Topic: DC Motor Control with DRV8801 (Read 123 times) previous topic - next topic
JazzyJ
Hi, my aim is to just control the direction and speed of the Micro-Metal Gearmotor with this motor driver DRV8801.
For now my code is
Code: [Select]
int PWM1=  2;
int DIR1= 22;
int Brake1= 28;
  pinMode(PWM1, OUTPUT);
  pinMode(DIR1, OUTPUT);
  pinMode(Brake1,OUTPUT);
  digitalWrite(DIR1, LOW);
analogWrite(PWM1, 200);
delay(2000);
digitalWrite(DIR1, HIGH);
analogWrite(PWM1, 50);
But the motor is neither changing direction nor speed. What am I doing wrong?
groundFungus
Code: [Select]
int PWM1=  2;
What Arduino board are you using?  An Uno (or equivalent) has PWM on pins 3,5,6,9,10,11.  Not pin 2.
JazzyJ
Code: [Select]
int PWM1=  2;
I'm using the mega 2560 R3
JazzyJ
Has been solved, the solder was cold and wasn't connecting the DIR properly.
