Topic: Push button on-off (Read 165 times) previous topic - next topic
dragonflex
Hallo everybody, could you help me a little? As long as I push a button I want the output pin1 to became HIGH and output pin2 LOW, else LOW and LOW, When I push the button for second time I want pin1 to became LOW and pin2 HIGH, else LOW and LOW. Third time begin cycle again. Any idea? Thanks a lot.
PaulS
Quote
Any idea?
Yeah. Look at the state change detection example. It describes exactly what you are asking about, except that it deals with one output pin. Trivial to make it deal with two pins instead.
neiklot
That's a tad ambiguous, OP....
Do you mean while the button is pressed the first time the outputs are high/low and when released low/low, followed by another held press low/high and back to low/low on release?
In other words while the button unpressed the output is always low/low, and while it is pressed an odd time, outputs are high/low and low/high during even presses?
If that's right you need to do what PaulS just said to see a new press, and the example includes doing a count so it's easy to test for odd / even, BUT you also need to handle the unpressed case.
(Iff I understood you correctly, OP.)
dragonflex
Thats right, neiklot. A piece of code please?
PaulS
Quote
evanmars
#5
Apr 17, 2019, 04:10 pm Last Edit: Apr 17, 2019, 04:10 pm by evanmars
Here's a piece of code:
Code: [Select]
Fill in the rest with your best try.
dragonflex
 if (buttonPushCounter % 1 ) {
    digitalWrite(ledPin3, HIGH);
    digitalWrite(ledPin4, LOW);
    digitalWrite(ledPin3, LOW);
  if (buttonPushCounter % 2 ) {
    digitalWrite(ledPin4, HIGH);
this do not work
evanmars
#7
Apr 17, 2019, 04:27 pm Last Edit: Apr 17, 2019, 04:30 pm by evanmars
this do not work
No big surprise.  There is no setup() and no loop().
Not to mention no digitalRead of the push button pin.
No assigning a value to the undeclared/undefined variable "buttonPushCounter"
dragonflex
Code: [Select]
const int  buttonPin = 2;
const int ledPin3 = 8;
const int ledPin4 = 9;
// Variables will change:
int buttonPushCounter = 0;
int buttonState = 0;
int lastButtonState = 0;
  pinMode(buttonPin, INPUT_PULLUP);
  pinMode(ledPin3, OUTPUT);
  pinMode(ledPin4, OUTPUT);
  buttonState = digitalRead(buttonPin);
  if (buttonState != lastButtonState) {
    if (buttonState == LOW) {
      buttonPushCounter++;
      Serial.println("on");
      Serial.print("number of button pushes: ");
      Serial.println(buttonPushCounter);
      Serial.println("off");
    delay(50);
  lastButtonState = buttonState;
  }[code]
The code
wildbill
This makes no sense:
Code: [Select]
It's always 0, so your code always sets your two outputs low unconditionally.
You want three states, so if you're going to use the % operator, use 3, not 1.
Then add a switch statement based on the result of that modulo calculation with a case for 0, 1  and 2.
PaulS
Code: [Select]
What will be the remainder of dividing an int by 1?
neiklot
That logic counts the new presses and you only do the led switching once you come out of the main if. You need to do your odd/even thing inside the main if where it detects the button press since you said the leds are only on WHILE the button is pressed.
It's too late, where you do it.
And an easy way to test for odd or even is a bitwise and:
Code: [Select]
if (count & 1)
    //odd
   //even
