Topic: USBasp issue (Read 476 times) previous topic - next topic
bartofborg
I am attempting to flash an ender 3 pro with a bootloader so I can update marlin.
I am using a USBasp adapter. I installed the adapter successfully using the Zadig program (libusbK (v3.0.7.0))
I added sanguino into the hardware folder successfully and selected same in Arduino, chose usbasp as programmer and ATmega1284 as processor no problem. When I plug the adapter into the computer and the enders motherboard via the isp pins the adapter and the motherboard both power up.
 Unfortunately, in Arduino, the com port is grayed out and Arduino states, when I try to upload bootloader anyway, :
Arduino: 1.8.9 (Windows 10), Board: "Sanguino, ATmega1284 or ATmega1284P (16 MHz)"
C:\Program Files (x86)\Arduino\hardware\tools\avr/bin/avrdude -CC:\Program Files (x86)\Arduino\hardware\tools\avr/etc/avrdude.conf -v -patmega1284p -cusbasp -Pusb -e -Ulock:w:0x3F:m -Uefuse:w:0xFD:m -Uhfuse:w:0xDE:m -Ulfuse:w:0xFF:m
avrdude: Version 6.3-20171130
         Copyright (c) 2007-2014 Joerg Wunsch
         System wide configuration file is "C:\Program Files (x86)\Arduino\hardware\tools\avr/etc/avrdude.conf"
         Using Port                    : usb
         Using Programmer              : usbasp
         AVR Part                      : ATmega1284P
         Chip Erase delay              : 55000 us
         PAGEL                         : PD7
         BS2                           : PA0
         RESET disposition             : dedicated
         RETRY pulse                   : SCK
         serial program mode           : yes
         parallel program mode         : yes
         Timeout                       : 200
         StabDelay                     : 100
         CmdexeDelay                   : 25
         SyncLoops                     : 32
         ByteDelay                     : 0
         PollIndex                     : 3
         PollValue                     : 0x53
         Memory Detail                 :
                                  Block Poll               Page                       Polled
           Memory Type Mode Delay Size  Indx Paged  Size   Size #Pages MinW  MaxW   ReadBack
           eeprom        65    10   128    0 no       4096    8      0  9000  9000 0xff 0xff
           flash         65    10   256    0 yes    131072  256    512  4500  4500 0xff 0xff
           lock           0     0     0    0 no          1    0      0  9000  9000 0x00 0x00
           lfuse          0     0     0    0 no          1    0      0  9000  9000 0x00 0x00
           hfuse          0     0     0    0 no          1    0      0  9000  9000 0x00 0x00
           efuse          0     0     0    0 no          1    0      0  9000  9000 0x00 0x00
           signature      0     0     0    0 no          3    0      0     0     0 0x00 0x00
           calibration    0     0     0    0 no          1    0      0     0     0 0x00 0x00
         Programmer Type : usbasp
         Description     : USBasp, http://www.fischl.de/usbasp/
avrdude: auto set sck period (because given equals null)
avrdude: warning: cannot set sck period. please check for usbasp firmware update.
avrdude: error: program enable: target doesn't answer. 1
avrdude: initialization failed, rc=-1
         Double check connections and try again, or use -F to override
         this check.
avrdude done.  Thank you.
Error while burning bootloader.
pert
That's normal. USBasp is a pure USB device. It doesn't create a COM port.
Make sure you have the USBasp cable plugged in to the ICSP header the right way around. Pin 1 should be marked somehow on the Ender's motherboard, maybe with a dot or a "1" printed on the silkscreen next to that pin. Pin 1 is marked on the USBasp cable with a triangle embossed on the plastic of the connector.
bartofborg
thank you for the quick reply, it is plugged in correctly, the mainboard would not power up if that wasn't the case. when I plug it in backwards nothing happens, correctly, mainboard lights up and window hardware ditty goes off. will not upload bootloader though, any other ideas?
bartofborg
Found the issue! ender 3 now flashed. Turned out to be a jumper on the USBasp adapter was put on the wrong pins from the factory, coming from china, it had no documentation so there was no way to tell without messing around with it.
pert
I'm glad to hear you got it working. Enjoy!
Per
