Topic: Error message: Trying to connect 16 x 2 lcd to arduino nano (Read 662 times) previous topic - next topic
melsheik
I followed the instructions in this: https://eldontronics.wordpress.com/2018/02/11/lcd-module-connection-to-arduino-board-with-without-an-i2c-module/
and followed the "Direct connection" section and I'm just trying to display  "HelloWord" using the example under the liquidcrystal library
I'm getting this error message:
Arduino: 1.8.9 (Windows Store 1.8.21.0) (Windows 10), Board: "Arduino Nano, ATmega328P"
WARNING: Category 'Display, Hangul' in library LiquidCrystal_I2C_Hangul is not valid. Setting to 'Uncategorized'
Sketch uses 1902 bytes (6%) of program storage space. Maximum is 30720 bytes.
Global variables use 59 bytes (2%) of dynamic memory, leaving 1989 bytes for local variables. Maximum is 2048 bytes.
An error occurred while uploading the sketch
option enabled in File -> Preferences.
sterretje
Genuine Arduino bought in 2018 or later? Or Older genuine Arduino or clone?
For the latter, select tools -> processor -> 328P (old bootloader). If that does not help, please enable verbose output during upload in file -> preferences and copy the output in a new reply.
If you understand an example, use it.
If you don't understand an example, don't use it.
Electronics engineer by trade, software engineer by profession. Trying to get back into electronics after 15 years absence.
melsheik
Hey, thanks for the reply!
It's a clone. I tried using ATmega328P (Old Bootloader) but that also displayed the following
error message:
Arduino: 1.8.9 (Windows Store 1.8.21.0) (Windows 10), Board: "Arduino Nano, ATmega328P (Old Bootloader)"
C:\Program Files\WindowsApps\ArduinoLLC.ArduinoIDE_1.8.21.0_x86__mdqgnx93n4wtt\hardware\tools\avr/bin/avrdude -CC:\Program Files\WindowsApps\ArduinoLLC.ArduinoIDE_1.8.21.0_x86__mdqgnx93n4wtt\hardware\tools\avr/etc/avrdude.conf -v -patmega328p -carduino -PCOM3 -b57600 -D -Uflash:w:C:\Users\ME489D~1\AppData\Local\Temp\arduino_build_57905/HelloWorld.ino.hex:i
avrdude: Version 6.3-20171130
         Copyright (c) 2007-2014 Joerg Wunsch
         System wide configuration file is "C:\Program Files\WindowsApps\ArduinoLLC.ArduinoIDE_1.8.21.0_x86__mdqgnx93n4wtt\hardware\tools\avr/etc/avrdude.conf"
         Using Port                          : COM3
         Using Programmer              : arduino
         Overriding Baud Rate          : 57600
sterretje
OK, that does not tell too much. Usually it gives a hint about what is wrong.
Next step is to get rid of the windows store version and install the normal IDE (current version 1.8.9) from https://www.arduino.cc/download_handler.php?f=/arduino-1.8.9-windows.exe.
The windows store version can exhibit strange behaviour and this might be part of it.
Question: is COM3 indeed the port that shows up in device manager when you connect the board to the PC?
DrAzzy
I think ive seen other reports of this behavior with windows store version...
ATTinyCore for x4/x5/x61/x7/x8/x41/1634/828/x313 megaTinyCore for the megaavr ATtinies - Board Manager:
http://drazzy.com/package_drazzy.com_index.json
ATtiny breakouts, mosfets, awesome prototyping board in my store http://tindie.com/stores/DrAzzy
melsheik
Yeah I got it working now when I changed the port from COM3 to COM8 which was the one that had the USB. Thanks for the help!
