Topic: Simple NRF24L01 based temperature sensor transmitter/receiver (Read 964 times) previous topic - next topic
RoboDocFezy
hey guys ,
M making a simple temperature transmitter receiver system using NRF24l01 modules , the goal is to install a remote module that gathers temperature data via ds18b20 and transmits via nrf to a base station that datalogs the temp data on serial . since the remote temperature module needs to be powered by a battery i used a lowpower library on Arduino pro mini 3.3v to transmit data only once every 8secs, and on the base its just a arduino mega with NRF attached .
the problem m facing is that every 10 to 20 packets i lose one or 2 packets , how can i make sure it doesnt happen , for initial testing the modules are kept just a few feet apart , code is given below
transmitter code Arduino pro mini 3.3v
Code: [Select]
#include <SPI.h>
#include <nRF24L01.h>
#include <RF24.h>
#include <OneWire.h>
#include <DallasTemperature.h>
#include "LowPower.h"
// Data wire is plugged into pin 2 on the Arduino
#define ONE_WIRE_BUS 2
RF24 radio(9, 10); // CE, CSN
OneWire oneWire(ONE_WIRE_BUS);
DallasTemperature sensors(&oneWire);
const byte address[6] = "10001";
int count = 0 ;
byte sensorid = 0x01;
struct Tempdata {
  byte s_id;
  float celc;
  int count;
Tempdata packet;
  // Start up the library
  sensors.begin();
  radio.begin();
  radio.openWritingPipe(address);
  radio.setPALevel(RF24_PA_MAX);
  radio.setDataRate( RF24_250KBPS );    //RF24_250KBPS //RF24_1MBPS //RF24_2MBPS
  radio.setRetries(15, 15);             // delay, count
  radio.setAutoAck(false);
  radio.stopListening();
  radio.powerUp(); // new bit for LP
  delay(5);  // new bit for LP
  Serial.print(" Requesting temperatures...");
  sensors.requestTemperatures(); // Send the command to get temperature readings
  Serial.println("DONE");
  packet.celc = sensors.getTempCByIndex(0);
  packet.count = count;
  packet.s_id = sensorid;
  radio.write(&packet, sizeof(packet));
  count++;
   delay(100);
  radio.flush_tx();
// new bit added for LP
  radio.powerDown();
  MCUCR |= (3 << 5); //set both BODS and BODSE at the same time
  MCUCR = (MCUCR & ~(1 << 5)) | (1 << 6); //then set the BODS bit and clear the BODSE bit at the same time
  LowPower.powerDown(SLEEP_8S, ADC_OFF, BOD_OFF); // sleep for 4 seconds with all IOs OFF
Recieving end code Arduino Mega
Code: [Select]
#include <SPI.h>
#include <RF24.h>
byte node[6] = "10001";
RF24 radio(7, 8); // CE, CSN
struct Tempdata {
  byte s_id;
  float celc;
  int count;
Tempdata temp;
Tempdata packet[4];
int counter;
  radio.begin();
  radio.setPALevel(RF24_PA_MAX); //set data rate 256kpbs radio , set auto ack off
  radio.startListening();
    radio.openReadingPipe(0, node);
    Nrf_read(0);
    delay(50);
void Nrf_read(int x) {
  int error;
  if (radio.available()) {
    radio.read(&temp, sizeof(temp));
    packet[x] = temp;
    Serial.print("Sensor ID: ");
    Serial.print(packet[x].s_id);
    Serial.print("  ;  ");
    Serial.print("Temperature is: ");
    Serial.print(packet[x].celc);
    Serial.print("Count : ");
    Serial.print(packet[x].count);
    Serial.println("  ;  ");
  else if (!radio.available())
   error++;
m using a array because in next step i want recieve temprature from multiple modules
Robin2
The Exhibition section is for working demo programs, not problems. I have suggested to the Moderator to move your question to the Networking section.
Have a look at this Simple nRF24L01+ Tutorial.
Wireless problems can be very difficult to debug so get the wireless part working on its own before you start adding any other features.
The examples are as simple as I could make them and they have worked for other Forum members. If you get stuck it will be easier to help with code that I am familiar with. Start by getting the first example to work
How are you powering your nRF24s? Inadequate power is a common cause of problems. Try powering them with a pair of AA alkaline cells (3v) with the battery GND connected to the Arduino GND.
...R
Two or three hours spent thinking and reading documentation solves most programming problems.
Whandall
Code: [Select]
This configuration is just silly.
There will be no retries or delays if autoAck is switched off.
Ah, this is obviously some strange usage of the word 'safe' that I wasn't previously aware of. (D.Adams)
Robin2
And if autoAck is disabled it quite likely explains the lost packets.
...R
Whandall
At least nobody will retry and collisions happen on a shared medium.  ;)
RoboDocFezy
...R
I'm powering the transmitter via usb outlet .
also just ran it for 10 hours straight and got just 206 packet losses out of 4908 thats approx 4%packet loss
Robin2
You can't connect an nRF24 module to a USB outlet - so if you want help please provide a detailed description.
...R
