Topic: ATMEL Mega1284P evaluation board avalible (Read 184311 times) previous topic - next topic
oscarBravo
Correct, A6 & A7 added to the analog header.
Ah! Told you I might be missing something. Turns out it was the ability to count. Carry on!
CrossRoads
pito
.. do the smd parts (e.g. c2 r2) below the IC socket fit without touching the plastic socket's diagonal frame? P.
mowcius
The SMD parts do look a bit too close on that.
CrossRoads
There will be no diagonal frame, just socket strips.  I'll see if the parts can be moved in a little.
pito
.. so you are not going to use the standard dil40 machine (precision) socket?
http://www.chip-service.de/product_info.php?language=en&info=p185_DIL40%20Sockel.html
CrossRoads
No, being in the US, I was thinking more like this, comparable design, less expensive.
http://www.dipmicro.com/store/index.php?act=viewProd&productCode=HDR40X1FM
Course if one had a bare board one could populate as desired. Take a frame and cut the middle span for example.
I like the look of these, just gets kind of pricey to use 40 - becomes a $6 socket!
http://www.dipmicro.com/store/0552-2-15-01-11-27-10-0
CrossRoads
Pito,
I think you recommende a cap on the 32K crystal  - any value recommened there?
http://datasheets.maxim-ic.com/en/ds/DS1307.pdf
CrossRoads
Crap. Just discovered that the 20mm battery holder (CR2032) I used from the Sparkfun library is not actually carried by Sparkfun.
Anyone seen either of these in the Eagle Library?
http://www.dipmicro.com/store/BH120591-1
http://www.dipmicro.com/store/BH2025
Thanks
Robert
mowcius
Those machined headers will probably do fine for the chip although I have never seen them used that way before
EDIT: Just tested on one, seems to work quite well actually.
Quote
Sounds like a job for EAGLE part making :D
I'll take a look through the libraries I have later and see if anything matches up but it would almost be faster to make a part.
CrossRoads
Well, faster for someone more experienced than me!  I kind of bumble along, having only done 1 so far. Learned a lot about eagle doing it, but by no means was it a speedy process.
I use the machine header strips all the time.  A large # of what I have built so far has used those as a socket for a Promini's, with pins installed in the promini. Dipmicro has the too.
mmcp42
#191
Jun 06, 2011, 08:50 pm Last Edit: Jun 07, 2011, 08:20 am by mmcp42 Reason: 1
here's one I prepared earlier
if you want any mods just let me know
but it does seem to match the data sheet I found (TYCO 120591-1)
LINK REMOVED AS THE LIBRARY WAS INCORRECT
see post #203 for library Mk II
added link to data sheet
there are only 10 types of people
them that understands binary
and them that doesn't
skyjumper
MMCP42, what's the part number for that? I was just about to place an order from Digikey and I can grab one of those for Crossroads to play with.
mowcius
Well it's two pads either 20 or 26.92mm apart for the ones CrossRoads posted... I wouldn't bother with an actual part atm :D
mmcp42
it's the tyco 120591-1
120591-1
