Topic: Cannot upload to Arduino Mega 2560 (need solution quick!!!!) (Read 1 time) previous topic - next topic
Davidof
Hello, after a while suddenly i cannot upload any program in the Arduino. If i try another PC it works but after a while te same problem.
I always get next errors:
Code: [Select]
Binary sketch size: 1588 bytes (of a 258048 byte maximum)
avrdude: stk500v2_command(): unknown status 0xc8
avrdude: initialization failed, rc=-1
        Double check connections and try again, or use -F to override
        this check.
avrdude: stk500v2_command(): unknown status 0x01
avrdude: stk500v2_disable(): failed to leave programming mode
i already tried to reinstall the drivers but nothing fixes this. I had this problem om 3 different PC's!
OS: Windows 7
opalenzuela
My advice: get a AVR programmer and avoid the USB connection for uploading sketches.
Yes, I insist: the USB controller in UNO and Mega2560 does not work well
hugo007
#3
May 15, 2011, 11:01 pm Last Edit: May 15, 2011, 11:04 pm by hugo007 Reason: 1
there are a solution for that .You must reinstall the firmware on it again. There is a know bug on Mega that cause fail to upload the sketchs
Read this topic
http://arduino.cc/forum/index.php/topic,56926.0.html
Debian,Mint,Ubuntu
Arduino Mega 2560
Arduino Nano
Arduino Duemilanove
MAC OS Montain Lion
Raspberry PI Model B
