Topic: Playing a wav sample from an SD card when a button is pressed (Read 700 times) previous topic - next topic
saniv
I've been struggling to make an Arduino to play samples (loaded on an SD card and connected to the Arduino Uno board) whenever a button is pressed but with no success. When I run the code it does not wait for the button to be pressed, it starts playing the sample right away. Then if there's only one button available for pressing, it would make some "beep" noise but if there are two for example, it starts "beeping" constantly as if the second button is always pressed. Here's the code. How can I play the samples (1 or 2 seconds mono samples) when the buttons are pressed?
Code: [Select]
#include <SD.h> //Include the library.
#include <TMRpcm.h> //Include the library.
TMRpcm tmrpcm; //Creating a player object.
TMRpcm tmrpcm2; //Creating a player object.
const int chipSelect = 4;
  pinMode(9,INPUT);
  pinMode(10,INPUT);
  pinMode(11,INPUT);
  pinMode(12,INPUT);
  //tmrpcm.speakerPin = 11; //The speaker is connected to 11 Pin. You can use any PWM Pin.
  Serial.begin(9600); //Initializing serial port. Speed 9600.
  if(!SD.begin(chipSelect)) //If the card is available.
    Serial.println("SD fail"); //Write in the serial port "SD fail".
    return; //Return.
  Serial.println("SD working");
if(digitalRead(9)==1){
  tmrpcm.play("transMono1.wav"); //Play music file
   Serial.println("button 1 pressed");
  else{
    tmrpcm.pause();
  if(digitalRead(10)==1){
  tmrpcm2.play("transMono3.wav"); //Play music file
   Serial.println("button 2 pressed");
  else{
    tmrpcm2.pause();
Also I have been mainly trying things with one sample. I tried switching to another but it still plays the initial sample. Why is this happening? Thanks in advance!
Geek Emeritus
I am baffled by the combination of
pinMode(11,INPUT);
All PMs will be deleted unopened due to arrogant argumentative pot stirring Malfoys.
 If you have not read "How to use this forum - please read", in particular: "7. If you are posting code or error messages, use "code" tags":  expect rude responses
saniv
This ---> //tmrpcm.speakerPin = 11; //The speaker is connected to 11 Pin.
is commented out so it does not affect the program or the button input pin.
DVDdoug
So, where is the speaker connected?
And you probably need to include that line of code (modified) so TRMpcm "knows" where to send the sound.  ;)
SchnoppDog
I've been working recently on a project which is kinda the same.
  • there is no need to create two TMRPCM-Objects. You only need one "TMRpcm tmrpcm".
  • DOn't comment out this line: "tmrpcm.speakerPin = 11". You need a speaker. You can't tell tmrpcm with "pinMode(11, INPUT)" to use your speaker. Also: if it would work with "pinMode" it should be set as an "OUTPUT" since a speaker commonly is a output-device.
  • What kind of speaker do you use?
  • How did you connect your speaker to the arduino? (As for my project I used a JBL-Box with a aux-to-aux cable. You have many different options so it would be nice to know how you connected your speaker)
Now some more thing you might want to try out:
Use a 1k ohm Resistor between your datapin and button to the ground. With that the remaining electrons are cleared from the button and you can get a better "HIGH-LOW"-Status.
Use some variables to check the status of an button. Then use the if-statement to check if a button is pressed.
You can try this:
Code: [Select]
const int buttonState1 = 0;
const int buttonState2 = 0;
  pinMode(9,INPUT);
  pinMode(10,INPUT);
  //pinMode(11,INPUT);
  pinMode(12,INPUT);
    return; //Return.
buttonState1 = digitalRead(9);
buttonState2 = digitalRead(10);
if(buttonState1 == HIGH){
  else{
    tmrpcm.pause();
  if(buttonState2 == HIGH){
  tmrpcm.play("transMono3.wav"); //Play music file
  else{
    tmrpcm.pause
I don't guarantee you that this is working 100% correctly since I can't test it out right now.
