Usando arquivo compilado anteriormente: C:\Users\ASUS\AppData\Local\Temp\arduino_build_890717\core\Stream.cpp.o
Usando arquivo compilado anteriormente: C:\Users\ASUS\AppData\Local\Temp\arduino_build_890717\core\main.cpp.o
Usando arquivo compilado anteriormente: C:\Users\ASUS\AppData\Local\Temp\arduino_build_890717\core\HardwareSerial1.cpp.o
Usando arquivo compilado anteriormente: C:\Users\ASUS\AppData\Local\Temp\arduino_build_890717\core\HardwareSerial3.cpp.o
Usando arquivo compilado anteriormente: C:\Users\ASUS\AppData\Local\Temp\arduino_build_890717\core\HardwareSerial2.cpp.o
Usando arquivo compilado anteriormente: C:\Users\ASUS\AppData\Local\Temp\arduino_build_890717\core\Print.cpp.o
Usando arquivo compilado anteriormente: C:\Users\ASUS\AppData\Local\Temp\arduino_build_890717\core\IPAddress.cpp.o
Usando arquivo compilado anteriormente: C:\Users\ASUS\AppData\Local\Temp\arduino_build_890717\core\HardwareSerial.cpp.o
Usando arquivo compilado anteriormente: C:\Users\ASUS\AppData\Local\Temp\arduino_build_890717\core\HardwareSerial0.cpp.o
"C:\\Users\\ASUS\\AppData\\Local\\Arduino15\\packages\\arduino\\tools\\avr-gcc\\5.4.0-atmel3.6.1-arduino2/bin/avr-gcc-ar" rcs "C:\\Users\\ASUS\\AppData\\Local\\Temp\\arduino_build_890717\\core\\core.a" "C:\\Users\\ASUS\\AppData\\Local\\Temp\\arduino_build_890717\\core\\CDC.cpp.o"
Error running c:\users\asus\appdata\local\arduino15\packages\arduino\tools\avr-gcc\5.4.0-atmel3.6.1-arduino2\bin\../lib/gcc/avr/5.4.0/../../../../avr/bin/ar.exe: CreateProcess
exit status 1
