Topic: can't install IDE on Ubuntu (Read 3601 times) previous topic - next topic
mickgobb
I've spent 3 days wrestling with this installation and am at wit's end.
OS is Unbutu 16.04.6 lts. I've performed apt update and apt upgrade (in place of apt-get) within the last 24 hours.
I downloaded arduino-1.8.9-linux64.tar.xz from the Arduino site.
I put the tar.xz package in another directory and extracted it there.
I examined the install.sh script to confirm RESOURCE_NAME=arduino-arduinoide was correct. The I ran install.sh (sudo ./install.sh).
I got this message:
Adding desktop shortcut, menu item and file associations for Arduino IDE...
rm: cannot remove '/usr/local/bin/arduino': No such file or directory
Removing symlink failed. Hope that's OK. If not then rerun as root with sudo.
 Done!
The next day, I did the same thing using arduino-1.8.9-linux32.tar.xz. And got the same results.
I don't want to trash this Arduino project but I only have so much time to pursue it. Any help would be greatly appreciated.
gbafamily
Change to the directory where you extracted the IDE files. Usually it is ~/arduino-1.8.9. Launch arduino from command line using "./arduino".
Are you sure you are running 64 bit Linux? Examine the output of "uname -a" to be sure.
pert
I got this message:
Those messages are expected and normal with a fresh install of the Arduino IDE. You can safely ignore them. Now it's time for you to get to having fun with Arduino!
FYI, the install script was recently improved so that in the next release of the Arduino IDE it won't generate these warnings and cause unnecessary confusion:
https://github.com/arduino/Arduino/pull/8781
