Topic: GBF( générateur de basse fréquence) with ARDUINO PWM problem frequency (Read 605 times) previous topic - next topic
rahma94
Hey have a Good Day! :)  :)
I am working on a project of a frequency probe and I need to create a GBF goes from ]0-10KHz]
I am using an Arduino Uno board to generate a PWM to get frequency.
I'am using Potentiometr to change the frequency on A0 pin of my ARDUINO baord .
I need help to fix my Program to provide at least from 1 HZ to 11khz frequency of pwm.
my out put is on pin 9.
this is my program:
#include "Arduino.h"
#define NECHANT 128
#define SHIFT_ACCUM 25
uint32_t icr;
uint32_t table_onde[NECHANT];
uint32_t accum1,accum2,accum3,increm;
//uint16_t diviseur[6] = {0,1,8,64,256,1024};
uint16_t diviseur[1] = {8};
void init_pwm_timer1(uint32_t period) {
    char clockBits;
    TCCR1A = 0;
    TCCR1A |= (1 << COM1A1); //Clear OC1A on compare match when upcounting, set OC1A on compare match when downcounting
    TCCR1A |= (1 << COM1B1);
#if defined(__AVR_ATmega2560__) || defined(__AVR_ATmega32U4__)
    TCCR1A |= (1 << COM1C1);
#endif
    TCCR1B = 1 << WGM13; // phase and frequency correct pwm mode, top = ICR1
    int d = 1;
    icr = (F_CPU/1000000*period/2);
    while ((icr>0xFFFF)&&(d<6)) { // choix du diviseur d'horloge
        d++;
        icr = (F_CPU/1000000*period/2/diviseur[d]);
   clockBits = d;
   ICR1 = icr; // valeur maximale du compteur
   TIMSK1 = 1 << TOIE1; // overflow interrupt enable
   sei(); // activation des interruptions
   TCNT1 = 0; // mise à zéro du compteur
   TCCR1B |= clockBits; // déclenchement du compteur
ISR(TIMER1_OVF_vect) { // Timer 1 Overflow interrupt
  accum1 += increm;
  accum2 += increm;
  accum3 += increm;
  OCR1C = table_onde[accum3 >> SHIFT_ACCUM];
#endif
  OCR1A = table_onde[accum1 >> SHIFT_ACCUM];
  OCR1B = table_onde[accum2 >> SHIFT_ACCUM];
void set_sinus_table(float amp) {
  int i;
  float dt = 2*3.1415926/NECHANT;
  for(i=0; i<NECHANT; i++) {
    table_onde = icr*0.5*(1.0+amp*sin(i*dt));
     int p;
    pinMode(9,OUTPUT);
    pinMode(A0,INPUT);
Serial.begin(19200);
//    uint32_t period_pwm = 100; // en microsecondes
//    uint32_t frequence = 50; // en Hz
//    accum1 = 0;
//    accum2 = ((uint32_t)(NECHANT * 0.25)) << SHIFT_ACCUM;
//    accum3 = 0;
//    increm = (uint32_t) (((float)(0xFFFFFFFF))*((float)(frequence)*1e-6*(float)(period_pwm))); // incrément de l'accumulateur de phase
//    init_pwm_timer1(period_pwm);
//    set_sinus_table(1.0);
    p=analogRead(A0);
p=map(p,0,1023,0,255);
Serial.println(p);
analogWrite(9,p);
    uint32_t period_pwm = 1.5*p; // en microsecondes
    uint32_t frequence = 40*p; // en Hz
    accum1 = 0;
    accum3 = 0;
al1fch
Bonjour
Forum francophone : on s'exprime ici en Français
Bien lire la Regle du Forum, entre autres l'endroit où poster les questions, ainsi que la manière de publier le code
tel quel ce message a le profil idéal pour finir dans la poubelle du BAR pour non respect de plusieurs règles
Corriges ce message et demandes au modérateur (lien report to moderator) le déplacement du message a l'endroit prévu pour les demandes d'aides (il n'a rien à faire avec les Réalisations FINIES et projets FINIS)
J-M-L
Hello - Please do not PM me for help,  others will benefit as well if you post your question publicly on the forums.
Bonjour Pas de messages privés SVP, postez dans le forum directement pour que ça profite à tous
rahma94
Je n'ai pas trouvé comment supprimer ce post!!!!
C'est très claire que je suis nouvelle ici alors quand vous me dirige comment faire  sa sera mieux que agrandir le nombre de réponse de ce post pour rien !!!!!!
@J-M-L j'ai fait le 2 ème post parce que j'ai compris que ici ce n'ai pas le bon endroit
et comme j'ai déjà indiqué au dessus "Je n'ai pas trouvé comment supprimer ce post"
je vous remercie aussi parce que vous prenez votre temps pour compter mes post et où j'ai les met :D
J-M-L
