Topic: ATMEL Mega1284P evaluation board avalible (Read 191158 times) previous topic - next topic
CrossRoads
Great, so its all done finally, leaving me unrouted lines to clean up - all Grounds! Go figure.
mowcius
Quote
Shouldn't take too long.
Once you're done I'd have a manual tidy up of tracks (I'll have a play around with them if you want).
pito
#92
May 19, 2011, 04:30 pm Last Edit: May 19, 2011, 04:57 pm by pito Reason: 1
@Xroads: you have to simply write into eagle's command line:
polygon Gnd (or GND or gnd - depends on the signal name)
and it will assign the name to the polygon you intend to draw after..
BTW -you may place the crystal underneath the 1284p (see the dil40 machine pin socket there are such "windows"), I did it with dil28 narrow socket as well - Unless you plan to change the crystal too often it saves a lot of space. As the heights is concerned it fits nice..
mowcius
Quote
BTW -you may place the crystal beneath the 1284p (see the dil40 machine pin socket there are such "windows"), I did it with dil28 narrow socket as well - Unless you plan to change the crystal too often it saves a lot of space. As the heights is concerned it fits nice..
Yeah I was going to suggest parts under the 1284 but I was struggling to think of anything that could go under it - I'd completely forgotten the crystal!
pito
#94
May 19, 2011, 05:01 pm Last Edit: May 19, 2011, 05:05 pm by pito Reason: 1
IC1 is also a good candidate to be put underneath the 1284p..
Btw, is the package of the IC1 really so wide??
mowcius
You'd struggle to fit it under as it really is that wide - I think the plastic socket would hit it and that would make routing much harder without any real advantages.
CrossRoads
Yes, the MAX232 driver chip selected is that wide. It would fit under the 1284 if the pins were laid perpindular to the DIP's pins, which would probabaly be good for the capacitors also. However I think routing of the signals in/out of the part then seriously get in the way of the 1284 signals on a 2 layer board.  If I think about it tonight, I'll rip the traces up & try it.
The decoupling caps and crystal caps and Reset R/C parts would then have to move out from under the 1284 (or go on the bottom of the board? Hadn't considered that possibility.)
The MAX3232 also comes in a 16TSSOP package which the FTDI part type pin spacing. I went for the bigger hand-solderable size.
The 16MHz crystal won't fit, is too tall.
@mowcius,
"Shouldn't take too long.
Once you're done I'd have a manual tidy up of tracks (I'll have a play around with them if you want)."
Its gonna be hard - there are so many signals, I did not see any readily available spaces to run a trace and vias to get them connected to ground somewhere, and I have hatching on the top & bottom layer.  The pads that need to be connected are on their own little ground islands.  I think I will have to  move things a little and try again, should resolve 2 of the capacitor ground issues, getting ground to IC7 a little trickier now that the crystal caps are under the 1284.
I find it very hard to follow the traces after the hatching goes in.
I suppose I could have it do the routing with no hatching, strip out the grounds, clean up by hand, then let it try & put the hatching in again. Likely just leave me with unconnected grounds again.
Or just route it all by hand, just takes longer and results in more Design Rule checks to clean up as I tend to get things a little too close without realizing it (they look far enough apart when zoomed in!)
What gets me is the clearance errors that need cleaning up after the routing is done, and the Width & Dimension errors. from the libray parts! Specifically the fiduciarys, some interference between SD socket ground pad and hole in the lower right side, and vias that get placed too close to stuff.
mowcius
Quote
Why are you hatching it then? Or just so it looks pretty...
CrossRoads
Got it to work finally. Still had to make a few ground connections by hand, kinda like showing the program where to put a via or two so it could make the final connections. Moved a couple of caps slightly, moved a few traces so the ground planes could cover a little more area. Bit of an iterative process - tweak a trace or two, let the polygon refill. Move a part a scooch, let the polygon refill. Overall coverage between the 2 layers is good, got some voids in the bottom layer where the runs spanning long stretches don't give the polygon any access.
Think I can add a via in the middle of the top layer and have it carry over to the bottom to get the voids filled?
Looking at parts for availability next - checking the SD socket to see if make can go in (digikey carries several, the mechanical drawings are not the easiest to interpret) or if the Sparkfun library part is unique.
CrossRoads
#99
May 20, 2011, 09:50 am Last Edit: May 20, 2011, 09:57 am by CrossRoads Reason: 1
When Eagle complains about "Clearance" errors around the regulator thermal pad, do I need to resolve that or can I ignore it as the top & bottom layers are intentionally connected together with vias?
I'm thinking this needs  more work - looking closer, the top layer has a small pad in the middle that is isolated with an outer pad that is connectet to the ground hatching.
The bottom pad is VCC, but is also connected to the bottom layer ground hatching.
I need some way to isolate the regulator thermal pad.
pito
#100
May 20, 2011, 10:03 am Last Edit: May 20, 2011, 10:06 am by pito Reason: 1
if you shoot manually vias through you have to name each via according to the signal - in the thermal pad case "GND".
You are missing the vias in thermal pad for the second voltage regulator..
The low profile crystal package fits under the chip..
Do use solid ground plane..
Generally : design rules - it depends on your pcb provider, most of them are checking them before the fab starts (and they shall provide you with their design rules definition, drill set definition etc..) and when they see an error they will not fab the pcb or they will charge additional fees.. :0
P.
mowcius
Yeah, use a solid ground plane (or an almost solid ground plane if you absolutely have to stick silly hatching on it) and that routing's still ugly :D
What fab house are you thinking of using, go look if they provide design rules files - some do so you can easily check it yourself.
...and if the tracks are ground, you don't have to route them, rip them up and they will then just connect to the ground plane.
CrossRoads
Ok, now that I've the hatched polygon figured out,  I can try solid planes. I will check out naming the pads/vias as well.
I had vias in both thermal pads, will check & see what happened to them. I might have just turned viewing them off when I did the screen captures.
There were a few pins that couldn't connect to the ground hatching because there were too many signal runs in the area. I had to run a trace by hand, adding vias to bring the signal under the part and back up to where there was a ground signal to hook up to. Just a little too complex for the autorouter.
I think part of the reason for the ugliness is the shield footprint. The placement of some signals is just poor, and the size of the 1284 means you can't cram everything all in the same spot.
Skyjumper just had some similar boards made (little bigger more connectors), the bare PCBs look good, I think I'll follow his lead as  he's nearby (Boston area also) and they were made & returned pretty quick.
mowcius
Quote
Nahh it's just the tracks going at funny angles.
CrossRoads
Ah, the angles - thats all part of the shortest distance routing going on. The 40 pin DIP really stretches some of the signals out.
