Topic: Trying to sweep a servo 10 times but my loop isn't working? (Read 383 times) previous topic - next topic
WhosAGoodBoy
I'm trying to sweep it from 20-120 degrees 10 times but it just keeps running indefinitely. Can anyone help me out?
#include <Servo.h>
Servo myservo;
int pos = 0;
byte i;
void setup(){
  myservo.attach(8);
void loop(){
  for (byte i; i < 11;i++){
    for (pos = 20; pos <= 120; pos += 1){
      myservo.write(pos);
      delay(15);
    for (pos = 120; pos >= 20; pos -= 1){
      myservo.write(pos);
      delay(15);
groundFungus
Can you control a servo with the smiley face pin?
If you want the for loop to happen only once, move the code that you have in loop() to setup().
Montmorency
groundFungus
Since i is declared global, it is initialized to 0 by default.   If i were declared as a local variable with no initializer it could be anything (whatever was in the assigned memory location).
evanmars
Isn't
for (byte i,
declaring a different i than the global i ?
Montmorency
It is true that the global `i` is implicitly initialized to zero.
However, the OP's `for` cycle declares and uses its own local `i`, which has no relation to the global `i` whatsoever. And that local `i' is left uninitialized.
So, once again, the `for` cycle relies on an ininitialized variable.
groundFungus
for (byte i,
Right, sorry, need more coffee.
WhosAGoodBoy
Okay so I also needed it to run only when I press enter something into the serial monitor but it's not doing anything when I give it an input. Any ideas?
#include <Servo.h>
Servo myservo;
int pos = 0;
int i = 0;
byte bytefromKbd;
void setup(){
  myservo.attach(8);
  Serial.println("Hit a key plus the [Enter] key to execute...:");
  if(Serial.available()){
    for (i = 0; i < 11; i++){
      for(pos = 20; pos <= 120; pos += 1){
        myservo.write(pos);
        delay(15);
      for(pos = 120; pos >= 20; pos -= 1){
        myservo.write(pos);
        delay(15);
void loop(){
evanmars
Why do you still have the smiley face in your code?
Hint: read the post describing how to post your code  AKA Read this before posting a programming question ...
evanmars
PaulS
        myservo.write(pos);
        delay(15);
        myservo.write(pos);
        delay(15);
Once the serial data arrives, you never bother to read it. Why not.
The if statement is not going to wait for serial data to arrive.
