Topic: Error: expected '}' before '{' token (Read 143 times) previous topic - next topic
mattlogue
There clearly is a '}' at the end of that first line! Its a 5x35 array. Compiling for an ESP12E. I know i shoud not use String, but is it worse than using char pointers in unallocated mem blocks...
Code: [Select]
const     String    eAddrNames[5][EADDR_SZ] = { { "RESERVED" }
                        { "dailyEmails", "emailsCount", "fanEvery", "fanFor", "fanMode", "fanPostMixTime", "fanTimeout", "HHOffset", "hysteresis", "lastEmailHour", "lastIssueCodeI", "minsFan", "minsCool", "minsHeat", "lock", "MMOffset", "temperature", "temperatureSet", "tempX", "timeBlocks", "tempTimeout", "timeNTP", "lastVersionDayA", "version2A", "version3A", "lastVersionDayB", "version2B", "version3B", "RESERVED_INT", "RESERVED_INT"}
                        { "unlockTime", "codeMS", "epoch", "longmillis", "lastEmailMS", "lastIssueMS", "myResetMS", "RESERVED_LONG", "RESERVED_LONG", "RESERVED_LONG", "RESERVED_LONG", "RESERVED_LONG", "RESERVED_LONG", "RESERVED_LONG", "RESERVED_LONG" }
                          { "APPass", "ATTPass", "BIPass", "RESERVED_CHAR10", "RESERVED_CHAR10", "RESERVED_CHAR10", "RESERVED_CHAR10", "RESERVED_CHAR10", "RESERVED_CHAR10" }
                          { "RESERVED_STRING20", "RESERVED_STRING20", "RESERVED_STRING20", "RESERVED_STRING20" } };
Just because I live in the states don't mean I care
GoForSmoke
troll
Code: [Select]
1) http://gammon.com.au/blink  <-- tasking Arduino 1-2-3
2) http://gammon.com.au/serial <-- techniques howto
3) http://gammon.com.au/interrupts
Your sketch can sense ongoing process events in time.
Your sketch can make events to control it over time.
mattlogue
Montmorency
#3
Apr 18, 2019, 05:25 am Last Edit: Apr 18, 2019, 05:28 am by Montmorency
Um, aggregate initializers are supposed to be separated by commas. Where are your commas?
Code: [Select]
const String eAddrNames[5][EADDR_SZ] = { { "RESERVED" }, // <- comma
      "version3B", "RESERVED_INT", "RESERVED_INT"}, // <- comma
      // and so on
mattlogue
I missed the commas between the dimensions. Darn, thanks!
GoForSmoke
because whatever you do, don't define char arrays then use those or even more, don't put const chars in PROGMEM.
Load up your RAM with data you already have a copy of and be sure to use C++ convenience objects to trash the heap.
mattlogue
Yep
GoForSmoke
You should know better after all this time, hence Reply #1.
Quote
That's hardly helpful.
I'm hardly helping you shoot your own foot. Noted.
