Topic: sending email using arduino uno wifi rev2 (Read 367 times) previous topic - next topic
MohamadMohamad
hello
i am trying to send data in a mail using arduino uno wifi rev2, i tried this program but it doesn't work.
the arduino is already connected to the wifi.
could you check the following program and tell me what i have to change or any suggestions ?
thanks.
Code: [Select]
#include <WiFiNINA.h>
#include <SPI.h>
const int touch1 = 2;                            // touch sensor 1 is connected to pin number 2.
const int touch2 = 4;                            // touch sensor 2 is connected to pin number 4.
const int touch3 = 5;                            // touch sensor 3 is connected to pin number 5.
const int touch4 = 8;                            // touch sensor 4 is connected to pin number 8.
const int BUZZ = 9;                              // BUZZER is connected to pin number 9.
int A , B , C , D = 0;
const char net [] =  "xxxxxxxxxx";                          // name of the router
const char pass [] = "xxxxxxxxxx";                      // wifi passwoard
int status = WL_IDLE_STATUS;    // function that detect if the arduino is connected or disconnected
WiFiSSLClient wifi;                          // create wifi in wificlient class
IPAddress ip(192, 168, 43, 215);                 // give ip adress to arduino
char from [] = "arduinounowifirev2@yahoo.com";      // email of sender
char password [] = "xxxxxxxxxxx";                     // email password
char to [] = "xxxxxxxxxxxxxx@xxxxxxx.com";
char sub [] = "Results";
String from_base64 = ("xxxxxxxxxxxxxxxxxxxxx");    // email of sender in base64
String password_base64 = ("xxxxxxxxxxxxxxx");                            // email password in base64
const String host [] = "pop.mail.yahoo.com";
const String port [] = "995";
  pinMode ( touch1 , INPUT );        // set pin 2 as input.
  pinMode ( touch2 , INPUT );        // set pin 4 as input.
  pinMode ( touch3 , INPUT );        // set pin 5 as input.
  pinMode ( touch4 , INPUT );        // set pin 8 as input.
  pinMode ( BUZZ , OUTPUT );         // set pin 9 as output.
  status = WiFi.begin( net , pass );           // start the wifi and give the wifi name and password
  while( status != WL_CONNECTED )              // wait till the arduino is connected to the wifi
    status = WiFi.begin ( net , pass );
  Serial.println( "Connected to wifi" );
  wifi.connect ( host , port );
  if (wifi.connect(host, port)) {
  Serial.println ( " access to server " );
  wifi.println("EHLO kltan");
  wifi.println(F("250"));
  wifi.println("AUTH LOGIN");
  wifi.println(F("334 YXJkdWlub3Vub3dpZmlyZXYyQGhvdG1haWwuY29t"));
  wifi.println (from_base64);
  wifi.println(F("334 bWhhbWFkMTIz"));
  wifi.println ( password_base64 );
  wifi.println ( F ("235"));
  char mailfrom [20] = "MAIL FROM:<";
  strcat ( mailfrom , from );
  strcat ( mailfrom , ">" );
  wifi.println ( mailfrom );
  wifi.println (F ("250"));
  char mailto [20] = "RCPT TO:<";
  strcat ( mailto , to );
  strcat ( mailto , ">" );
  wifi.println ( mailto );
  wifi.println ( F ("250"));
  wifi.println ( "DATA" );
  wifi.println ( F ("354"));
  char efrom [50] = "FROM: ";
  strcat ( efrom , from );
  strcat ( efrom , " " );
  strcat ( efrom , "<" );
  strcat ( efrom , ">" );
  wifi.println ( efrom );
  char eto [50] = "TO: ";
  strcat ( eto , to );
  strcat ( eto , " " );
  strcat ( eto , "<" );
  strcat ( eto , ">" );
  wifi.println ( eto );
  char subject [50] = "SUBJECT: ";
  strcat ( subject , sub );
  wifi.println ( subject );
  wifi.println ( "\r\n" );
  wifi.println ("welcome to Arduino, we will count the results and send them each 5 min. ");
  wifi.println ( "QUIT" );
  }else{
    Serial.println ( " couldn't access to server " );
 printWiFiStatus();
  Serial.println ( " welcome to Arduino, we will count the results and send them each 5 min. " );
  Serial.println ( "_________________________________________________________________________________ " );
   int e , f , g , h , i = 0 ;
   int vtouch1 = digitalRead ( touch1 );
   int vtouch2 = digitalRead ( touch2 );
   int vtouch3 = digitalRead ( touch3 );
   int vtouch4 = digitalRead ( touch4 );
for ( i = 0 ; i < 300000 ; i++ )
  delay ( 1 );
    if ( vtouch1 == 1 )                     // if the touch sensor that correspond to trop bien is touched increase the result of trop bien and start the buzzer for 0.2s in a frecuency of 1000 HZ.
      e++;
      tone ( BUZZ , 1000 );
      delay ( 200 );
      noTone ( BUZZ );
      A = A + e ;                          // e is the result of trop bien for 5 min. we added to A that is the result of trop bien for all time.
    else if ( vtouch2 == 1 )                // if the touch sensor that correspond to bien is touched increase the result of trop bien and start the buzzer for 0.2s in a frecuency of 1000 HZ.
      f++;
      delay ( 200 );
      noTone ( BUZZ );
      B = B + f ;                           // f is the result of bien for 5 min. we added to B that is the result of bien for all time.
    else if ( vtouch3 == 1 )                 // if the touch sensor that correspond to mal is touched increase the result of trop bien and start the buzzer for 0.2s in a frecuency of 1000 HZ.
      g++;
      delay ( 200 );
      noTone ( BUZZ );
      C = C + g ;                           // g is the result of mal for 5 min. we added to C that is the result of mal for all time.
    else if ( vtouch4 == 1 )                 // if the touch sensor that correspond to trop mal is touched increase the result of trop bien and start the buzzer for 0.2s in a frecuency of 1000 HZ.
      h++;
      delay ( 200 );
      noTone ( BUZZ );
      D = D + h ;                           // h is the result of trop mal for 5 min. we added to D that is the result of trop mal for all time.
String m5 = " the result of the 5 min is : " ;
String mt = " the result of all time is : " ;
String tb = " trop bien , " ;
String b = " bien , " ;
String m = " mal et " ;
String TM = " trop mal." ;
String R5 = m5 + e + tb + f + b + g + m + h + TM ;
String RT = mt + A + tb + B + b + C + m + D + TM ;
Serial.println ( R5 );
Serial.println ( RT );
void printWiFiStatus() {
  // print the SSID of the network you're attached to:
  Serial.print("SSID: ");
  Serial.println(WiFi.SSID());
  // print your board's IP address:
  IPAddress ip = WiFi.localIP();
  Serial.print("IP Address: ");
  Serial.println(ip);
  // print the received signal strength:
  long rssi = WiFi.RSSI();
  Serial.print("signal strength (RSSI):");
  Serial.print(rssi);
  Serial.println(" dBm");
pert
Please provide a detailed description of what you mean by "it doesn't work".
What is the expected behavior?
What is the behavior you're observing that doesn't match your expectations?
MohamadMohamad
what i want is a way to access the email.
 i tried using hotmail, yahoo and gmail ( i change the settings of email to have access from pop ) by using the commande
wifi.connect ( server , port );
server in this commande is " pop.mail.yahoo.com " as an example for pop and i tried using smtp check
 ( https://support.office.com/en-us/article/pop-and-imap-email-settings-for-outlook-8361e398-8af4-4e97-b147-6c6c4ac95353 )
but i couldn't access to the email.
pylon
Code: [Select]
Port is provided as an integer not a string. Did that code actually compile?
