Topic: ATMEL Mega1284P evaluation board avalible (Read 191980 times) previous topic - next topic
pito
RTC - I am using pcf8563T (smd), 5xcheeper than the ds1307, and only needs 200nA current (you need two additional diodes for the pcf)
Battery -  I've moved to 12mm diameter cell recently (cr1220), there are nice sockets available, it will last _many_ years as well.. No need for such giant hockey puck :)
graynomad
#76
May 17, 2011, 06:05 pm Last Edit: May 17, 2011, 06:08 pm by Graynomad Reason: 1
Quote
How do I get the battery markings on the bottom of the board?
Don't know, I don't use Eagle for anything but viewing other people's files.
Quote
"Are the mounting holes at good spacing, .1" preferably but at least whole mm."
Not sure what you are asking here.
Just that the distances between mounting shouldn't be something like 57.356mm that's hard to measure with you come to mounting it in a box.
Quote
"SQW signal going to an interrupt pin so you can create a version of millis() that doesn't skip a beat or have the RTC wake the processor at 3AM. "
I think I can do that - does it need to a hardware interrupt like INT2 on pin PB2, or can it be a PCINT like PD7?
Either way, I would probably save the INTs and use a PCI, but INT2 would be a bit easier to use from the software point of view and it's "spare" according to the Arduino or do the 1284 core files handle attachInterrupt(2,xx).
Quote
"3.3V regulator & cap"
The MCP1700T is good, @ 250mA it will handle the power I would think, what power do the SD cards draw? The SOT23 has a tempco of up to 336 C/W and the the SOT89 only 52 C/W. So the SOT23 can only handle about 1/3W at room temp (depending on how much copper it has around it).
Quote
is any one familiar with this Pericom part:  PT7C4311WEX
Not me,it looks similar to the 1307 but I don't see any benefit to using it. The RX-8025 mentioned before looks nice and I do like the built-in TCXO, but if you went that route I'd go with the DS3231 chip. There are libraries for the common chips, probably not for the others, so unless there's a really neat feature not available on the 1307/3231 I'd stick with them.
Quote
One of those chips is extremely fine pitch.
I use a hot air gun to solder these (the FTDI is the finest I've done so far), easy, just run two beads of paste along the pads and hit it with the hot air. Clean any bridges with solder wick.
______
Rob
Rob Gray aka the GRAYnomad www.robgray.com
pito
#77
May 17, 2011, 06:14 pm Last Edit: May 17, 2011, 06:16 pm by pito Reason: 1
.. the 1284p is a low power device with <<1uA power save and power down.. Did you think on switching off the various chips on the board when they are not accessed? E.g. via a transistor in their Vcc.. Otherwise they can take ~mAmps.. A green board design.. :)
PS: the pcf8563 driver (based on the ds1307) does exist..
mowcius
Quote
If you flip the battery holder then it should go to the bottom of the board (either flip tool or middle button/scroll wheel when moving the part)
Quote
Quote
I have soldered 2 DS3231s with a 2mm chisel tip soldering iron (no extra flux) as well 16 dual colour 0805 LEDs and those tiny SMD 0.1uF caps and some other stuff - just takes practice. I did lose a capacitor in my solder when I got distracted though :D
Oh - smallest I've done are some of those SMD resistor networks with 8 resistors in each in a package about 3mm long.
Quote
Hmm. Interesting idea but I don't really have any knowledge of low power stuff so have no idea :D
pito
..and what is interesting for a low power design is the system can measure its battery voltage in the way it will not consume much energy. So you need an op-amp (sourced from i/o pin or switched on/off when required) with fet intputs, and a high impedance voltage divider (not to discharge the battery too much). I am using MAX1724 3V3 stepup (great chip -sot23-5)and my system is powered from one nimh cell.. From time to time it measures the battery voltage.. The 1.2V cell is charged from a sollar cell.. It works from 0.6V (it shall work from 0.8V input voltage according to the datasheet)..
P.
retrolefty
P.
If the processor is being powered directly from the battery voltage, there is a way to directly read the Vcc voltage of the processor without any external components. It's done by selecting the internal bandgap voltage as a analog input measurement (not as a reference) and calculating what the Vcc actual is. Here is a link to the topic as Coding Badly and I were playing with the function. http://www.arduino.cc/cgi-bin/yabb2/YaBB.pl?num=1294478456/8
However as you are using a step-up regulator that would not apply as the vcc should be constant until battery exhaustion.
Lefty
tastewar
re: RTC, I imagine you'd want to pick something for which there's already library support...
pito
#82
May 17, 2011, 07:40 pm Last Edit: May 17, 2011, 08:40 pm by pito Reason: 1
@lefty: yea, it is understood we measure the battery voltage.. to know the battery is low.. Btw, I've seen an application note at Maxim (an opamp) for current measurement (one op-amp, one pnp trans, 4 resistors - it is an simple i/u converter and it measures the current flowing from the positive vcc rail somewhere). So when using a dual opamp we can measure both and provide a kind of "power management". E.g. you can measure the current consumption of some external devices.. And switch them off when battery is close to die (you will decrease the current, based on its capacity, by switching off/on the shields with lower priority such the battery will last until the mission is accomplished..). Useful when you plan to land on the Mars (Arduino Guidance Computer)  :smiley-mr-green:
PS: see the
http://datasheets.maxim-ic.com/en/ds/MAX4240-MAX4244.pdf
fig.11.
CrossRoads
Okay, I'm calling it done electrically.  Gonna work on cleaning up component names next, check availability of all parts, from sparkfun or elsewhere.
Found a little 32K crystal for the RTC. Sticking with the DS1307 as it seems well known. Brought the square wave to the middle of 3 header pins, other 2 go to INT2 and PD7, select your interrupt choice.  May change it to much less expensive part (85 cents vs $3.72) if I can find a datasheet.
http://search.digikey.com/scripts/DkSearch/dksus.dll?Detail&name=PT7C4311WEXCT-ND
Hmm, maybe not - not much flexibility on the square wave out:
http://www.pti-ic.com/new/manage/doc_datasheet/PT0322%20%20%20%20%20PT7C4311.pdf
512 Hz only
vs
http://datasheets.maxim-ic.com/en/ds/DS1307.pdf
1 Hz/4K/8K/32K Hz
Not doing any more with low power operation, wasn't my goal for this board. Figured this to be an actively powered device with the 2 interfaces  and the SD card going for whatever reason.
Got the battery socket on the bottom of the board, away from any thru hole interference.
Made sure the mounting  holes were on 0.10" spacings.
Any Eagle experts out there? I need someone to confirm the pads are correct for the 2 regulators. They look odd to me.
PM me with address, I'll send the eagle file.
Thanks
Robert
mowcius
#84
May 18, 2011, 10:09 am Last Edit: May 18, 2011, 10:11 am by mowcius Reason: 1
Eugh, am I allowed to say that routing's ugly?
And those power tracks are a bit thin. No ground plane?
What do you think looks odd with the regulators?
Quote
Yeah this confused me for a bit last week - I've modified some scales which took 2 CR2032 batteries and ate them. It would tell you it was going flat at about 4V so I stuck in 2 AAs and a 5V boost converter. Then it stopped working after a while as the batteries were half flat but it hadn't told me it was going flat as the voltage was still ~5V, the boost converter just couldn't supply enough current so the scales simply died.
48X24X48X
You might want to move all tracks underneath the crystal elsewhere and provide proper guard ring.
The analog lines you might want less overlapping with the digital ones. I guess all the tracks (even signal can be thicker).
mowcius
That was also some pretty quick routing. Autorouter or by hand? Looks a bit too random to be done by hand.
pito
#87
May 18, 2011, 10:13 pm Last Edit: May 18, 2011, 10:51 pm by pito Reason: 1
1. there is a part colliding with the pinheader above the rtc
2. no tuning capacitor? (at least a single cap placeholder at X1 input against gnd), few pF makes few seconds a day from my experience when not having special resonator (and usualy resonators run faster so needs to be slowed down, at least mines)
3. the 32khz resonator shall not be placed vertically but it has to be placed horizontally with a solder point for its case (gnd?)
4. do pour the both sides with GNDplane (eagle "polygon GND" or "polygon gnd"), this may help with autorouting and ground noise significantly
5. did you consider smaller diameter coin cell? (maxim says 48mAh coin lasts for 10y ->CR1220)
6. sometimes helped me to place a few cents TL431 (+ 1 resistor in anode, anode+gate shorted) as an external 2.5V ref source (maybe better than atmega's internal one)
7. do we need those big alu caps there - the 10-20uF ceramics usualy works better, are cheap and are 1206 or 0805.
CrossRoads
#88
May 19, 2011, 07:45 am Last Edit: May 19, 2011, 07:47 am by CrossRoads Reason: 1
Ok, the board was autorouted with lots of parts placement manipulation to make traces as short a possible.
Here's a blowup of the pads. I figured the top & bottom would be 2 solid planes connected by vias. Yet the tops got split up funny.
I make the ground traces thicker manually, they seem to revert to thinner every time I rip them up and let them play out again as I move parts around.
After the routing was done I tried adding polygon to make a ground plane.
>> What makes  the ground plane actually connect to ground?
>> The ground plane also made a couple of signals become disconnected. Not sure its doing much for me.
Is there a better way to add that?
@pito,
1. There is no conflict - the battery holder is on the bottom of the board.  All conflicts except for "stop mask" errors were taken care of, I will be cleaning up the Reference Designators next.
2. X1 on the DS1307?
3. 32K crystal has been layed over.  Traces have been cleared away.
4. Am trying that again, see if it helps.
5. Went with a coin cell that I could easily find a holder for.
6. I don't know why Arduino original design had Aref located diaganolly opposite on the board from the Analog inputs.  Ihave rerouted the Aref signal away from the power supply section.
7. Will review the 'big' electrolytics.
CrossRoads
I'm trying to add the top & bottom layer hatch planes. I drew out the rectangles, renamed then Gnd, ripped up all traces and let the autorouter go - is ~97.7% done afeter Optimize 1. Having the 2 ground planes isn't helping the routing as much a I thought it would.
