Ah, ok. I thought that would give me the verbose logging. Instead, I just turned it on. Here is the output:
Arduino: 1.8.9 (Windows 10), Board: "Arduino/Genuino Uno"
C:\Program Files (x86)\Arduino\arduino-builder -dump-prefs -logger=machine -hardware C:\Program Files (x86)\Arduino\hardware -tools C:\Program Files (x86)\Arduino\tools-builder -tools C:\Program Files (x86)\Arduino\hardware\tools\avr -built-in-libraries C:\Program Files (x86)\Arduino\libraries -libraries C:\Users\aabrams\Documents\Arduino\libraries -fqbn=arduino:avr:uno -vid-pid=0X2341_0X0010 -ide-version=10809 -build-path C:\Users\aabrams\AppData\Local\Temp\arduino_build_894567 -warnings=none -build-cache C:\Users\aabrams\AppData\Local\Temp\arduino_cache_23908 -prefs=build.warn_data_percentage=75 -prefs=runtime.tools.avr-gcc.path=C:\Program Files (x86)\Arduino\hardware\tools\avr -prefs=runtime.tools.avr-gcc-5.4.0-atmel3.6.1-arduino2.path=C:\Program Files (x86)\Arduino\hardware\tools\avr -prefs=runtime.tools.avrdude.path=C:\Program Files (x86)\Arduino\hardware\tools\avr -prefs=runtime.tools.avrdude-6.3.0-arduino14.path=C:\Program Files (x86)\Arduino\hardware\tools\avr -prefs=runtime.tools.arduinoOTA.path=C:\Program Files (x86)\Arduino\hardware\tools\avr -prefs=runtime.tools.arduinoOTA-1.2.1.path=C:\Program Files (x86)\Arduino\hardware\tools\avr -verbose E:\Arduino\BlinkLED\BlinkLED.ino
C:\Program Files (x86)\Arduino\arduino-builder -compile -logger=machine -hardware C:\Program Files (x86)\Arduino\hardware -tools C:\Program Files (x86)\Arduino\tools-builder -tools C:\Program Files (x86)\Arduino\hardware\tools\avr -built-in-libraries C:\Program Files (x86)\Arduino\libraries -libraries C:\Users\aabrams\Documents\Arduino\libraries -fqbn=arduino:avr:uno -vid-pid=0X2341_0X0010 -ide-version=10809 -build-path C:\Users\aabrams\AppData\Local\Temp\arduino_build_894567 -warnings=none -build-cache C:\Users\aabrams\AppData\Local\Temp\arduino_cache_23908 -prefs=build.warn_data_percentage=75 -prefs=runtime.tools.avr-gcc.path=C:\Program Files (x86)\Arduino\hardware\tools\avr -prefs=runtime.tools.avr-gcc-5.4.0-atmel3.6.1-arduino2.path=C:\Program Files (x86)\Arduino\hardware\tools\avr -prefs=runtime.tools.avrdude.path=C:\Program Files (x86)\Arduino\hardware\tools\avr -prefs=runtime.tools.avrdude-6.3.0-arduino14.path=C:\Program Files (x86)\Arduino\hardware\tools\avr -prefs=runtime.tools.arduinoOTA.path=C:\Program Files (x86)\Arduino\hardware\tools\avr -prefs=runtime.tools.arduinoOTA-1.2.1.path=C:\Program Files (x86)\Arduino\hardware\tools\avr -verbose E:\Arduino\BlinkLED\BlinkLED.ino
Using board 'uno' from platform in folder: C:\Program Files (x86)\Arduino\hardware\arduino\avr
Using core 'arduino' from platform in folder: C:\Program Files (x86)\Arduino\hardware\arduino\avr
Detecting libraries used...
"C:\\Program Files (x86)\\Arduino\\hardware\\tools\\avr/bin/avr-g++" -c -g -Os -w -std=gnu++11 -fpermissive -fno-exceptions -ffunction-sections -fdata-sections -fno-threadsafe-statics -Wno-error=narrowing -flto -w -x c++ -E -CC -mmcu=atmega328p -DF_CPU=16000000L -DARDUINO=10809 -DARDUINO_AVR_UNO -DARDUINO_ARCH_AVR "-IC:\\Program Files (x86)\\Arduino\\hardware\\arduino\\avr\\cores\\arduino" "-IC:\\Program Files (x86)\\Arduino\\hardware\\arduino\\avr\\variants\\standard" "C:\\Users\\aabrams\\AppData\\Local\\Temp\\arduino_build_894567\\sketch\\BlinkLED.ino.cpp" -o nul
Generating function prototypes...
"C:\\Program Files (x86)\\Arduino\\hardware\\tools\\avr/bin/avr-g++" -c -g -Os -w -std=gnu++11 -fpermissive -fno-exceptions -ffunction-sections -fdata-sections -fno-threadsafe-statics -Wno-error=narrowing -flto -w -x c++ -E -CC -mmcu=atmega328p -DF_CPU=16000000L -DARDUINO=10809 -DARDUINO_AVR_UNO -DARDUINO_ARCH_AVR "-IC:\\Program Files (x86)\\Arduino\\hardware\\arduino\\avr\\cores\\arduino" "-IC:\\Program Files (x86)\\Arduino\\hardware\\arduino\\avr\\variants\\standard" "C:\\Users\\aabrams\\AppData\\Local\\Temp\\arduino_build_894567\\sketch\\BlinkLED.ino.cpp" -o "C:\\Users\\aabrams\\AppData\\Local\\Temp\\arduino_build_894567\\preproc\\ctags_target_for_gcc_minus_e.cpp"
"C:\\Program Files (x86)\\Arduino\\tools-builder\\ctags\\5.8-arduino11/ctags" -u --language-force=c++ -f - --c++-kinds=svpf --fields=KSTtzns --line-directives "C:\\Users\\aabrams\\AppData\\Local\\Temp\\arduino_build_894567\\preproc\\ctags_target_for_gcc_minus_e.cpp"
Compiling sketch...
"C:\\Program Files (x86)\\Arduino\\hardware\\tools\\avr/bin/avr-g++" -c -g -Os -w -std=gnu++11 -fpermissive -fno-exceptions -ffunction-sections -fdata-sections -fno-threadsafe-statics -Wno-error=narrowing -MMD -flto -mmcu=atmega328p -DF_CPU=16000000L -DARDUINO=10809 -DARDUINO_AVR_UNO -DARDUINO_ARCH_AVR "-IC:\\Program Files (x86)\\Arduino\\hardware\\arduino\\avr\\cores\\arduino" "-IC:\\Program Files (x86)\\Arduino\\hardware\\arduino\\avr\\variants\\standard" "C:\\Users\\aabrams\\AppData\\Local\\Temp\\arduino_build_894567\\sketch\\BlinkLED.ino.cpp" -o "C:\\Users\\aabrams\\AppData\\Local\\Temp\\arduino_build_894567\\sketch\\BlinkLED.ino.cpp.o"
Compiling libraries...
Compiling core...
Using precompiled core: C:\Users\aabrams\AppData\Local\Temp\arduino_cache_23908\core\core_arduino_avr_uno_0c812875ac70eb4a9b385d8fb077f54c.a
Linking everything together...
"C:\\Program Files (x86)\\Arduino\\hardware\\tools\\avr/bin/avr-gcc" -w -Os -g -flto -fuse-linker-plugin -Wl,--gc-sections -mmcu=atmega328p -o "C:\\Users\\aabrams\\AppData\\Local\\Temp\\arduino_build_894567/BlinkLED.ino.elf" "C:\\Users\\aabrams\\AppData\\Local\\Temp\\arduino_build_894567\\sketch\\BlinkLED.ino.cpp.o" "C:\\Users\\aabrams\\AppData\\Local\\Temp\\arduino_build_894567/..\\arduino_cache_23908\\core\\core_arduino_avr_uno_0c812875ac70eb4a9b385d8fb077f54c.a" "-LC:\\Users\\aabrams\\AppData\\Local\\Temp\\arduino_build_894567" -lm
"C:\\Program Files (x86)\\Arduino\\hardware\\tools\\avr/bin/avr-objcopy" -O ihex -j .eeprom --set-section-flags=.eeprom=alloc,load --no-change-warnings --change-section-lma .eeprom=0 "C:\\Users\\aabrams\\AppData\\Local\\Temp\\arduino_build_894567/BlinkLED.ino.elf" "C:\\Users\\aabrams\\AppData\\Local\\Temp\\arduino_build_894567/BlinkLED.ino.eep"
"C:\\Program Files (x86)\\Arduino\\hardware\\tools\\avr/bin/avr-objcopy" -O ihex -R .eeprom "C:\\Users\\aabrams\\AppData\\Local\\Temp\\arduino_build_894567/BlinkLED.ino.elf" "C:\\Users\\aabrams\\AppData\\Local\\Temp\\arduino_build_894567/BlinkLED.ino.hex"
"C:\\Program Files (x86)\\Arduino\\hardware\\tools\\avr/bin/avr-size" -A "C:\\Users\\aabrams\\AppData\\Local\\Temp\\arduino_build_894567/BlinkLED.ino.elf"
Sketch uses 1450 bytes (4%) of program storage space. Maximum is 32256 bytes.
Global variables use 15 bytes (0%) of dynamic memory, leaving 2033 bytes for local variables. Maximum is 2048 bytes.
C:\Program Files (x86)\Arduino\hardware\tools\avr/bin/avrdude -CC:\Program Files (x86)\Arduino\hardware\tools\avr/etc/avrdude.conf -v -patmega328p -carduino -PCOM6 -b115200 -D -Uflash:w:C:\Users\aabrams\AppData\Local\Temp\arduino_build_894567/BlinkLED.ino.hex:i
avrdude: Version 6.3-20171130
Copyright (c) 2000-2005 Brian Dean,
http://www.bdmicro.com/ Copyright (c) 2007-2014 Joerg Wunsch
System wide configuration file is "C:\Program Files (x86)\Arduino\hardware\tools\avr/etc/avrdude.conf"
Using Port : COM6
Using Programmer : arduino
Overriding Baud Rate : 115200
avrdude: stk500_getsync() attempt 1 of 10: not in sync: resp=0xce
avrdude: stk500_getsync() attempt 2 of 10: not in sync: resp=0xce
avrdude: stk500_getsync() attempt 3 of 10: not in sync: resp=0xce
avrdude: stk500_getsync() attempt 4 of 10: not in sync: resp=0xce
avrdude: stk500_getsync() attempt 5 of 10: not in sync: resp=0xce
avrdude: stk500_getsync() attempt 6 of 10: not in sync: resp=0xce
avrdude: stk500_getsync() attempt 7 of 10: not in sync: resp=0xce
avrdude: stk500_getsync() attempt 8 of 10: not in sync: resp=0xce
avrdude: stk500_getsync() attempt 9 of 10: not in sync: resp=0xce
avrdude: stk500_getsync() attempt 10 of 10: not in sync: resp=0xce
avrdude done. Thank you.
Problem uploading to board. See
http://www.arduino.cc/en/Guide/Troubleshooting#upload for suggestions.
