Topic: Can not upload using Web Editor.  (Read 1 time) previous topic - next topic
LEEDOWON
Apr 18, 2019, 03:47 pm Last Edit: Apr 18, 2019, 03:49 pm by LEEDOWON
When uploading using Web Editor, uploading is not possible. ALWAYS BUSY -_-...
However if use IDE, upload is possible.
Here is Arduino Create Agent 'DEBUG' message.
What is the problem?
Why is the port closed?
Windows 10 64bit (latest version)
use Chrome, Edge (latest version)
NO anti virus, ALLOW firewall
Code: [Select]
{"Version" : "1.1.86"}
{"Commands" : ["list", "open [portName] [baud] [bufferAlgorithm (optional)]", "send [portName] [cmd]", "sendnobuf [portName] [cmd]", "close [portName]", "bufferalgorithms", "baudrates", "restart", "exit", "program [portName] [board:name] [$path/to/filename/without/extension]", "programfromurl [portName] [board:name] [urlToHexFile]"]}
{"Hostname" : "DESKTOP-PBU6MG0"}
{"OS" : "windows"}
downloadtool windows-drivers latest arduino keep
{"DownloadStatus":"Pending","Msg":"The tool is already present on the system"}
{"DownloadStatus":"Success","Msg":"Map Updated"}
downloadtool bossac 1.7.0 arduino keep
list
{ "Ports": [], "Network": true }
{ "Ports": [ { "Name": "COM5", "SerialNumber": "75430333137351A050B1", "DeviceClass": "", "IsOpen": false, "IsPrimary": false, "Baud": 0, "BufferAlgorithm": "", "Ver": "1.1.86", "NetworkPort": false, "VendorID": "0x2A03", "ProductID": "0x0043" } ], "Network": false }
close COM5
{"Error" : "We could not find the serial port COM5 that you were trying to close."}
list
list
pert
ballscrewbob
A great post including most of the details needed but a couple of items missing if you would not mind.
Which particular board It says UNO in the picture so just checking ?
Clone or true Arduino ?
USB 3.0 or 2.0 ports ?
Network type ( your own or a company / educational ) ?
Bob.
It may not be the answer you were looking for but its the one I am giving based on either experience, educated guess, google or the fact that you gave nothing to go with in the first place so I used my wonky crystal ball.
Peplinskijohn
I am having similar problem.
Windows 7
Chrome, updated
Mega, 2560 clone
usb 2
private home network
My board uploaded fine prior to today with no problem on web editor.  It currently works fine with IDE.  Web editor recognizes and connects with board on COM12 but stays busy without end when attempting to upload, no error message.  The board can also print to serial monitor on web with its current code, just can't upload via web.
This is from the debug console:
Code: [Select]
{"Hostname" : "John-P50"}
{"OS" : "windows"}
list
{ "Ports": [ { "Name": "COM12", "SerialNumber": "75439333435351E02252", "DeviceClass": "", "IsOpen": false, "IsPrimary": false, "Baud": 0, "BufferAlgorithm": "", "Ver": "1.1.86", "NetworkPort": false, "VendorID": "0x2341", "ProductID": "0x0042" } ], "Network": false }
I have:  checked port in device manager, changed com port manually, checked for updated driver, uninstalled and reinstalled arduino create plugin, restarted computer many times, changed usb ports, tried editor in firefox vs. chrome, disabled firewall and antivirus, double checked com port and board type, and even checked to see if other board types might somehow work.
I'm stumped. Please help.
LEEDOWON
thanks ~_~
It's same problem as me. I'll try to change port number manually. and i use 2560 Mega clone and R3 Uno true product.
Windows 7
Chrome, updated
Mega, 2560 clone
usb 2
Code: [Select]
{"OS" : "windows"}
list
pert
I also can reproduce this issue. I have reported it to the Arduino developers. I'll post an update here if I have any new information to share.
myalenti
I can confirm the same behavior...
No more than 7 days ago everything was fine. Using the web editor to upload to my meg2560...
Locally installed IDE works, just the web editor does not seem to work.
Tried it in Firefox, Chrome... Tried clearing local cache as well...
Tried re-installing the agent as well.
Happening on a Windows 10 System
Will try to duplicate this behavior on my Mac to see if this is platform specific.
pert
Hi. The developers are asking for some additional information so they can investigate the issue. Please click on the tray icon for Arduino Create Agent. In the menu, it will show the agent version, something like this: "Agent version 1.1.86-5c199c1". Please tell us which version is shown on your menu.
Thanks!
ninora
#8
Apr 19, 2019, 11:20 am Last Edit: Apr 19, 2019, 12:56 pm by ninora
Same problem here the last few days, stays on "Busy" and not uploading.
Did agent uninstall and reinstall, worked for a while, didn't help when i tried that again.
Stopping and restarting the agent, reloading the browser, restarting the PC, nothing works.
Windows 10, 64 Bit
Windows firewall OFF, no other firewall / antivirus installed
USB 2.0
Self managed network, Cable Modem, no F/W, no Proxy
Chrome Version 73.0.3683.103 (Official Build) (64-bit)
MKR WIFI 1010 with/without MKR ETH SHIELD
MKR GSM 1400
Code: [Select]
{"Hostname" : "OFFICE10"}
{"OS" : "windows"}
list
{ "Ports": [ { "Name": "COM12", "SerialNumber": "", "DeviceClass": "", "IsOpen": false, "IsPrimary": false, "Baud": 0, "BufferAlgorithm": "", "Ver": "1.1.86", "NetworkPort": false, "VendorID": "0x2341", "ProductID": "0x0054" } ], "Network": false }
LEEDOWON
#9
Apr 19, 2019, 03:04 pm Last Edit: Apr 19, 2019, 03:08 pm by LEEDOWON
Hello
My agent version is "Agent version 1.1.86-5c199c1".
additionally it also does not work on Firefox... T.T
Thanks!
Baggage_warrior
Similar thing happening to me.
Tried with an UNO R3 and an UNO Wifi R2.
Code is verifying fine, offline IDE seems to be working fine, but web editor won't upload. Rx/Tx lights aren't lighting up on either board, so it seems like web editor isn't working with my COM3 port :(
I'll check firewall settings and stuff.
For those wanting specs:
Using via Chrome
Windows 10
USB 2
Private home network
No error message, just won't even start uploading.
-BW
pert
Thanks for the information Baggage_warrior! Please tell us which version of the Arduino Create Agent you're using:
Baggage_warrior
Sorry for missing that part out...
-BW
myalenti
Same version of Arduino Agent for me on Windows 10...
1.1.86-5c199c1...
Meanwhile i verified that the web editor and arduino agent works fine on my Mac Mojave with the same version of the agent.
Peplinskijohn
Same here.  1.1.86-5c199c1
Thanks for following up
