Topic: Convert 3.3v into ampere (Read 686 times) previous topic - next topic
nicolopadovandev
Apr 24, 2019, 07:49 pm Last Edit: Apr 24, 2019, 08:30 pm by nicolopadovandev
Hi everyone.
I recently bought an RF24L01 radio module to connect it with my arduino esplora.
Sadly the Esplora has the 5v power only, and the module requires no more than 3.3v.
How can I convert these 3.3v into ampere to apply the Ohm's theory?
I also have this chip
Code: [Select]
https://www.sparkfun.com/products/12009
Is this any useful? If so, how do I have to connect it to the Esplora and the Radio module?
Thanks.
The most intelligent people in the world are the ones who don't think of themselves as the most intelligent person in the world.
groundFungus
The level converter is for signals, not power.  I use LM1117 3.3V voltage regulators to convert 5V to 3.3V to power my RF24 radios.  Those regulators provide plenty of current for the radios.  Do not forget the required cap on the input side of the regulator.
nicolopadovandev
Is it possible to do this with resistors? And what is the difference between Signals and Power?
Also that chip has 4 channels for signals and 1 for power (the center one) I think.
Perehama
A common resistor is not Ohmic, and Ohm's Law is just a rule of thumb. There are lots of sources on the internet that will explain how to do "Logic-Level Translation" using resistors, but It can be a lot of frustration for a new electronics hobbyist if they can't get it to work, or damage their hardware etc.
"Have not I written to thee excellent things in counsels and knowledge, that I might make thee know the certainty of the words of truth; that thou mightest answer the words of truth to them that send unto thee?"  Proverbs 22:20-21 KJV
groundFungus
If you are thinking of using a voltage divider to drop 5V to 3.3V, forget it.  As soon as you connect a load to the divider, you change the dividing ratio and therefore the voltage.  Use a proper power converter, ie.linear voltage regulator or buck regulator.
The power pins on the level converter must be supplied external to the converter, those pins do not supply power.
nicolopadovandev
What if I use something like the one attached to this post?
There is 5v input -> 12k resistor -> 3.3v output -> 22k resistor -> Ground
groundFungus
One more time, you cannot use a voltage divider to supply power. See. here
Perehama
Also, here, a tutorial and inexpensive translation module, open source, with schematic.
groundFungus
WattsThat
There is no need for signal level conversion with the NRF24L01, it has 5 volt tolerant I/O but you must supply it with 3.3 volts. The board shown, available on eBay for $1 US is an easy solution for adding the NRF24 radio to a board like an Uno or Nano as it provides a proper 5V to 3.3V regulator, bypass caps and a socket for the module. Easy, simple, cheap.
Vacuum tube guy in a solid state world
hesam_m
Do you want to use a resistor divider to convert the 5V to 3.3V to supply your NRF?
that's not practical because by a voltage divider you limit the current also, or if you use low-value resistors, you put your supply at pressure, because it will be an extra load!
if you want to convert a signal (I/O line), actually it depends on the signal direction. you can use a Mosfet or even yes a resistor divider or a Zener diode.
nicolopadovandev
Thanks you! The adapter came with the Radio Module
