Topic: Trying to sweep a servo 10 times but my loop isn't working? (Read 417 times) previous topic - next topic
WhosAGoodBoy
I'm trying to sweep it from 20-120 degrees 10 times but it just keeps running indefinitely. Can anyone help me out?
#include <Servo.h>
Servo myservo;
int pos = 0;
byte i;
void setup(){
  myservo.attach(8);
void loop(){
  for (byte i; i < 11;i++){
    for (pos = 20; pos <= 120; pos += 1){
      myservo.write(pos);
      delay(15);
    for (pos = 120; pos >= 20; pos -= 1){
      myservo.write(pos);
      delay(15);
groundFungus
Can you control a servo with the smiley face pin?
If you want the for loop to happen only once, move the code that you have in loop() to setup().
You will save everyone's time if you read and follow the forum guidelines.  :)
https://forum.arduino.cc/index.php/topic,148850.0.html
and
https://forum.arduino.cc/index.php?topic=97455.0
Montmorency
groundFungus
Since i is declared global, it is initialized to 0 by default.   If i were declared as a local variable with no initializer it could be anything (whatever was in the assigned memory location).
and
evanmars
Isn't
Code: [Select]
for (byte i,
declaring a different i than the global i ?
Montmorency
It is true that the global `i` is implicitly initialized to zero.
However, the OP's `for` cycle declares and uses its own local `i`, which has no relation to the global `i` whatsoever. And that local `i' is left uninitialized.
So, once again, the `for` cycle relies on an ininitialized variable.
groundFungus
Quote
for (byte i,
Right, sorry, need more coffee.
and
WhosAGoodBoy
Okay so I also needed it to run only when I press enter something into the serial monitor but it's not doing anything when I give it an input. Any ideas?
#include <Servo.h>
Servo myservo;
int pos = 0;
int i = 0;
byte bytefromKbd;
void setup(){
  myservo.attach(8);
  Serial.println("Hit a key plus the [Enter] key to execute...:");
  if(Serial.available()){
    for (i = 0; i < 11; i++){
      for(pos = 20; pos <= 120; pos += 1){
        myservo.write(pos);
        delay(15);
      for(pos = 120; pos >= 20; pos -= 1){
        myservo.write(pos);
        delay(15);
void loop(){
evanmars
Why do you still have the smiley face in your code?
Hint: read the post describing how to post your code  AKA Read this before posting a programming question ...
evanmars
PaulS
Code: [Select]
        myservo.write(pos);
        delay(15);
        myservo.write(pos);
        delay(15);
Once the serial data arrives, you never bother to read it. Why not.
The if statement is not going to wait for serial data to arrive.
