Arduino Forum
Using Arduino
General Electronics
(Moderator:
PerryBebbington
Is Less number of turns on primary side of transfomer a problem
Print
Pages:
[1]
Topic: Is Less number of turns on primary side of transfomer a problem
(Read 376 times)
previous topic
next topic
Rishi_kesh
Newbie
[add]
electronics enthusiast from a long time . I love making random digital electronics and electronics circuits and projects.
Apr 23, 2019, 09:34 am
Last Edit
: Apr 23, 2019, 09:35 am by Rishi_kesh
Hi! Im currently working on project which is pure sine wave inverter.Its based on smps design. In it im using ferrite transformer whose primary turns we found out to be 3. Since its centre tapped, transformer actual turns are 6. Transformer is to be operated at 50khz square wave. Im little doubtlfull about the primary current which will be large in this case and might cause any problems. Never worked on inverter designs before so im little doubtful. Do i need to increase the primary turns so that primary current under no load will be reduced? Inverter's power rating is 500w .
MorganS
Shannon Member
[add]
Re: Is Less number of turns on primary side of transfomer a problem
#1
Apr 23, 2019, 04:10 pm
1. How did you find out?
2. 3 turns is 3 turns. Center-tapping it can make two windings of 1.5 turns, not 6.
3. Do you know what the primary current is? That seems important to know.
4. You said nothing about the secondary. Isn't the ratio of turns the most important figure in transformer design?
5. What simulation and test equipment do you have to verify the design?
"The problem is in the code you didn't post."
Paul_KD7HB
Shannon Member
[add]
Prior work was computer software and data communications for 34 years. Then owner/President of an electronic assembly service for 20 years. Amateur radio since 1955, approximately. Live in Central Oregon desert.
#2
Apr 23, 2019, 08:14 pm
The ferrite transformer inductance will limit the primary current, IF it is of a proper mix of material, which you did not identify.
Paul
jremington
Brattain Member
[add]
Trust in Allah, but tie up your camel
#3
Apr 24, 2019, 03:52 am
Last Edit
: Apr 24, 2019, 03:52 am by jremington
Indeed, having
too few
turns would be a problem. Make sure that you have the correct number of turns.
MarkT
Brattain Member
[add]
Arduino rocks
#4
Apr 24, 2019, 04:39 am
You have neglected to provide a link to the datasheet of the ferrite core.
[ I DO NOT respond to personal messages, I WILL delete them unread, use the forum please ]
mauried
Edison Member
[add]
#5
Apr 24, 2019, 06:09 am
Sine wave inverters are exceptionally difficult devices to build and even harder to test when they dont work, as the normal response is a bucketful of blown up fets.
If this is your first project , Id stop and build something a lot simpler first.
Print
Pages:
[1]
Loading...
