Topic: besoin d'aide pour un menu, (Read 4455 times) previous topic - next topic
dbrion06
Est ce que vous pouvez definir une variable qui vaut, disons, vrai si un menu est actif, faux si on a demandé un affichage?
En plus, data ne sert à rien dans votre loop() du second mort sot.
Dams501
ma tentative de fusion des deux code
Code: [Select]
#include <LiquidCrystal.h>
LiquidCrystal lcd(12, 11, 5, 4, 3, 2);
#include <OneWire.h>
// DS18S20 Temperature chip i/o
OneWire ds(10);  // on pin 10
byte addr1[8] = {0x28, 0xAA, 0x98, 0x12, 0x3C, 0x14, 0x01, 0xD7};
byte addr2[8] = {0x28, 0xAA, 0xC1, 0x91, 0x3B, 0x14, 0x01, 0x9A};
int SignBit = 0;
int StartCol = 8;
int ventilo = 6;
int sonde = 7;
int relais = 1;
int Tmin = 20;
int Tmax= 25;
int Hmin = 20;
int Hmax = 25;
int heure = 1;
int minute = 1;
int unsigned Menu = 0;
int unsigned SousMenu = 0;
double Tempo = millis();
double Tempo2 = 0;
int test1 = 0;
int test2 = 0;
int test3 = 0;
int SELECT = A0;
int UP = A1;
int DOWN = A2;
int LEFT = A3;
int RIGHT = A4;
typedef struct {
  String Menu;
TypeMenu;
TypeMenu NumMenu[100];
void Initialisation() {
  NumMenu[10] = (TypeMenu) {
    "1. Info General "
  NumMenu[11] = (TypeMenu) {
    "Temp Nid:" +String(Tmin)
  NumMenu[12] = (TypeMenu) {
    "Temp ADC:" +String(Tmax)
  NumMenu[13] = (TypeMenu) {
    "Humidite" +String(Tmax)
  NumMenu[20] = (TypeMenu) {
    "2. Temperature"
  NumMenu[21] = (TypeMenu) {
    "Temp Min " +String(Tmin) + " c"
  NumMenu[22] = (TypeMenu) {
    "Temp Max " +String(Tmax) + " c"
  NumMenu[30] = (TypeMenu) {
    "3. Humidite"
  NumMenu[31] = (TypeMenu) {
    "Humid Min " +String(Hmin) + "%"
  NumMenu[32] = (TypeMenu) {
    "Humid Max " +String(Hmax) + "%"
  NumMenu[40] = (TypeMenu) {
    "4. Heure"
  NumMenu[41] = (TypeMenu) {
    "4.1 Reglage"
  NumMenu[42] = (TypeMenu) {
    "4.2 Reglage heure"
  pinMode(ventilo, OUTPUT);
  pinMode(sonde, OUTPUT);
  pinMode(relais, OUTPUT);
  Initialisation();
  lcd.begin(16, 2);
  lcd.clear();
  lcd.setCursor(0, 0);
  lcd.print("Temp NID:");;
  lcd.setCursor(0, 1);
  lcd.print("Temp ADC:");
  delay(2000);
  pinMode(SELECT, INPUT_PULLUP);
  pinMode(UP, INPUT_PULLUP);
  pinMode(DOWN, INPUT_PULLUP);
  pinMode(LEFT, INPUT_PULLUP);
  pinMode(RIGHT, INPUT_PULLUP);
  Sondes();
  Regul();
  humi();
  heurefunc();
  bouton();
void bouton() {
  if ( millis() > Tempo ) {
    if (digitalRead(LEFT) == LOW) { /* Bouton LEFT  */
      SousMenu++;
      Tempo = millis() + 250;
      AfficheMenu();
    } else if (digitalRead(DOWN) == LOW) { /* Bouton Down  */
      Menu = Menu - 10;
      SousMenu = 0 ;
      AfficheMenu();
    } else if (digitalRead(UP) == LOW) { /* Bouton Up */
      Menu = Menu + 10;
      SousMenu = 0;
      AfficheMenu();
    } else if (digitalRead(RIGHT) == LOW) { /* Bouton RIGHT  */
      SousMenu--;
      AfficheMenu();
    } else if (digitalRead(SELECT) == LOW) { /* Bouton Select */
      Tempo = millis() + 750;
      switch (Menu + SousMenu) {
      case 21 :
          if(Tmin <= 29){
            Tmin = Tmin + 1;
          else {
            Tmin = 5;
          if(Tmin >= Tmax) {
            Tmax = Tmin + 1;
            Serial.print("Tmax");
            Serial.println(Tmax);
          Serial.print("Tmin");
          Serial.println(Tmin);
          delay(200);
      case 22 :
          if ((Tmax > Tmin)&&(Tmax <= 30)){
            Tmax = Tmax + 1;
          else {
            Tmax = Tmin + 1;
          delay(200);
      case 31 :
          if ((Hmax > Hmin)&&(Hmin <= 99)){
            Hmin = Hmin + 1;
          else {
            Hmin = 5;
          if(Hmin >= Hmax) {
            Hmax = Hmin + 5;
            "Humid Max " +String(Hmax) + " %"
            Serial.print("Hmax");
            Serial.println(Hmax);
          "Humid Min " +String(Hmin) + " %"
          Serial.print("Hmin");
          Serial.println(Hmin);
          delay(200);
      case 32 :
          if ((Hmax > Hmin)&&(Hmax <= 99)){
            Hmax = Hmax + 1;
          else {
            Hmax = Hmin + 1;
          delay(200);
      case 41 :
      case 42 :
      AfficheMenu();
void AfficheMenu() {
  if (Menu == 0 ) {
    Menu = 40;
  if (Menu == 50 ) {
    Menu = 10;
  lcd.clear();
  lcd.print(NumMenu[Menu].Menu);
  if ( SousMenu < 0 ) {
    SousMenu = 0;
  if (NumMenu[Menu + SousMenu].Menu == "") {
    SousMenu = 0;
  if (Menu + SousMenu > Menu) {
    lcd.print(NumMenu[Menu + SousMenu].Menu);
void Regul() {
    if (test1 == 1) {
      lcd.clear();
      lcd.print("Temperature Mini");
      lcd.print(Hmin);
void humi() {
    if (test2 > 0) {
    if ((digitalRead(test2)) == HIGH) {
      Serial.print("action on test2");
    if ((digitalRead(test2)) == LOW) {
      Serial.print("action off test2");
void heurefunc() {
    if (test3 > 0) {
    if ((digitalRead(test3)) == HIGH) {
      Serial.print("action on test3");
    if ((digitalRead(test3)) == LOW) {
      Serial.print("action off test3");
// sonde temperature
int tc_100(byte* addr){
  int HighByte, LowByte, TReading;
  byte data[12];
  byte i;
  ds.reset();
  ds.select(addr);
  ds.write(0x44,1);         // start conversion, with parasite power on at the end
  delay(1000);     // maybe 750ms is enough, maybe not
  // we might do a ds.depower() here, but the reset will take care of it.
  ds.reset();
  ds.select(addr);
  ds.write(0xBE);         // Read Scratchpad
  for ( i = 0; i < 9; i++) {           // we need 9 bytes
    data[i] = ds.read();
  LowByte = data[0];
  HighByte = data[1];
  TReading = (HighByte << 8) + LowByte;
  SignBit = TReading & 0x8000;  // test most sig bit
  if (SignBit) // negative
    TReading = (TReading ^ 0xffff) + 1; // 2's comp
  return (6 * TReading) + TReading / 4;    // multiply by (100 * 0.0625) or 6.25
void mypr(int Tc_100, int line) {
  int Whole, Fract;
  Whole = Tc_100 / 100;  // separate off the whole and fractional portions
  Fract = Tc_100 % 100;
  if (SignBit) // If its negative
     lcd.setCursor(StartCol,line);
     lcd.print("-");
  lcd.setCursor(StartCol+1,line);
  lcd.print(Whole);
  lcd.print(".");
  if (Fract < 10)
     lcd.print("0");
  lcd.print(Fract);
  lcd.print("C");
void Sondes()
  byte i;
  byte data[12];
  int Tc_100;
  Tc_100 = tc_100(addr1);
  mypr(Tc_100,0);
  Tc_100 = tc_100(addr2);
  mypr(Tc_100,1);
C'est a force d'enfiler les poules que l'on finit par casser des œufs !
Dams501
je v t avouai ne pas y connaitre grand chose
tu veux dire avec une
variable = 1 sa active le menu
variable = 0 sa active le menu
je voie le principe mais pas vraiment comment faire
dbrion06
void Sondes()
 byte i;
 byte data[12];
 int Tc_100;
 mypr(Tc_100,0);
 mypr(Tc_100,1);
peut se reécrire (plus concis; sera plus facile à maintenir à therme)
en
Code: [Select]
void Sondes() {
  mypr(tc_100(addr1), 0);
  mypr(tc_100(addr2),1);
lesept
Oui c'est en effet comme ça que tu peux faire. Ce genre de variable peut être fait avec un type bool : c'est un booléen qui ne peut prendre comme valeurs que true ou false (ce sont des raccourcis pour 1 et 0).
Tu peux faire comme ça :
Code: [Select]
bool afficheMenu = true;
if (afficheMenu) {
 //  les instructions liées au menu
 // les autres instructions d'affichage
Pour compléter ce que propose dbrion06, en regardant la fonction de lecture des sondes, je vois que tu mets un delay(1000) : chaque lecture prend donc une seconde. Pour 2 lectures, ça fait deux secondes et pendant ce temps, le code ne fait RIEN DU TOUT. C'est bloquant : si tu appuies sur un bouton pendant ces 2 secondes, l'appui ne sera pas pris en compte !
Donc, première solution : lire les 2 sondes dans la même fonction. Ça te permet de réduire de 2 à 1 seconde, mais le résultat sera pratiquement le même.
Autre solution, écrire un code non bloquant pour lire les sondes. Pas facile sans chambouler complètement la structure du code actuel. Le plus simple serait de tirer parti de ce temps d'attente pour lire les boutons. Au lieu de
Code: [Select]
  byte data[12];
  byte i;
  ds.reset();
  ds.select(addr);
  ds.reset();
  ds.select(addr);
tu peux changer le delay(1000) en
Code: [Select]
unsigned long chrono = millis();
while (millis()-chrono < 1000ul) {
    // lecture des boutons et traitement si menu
    bouton();
A force d'essayer on finit par réussir... Donc, plus ça rate, plus on a de chances que ça marche (proverbe Sharduinok).
Dams501
parfait mon menu et redevenu fluide
la le dernier soucie c toujours ma température qui s affiche partout sur mes menu
il faudrait que quand j active le menu je désactive l affichage de met sonde met uniquement l affichage que le contrôle se face en tache de fond.
pour désactiver mon menu sur quelle paramètre je doit impacter ? le void Initialisation() ?
Code: [Select]
int SignBit = 0;
int StartCol = 8;
int ventilo = 6;
int sonde = 7;
int relais = 1;
int Tmin = 20;
int Tmax= 25;
int Hmin = 20;
int Hmax = 25;
int heure = 1;
int minute = 1;
double Tempo2 = 0;
int test1 = 0;
int test2 = 0;
int test3 = 0;
int SELECT = A0;
int UP = A1;
int DOWN = A2;
int LEFT = A3;
int RIGHT = A4;
typedef struct {
  String Menu;
TypeMenu;
    "1. Info General "
    "2. Temperature"
    "3. Humidite"
    "4. Heure"
    "4.1 Reglage"
    "4.2 Reglage heure"
  Initialisation();
  lcd.begin(16, 2);
  lcd.clear();
  delay(2000);
  Sondes();
  Regul();
  humi();
  heurefunc();
  bouton();
void bouton() {
      SousMenu++;
      AfficheMenu();
      Menu = Menu - 10;
      SousMenu = 0 ;
      AfficheMenu();
      Menu = Menu + 10;
      SousMenu = 0;
      AfficheMenu();
      SousMenu--;
      AfficheMenu();
      case 21 :
          if(Tmin <= 29){
            Tmin = Tmin + 1;
          else {
            Tmin = 5;
          if(Tmin >= Tmax) {
            Tmax = Tmin + 1;
          delay(200);
      case 22 :
            Tmax = Tmax + 1;
          else {
            Tmax = Tmin + 1;
          delay(200);
      case 31 :
            Hmin = Hmin + 1;
          else {
            Hmin = 5;
          if(Hmin >= Hmax) {
            Hmax = Hmin + 5;
          delay(200);
      case 32 :
            Hmax = Hmax + 1;
          else {
            Hmax = Hmin + 1;
          delay(200);
      case 41 :
      case 42 :
      AfficheMenu();
  if (Menu == 0 ) {
    Menu = 40;
  if (Menu == 50 ) {
    Menu = 10;
  lcd.clear();
    SousMenu = 0;
    SousMenu = 0;
void Regul() {
    if (test1 == 1) {
      lcd.clear();
      lcd.print(Hmin);
void humi() {
    if (test2 > 0) {
void heurefunc() {
    if (test3 > 0) {
  byte data[12];
  byte i;
  ds.reset();
  ds.select(addr);
    bouton();
  ds.reset();
  ds.select(addr);
  LowByte = data[0];
  HighByte = data[1];
  int Whole, Fract;
     lcd.print("-");
  lcd.print(Whole);
  lcd.print(".");
  if (Fract < 10)
     lcd.print("0");
  lcd.print(Fract);
  lcd.print("C");
void Sondes() {
Dams501
ou alors je prend un affichage lcd de 4*16 ?
lesept
Pas besoin...
Je pense que c'est lors de l'appui sur un bouton que tu dois switcher sur l'affichage du menu. En dehors, il faut afficher les températures. Exact ?
On y arrivera : d'abord tu déclares dans l'entête la variable booléenne globale
Code: [Select]
bool afficherMenu = false;
Puis dans bouton(), tu la passes à true lorsqu'un appui sur un bouton est détecté.
Tu modifies Sondes pour prendre en compte l'affichage
Code: [Select]
void Sondes() {
  if (!afficherMenu) {
Il reste à savoir quand la repasser à false. Quelle est ton idée, pour passer de l'affichage du menu à celui des températures ? Une temporisation ? L'appui sur un autre bouton ? Si c'est le bouton SELECT, tu peux changer ici :
Code: [Select]
      afficherMenu = false;  // <-- ici
Clair ?
Dams501
#23
Apr 24, 2019, 05:44 pm Last Edit: Apr 24, 2019, 05:46 pm by Dams501
merci ji voie effectivement plus clair et sa me remotive je me sens moin seul sa fait du bien ^^
j ai supprimer deux bouton dans mon code du coups j en est remis un nommé HOME dans l idéal il serait bien qu il me ramené sur l affichage principal
j ai également mis ton bout de code mais mes température reste afficher par dessus met menu
le code
Code: [Select]
int SignBit = 0;
int StartCol = 8;
int ventilo = 6;
int sonde = 7;
int relais = 1;
int Tmin = 20;
int Tmax= 25;
int Hmin = 20;
int Hmax = 25;
int heure = 1;
int minute = 1;
double Tempo2 = 0;
int test1 = 0;
int test2 = 0;
int test3 = 0;
int SELECT = A0;
int UP = A1;
int LEFT = A3;
int HOME = A4;
typedef struct {
  String Menu;
TypeMenu;
    "1. Info General "
    "2. Temperature"
    "3. Humidite"
    "4. Heure"
    "4.1 Reglage"
    "4.2 Reglage heure"
  Initialisation();
  lcd.begin(16, 2);
  lcd.clear();
  delay(2000);
  pinMode(HOME, INPUT_PULLUP);
  Sondes();
  Regul();
  humi();
  heurefunc();
  bouton();
  if ((Tmax*100) < (tc_100(addr1))){
    digitalWrite(ventilo, HIGH);
  }else {
      digitalWrite(ventilo, LOW);
void bouton() {
      SousMenu++;
      AfficheMenu();
      Menu = Menu + 10;
      SousMenu = 0;
      AfficheMenu();
      case 21 :
          if(Tmin <= 29){
            Tmin = Tmin + 1;
          else {
            Tmin = 5;
          if(Tmin >= Tmax) {
            Tmax = Tmin + 1;
          delay(200);
      case 22 :
            Tmax = Tmax + 1;
          else {
            Tmax = Tmin + 1;
          delay(200);
      case 31 :
            Hmin = Hmin + 1;
          else {
            Hmin = 5;
          if(Hmin >= Hmax) {
            Hmax = Hmin + 5;
          delay(200);
      case 32 :
            Hmax = Hmax + 1;
          else {
            Hmax = Hmin + 1;
          delay(200);
      case 41 :
      case 42 :
      AfficheMenu();
  if (Menu == 0 ) {
    Menu = 40;
  if (Menu == 50 ) {
    Menu = 10;
  lcd.clear();
    SousMenu = 0;
    SousMenu = 0;
void Regul() {
    if (test1 == 1) {
      lcd.clear();
      lcd.print(Hmin);
void humi() {
    if (test2 > 0) {
void heurefunc() {
    if (test3 > 0) {
  byte data[12];
  byte i;
  ds.reset();
  ds.select(addr);
    bouton();
  ds.reset();
  ds.select(addr);
  LowByte = data[0];
  HighByte = data[1];
  int Whole, Fract;
     lcd.print("-");
  lcd.print(Whole);
  lcd.print(".");
  if (Fract < 10)
     lcd.print("0");
  lcd.print(Fract);
  lcd.print("C");
void Sondes() {
  } else if (digitalRead(HOME) == LOW) { /* Bouton Select */
lesept
Tu n'as pas fait ça :
Quote
Code: [Select]
      afficherMenu = true;  // <-- ici
      SousMenu++;
      AfficheMenu();
      Menu = Menu + 10;
      SousMenu = 0;
      AfficheMenu();
      afficherMenu = true;  // <-- et ici
Dams501
ok sa marche  ;D  ;D  ;D  ;D  les température se cache
encore quelque réglage mais on est pas loin
1 par moment mais pas toujours la température reste affiché si il y a pas de sous menu qui récrie par dessus.
2 le retour se fait mais il est très long a revenir et je doit appuyer une deuxième fois en général
3 quand je revient au HOME les sous menu eux reste afficher j ai donc rajouter ceci mais je pense pas que se soit le plus propre ? mais sa marche
Code: [Select]
void Sondes() {
    mypr(tc_100(addr1),0);
      lcd.clear();
lesept
Tu peux mettre un lcd.clear(); lorsque tu vois qu'un sous-menu reste en partie affiché.
Que veux-tu dire par :
Quote
Dams501
#27
Apr 24, 2019, 06:25 pm Last Edit: Apr 24, 2019, 06:27 pm by Dams501
ok
je suis dans le menu
j'appuie une fois sur home rien ne se passe j'attends un peux rien 10/20 second
je rappuie le retour se fait
si je spams le bouton des la première fois je peux appuyer 3/4 fois avent le retour
et par moment une fois sufie
on dirait que c plus ou moin aléatoire
Dams501
#28
Apr 24, 2019, 06:36 pm Last Edit: Apr 24, 2019, 06:38 pm by Dams501
j ai mis des lcd.clear dans mes bouton le retour et instantané maintenant par contre quand je rentre dans mon menu la température de la deuxième ligne reste affiché et des que je me déplace dans le menu ou sous menu elle disparait
Code: [Select]
int SignBit = 0;
int StartCol = 8;
bool temperatureLimite = false;
int ventilo = 6;
int sonde = 7;
int relais = 1;
int Tmin = 20;
int Tmax= 25;
int Hmin = 20;
int Hmax = 25;
int heure = 1;
int minute = 1;
double Tempo2 = 0;
int test1 = 0;
int test2 = 0;
int test3 = 0;
int SELECT = A0;
int UP = A1;
int LEFT = A3;
int HOME = A4;
typedef struct {
  String Menu;
TypeMenu;
    "1. Info General "
    "2. Temperature"
    "3. Humidite"
    "4. Heure"
    "4.1 Reglage"
    "4.2 Reglage heure"
  Initialisation();
  lcd.begin(16, 2);
  lcd.clear();
  delay(2000);
  Sondes();
  Regul();
  humi();
  heurefunc();
  bouton();
void bouton() {
      lcd.clear();
      SousMenu++;
      AfficheMenu();
      lcd.clear();
      Menu = Menu + 10;
      SousMenu = 0;
      AfficheMenu();
      case 21 :
          if(Tmin <= 29){
            Tmin = Tmin + 1;
          else {
            Tmin = 5;
          if(Tmin >= Tmax) {
            Tmax = Tmin + 1;
          delay(200);
      case 22 :
            Tmax = Tmax + 1;
          else {
            Tmax = Tmin + 1;
          delay(200);
      case 31 :
            Hmin = Hmin + 1;
          else {
            Hmin = 5;
          if(Hmin >= Hmax) {
            Hmax = Hmin + 5;
          delay(200);
      case 32 :
            Hmax = Hmax + 1;
          else {
            Hmax = Hmin + 1;
          delay(200);
      case 41 :
      case 42 :
      AfficheMenu();
  if (Menu == 0 ) {
    Menu = 40;
  if (Menu == 50 ) {
    Menu = 10;
  lcd.clear();
    SousMenu = 0;
    SousMenu = 0;
void Regul() {
    if (test1 == 1) {
      lcd.clear();
      lcd.print(Hmin);
void humi() {
    if (test2 > 0) {
void heurefunc() {
    if (test3 > 0) {
  byte data[12];
  byte i;
  ds.reset();
  ds.select(addr);
    bouton();
  ds.reset();
  ds.select(addr);
  LowByte = data[0];
  HighByte = data[1];
  int Whole, Fract;
     lcd.print("-");
  lcd.print(Whole);
  lcd.print(".");
  if (Fract < 10)
     lcd.print("0");
  lcd.print(Fract);
  lcd.print("C");
void Sondes() {
      lcd.clear();
lesept
1 : Tu as des delay(200) qui traînent, enlève les si tu n'en as pas besoin
2 : Si l'écran ne s'efface pas c'est que tu as oublié un endroit où mettre le lcd.clear...
