hi,
my ESP32 calculates floats faultily opp. to my M4 and my M3/Due
(Arduino IDE 1.8.8 )
e.g, after a long calculation (1264 steps) by the Feather M4 I get the result 32.843750,
whilst the Feather ESP32 calculates 54196.625
update:
I now retested by the Due, and here I also get the result 32.843750, just like the M4.
this is the relevant code:
// Lunar Lander
// preprocessor defaults for time sync:
//#define SYNC_REALTIME // real time sync; outcomment for time lapse
#if defined (SAM)
#include "avr/dtostrf.h" // sprintf() and dtostrf() for floats
#endif
// flight control
// public:
float mFuel=8200; // fuel mass in kg for landing
float hi=15300; // act height in m
float vHorz=1685; // Horizontal orbital speed m/s
float sTargm=470000; // horizontal way to target landing place
float burnPerc=0; // user input: burnrate %
float ftilt; // tilt horiz...vert -1...0...+1
float tiltDeg; // tilt degrees -90°...0...+90°
// private:
float ti=0.0, dt=0.5; // act time, delta time in sec
const float g=1.62; // Moon gravity
const float MoonRad=3476000/2.0; // Moon radius
const float mLander=6500; // lander mass in kg with launch fuel
const float Isp=3050; // Rocket engine Specific Impulse
const float FBrake=45000; // Rocket engine max Propulsion Force
float burnMax=FBrake/Isp; // absolute max fuel burnrate
float mTotal=mLander+mFuel; // brutto weight with full tanks
float rBrake; // user Rocket brake force 100%, percentual
float dFuel=0; // delta fuel
float burnf=0; // burnrate factor 0.0 ... 1.0
float dh=0.0; // delta height in m
float scaleH=hi/100; // scaler for tft.hight=100%
float vVert=0.0; // Impact speed in m/s
float accVert=0; // vertical accel (sum)
float accBrake=0; // acc by break rockets
float fCentrifug=0; // centrifugal force by orbital speed
float accCentrif=0; // centrifugal accel by orbital speed
float sHorzm=0.0; // horizontal way flown in m
// Serial LogBook
void LogBook(){
char sbuf1[50], sbuf2[50] ;
char* headline1 = "t.sec hi.m vVert vHoriz ";
char* headline2 = "Burn tilt brake acc Fuel TBase.m";
Serial.print(headline1);
Serial.println(headline2);
sprintf(sbuf1, "%5.1f %5d %4d %4d ",
ti, (int)hi, (int)vVert, (int)vHorz);
sprintf(sbuf2, "%3d%% %4d %3.1f %4.1f %5d %f",
(int)burnPerc, (int)(ftilt*90), accBrake, accVert,
(int)mFuel, (float)(sTargm-sHorzm));
Serial.print(sbuf1); Serial.println(sbuf2);
uint32_t dtime;
// Lander Move
void LanderMove() {
static float t0=ti;
dtime=millis();
if(hi>0) {
// Burn Ratio:
// 100 = 100% == full brake power
// 50 = 50% == half brake power
// 0 = 0% == zero brake power
// or anything in between
// 100% BURN RATIO (BRAKE POWER)
// => 45000kN propulsion force
// => 14,75 kg Fuel burn per second
// => brake accelation = 3m/s²
// XEROX Board Computer program, debug:
if( sHorzm<15600.0) burnPerc=0; // sHorzm<15600
if( vVert>60||vHorz>30 ) burnPerc=100; //
if(vVert>50) burnPerc=65;
if(vVert>40&&hi<3000) burnPerc=45;
if(vVert>35&&hi<1800) burnPerc=40;
if(vVert>10&&hi<1100) burnPerc=35;
if(vVert>=1&&hi<120) burnPerc=33;
burnPerc=0;
// calculate control
fCentrifug=vHorz*vHorz*mTotal/(MoonRad+hi);
accCentrif=fCentrifug/mTotal;
if(mFuel==0) burnPerc=0; // no fuel, no burn ;)
burnf = burnPerc/100.0; // factor 0...1
// vvvvvvvvvvvvvvvvvvvvvvvvvvvvvvvvvvv
dFuel= burnMax*burnf*dt; // try burnrate: enough fuel?
dFuel = min(dFuel, mFuel); // calc available rest fuel
burnf = (dFuel/burnMax)/dt; // re-calc burnrate by rest fuel
burnPerc = burnf*100;
rBrake= FBrake*burnf; // rel brake force
accBrake= rBrake/mTotal; // rocket brake acceleration
mFuel = max(mFuel-dFuel, (float)0); // rest fuel >=0
mTotal= mLander+mFuel; // new total mass
if(vVert>=5 ) {
if(vVert>=40 && vHorz>2 ) ftilt=0.65; // 58.5°
if(vVert>=30 && vHorz>2 ) ftilt=0.75; // 67.5°
if(vVert>=20 && vHorz>2 ) ftilt=0.80; // 72.0°
if(vHorz<=2 && vHorz>=-2) ftilt=0.0;
if(vHorz<0) ftilt=0.0;
else ftilt=0.85; // 76.5°
if(vVert<5&&vHorz>20 ) ftilt=1;
else ftilt=0;
accVert = g - (1-abs(ftilt))*accBrake -accCentrif;
vVert = vVert + accVert*dt; // fractional vertical brake
if(vHorz>0)
vHorz = vHorz - (ftilt)*accBrake*dt; // fractional horizonal brake
sHorzm = sHorzm + vHorz*dt; // horizontal way flown
dh = 0.5*accVert*dt*dt + vVert*dt ; // delta height by res. grav+centrifug.+brake acc.
hi = hi-dh; // new resulting height
// pause
#ifdef SYNC_REALTIME
while( millis()-dtime < dt*1000 );
#endif
ti+=dt;
LogBook();
t0=ti;
// Landing specs/ratings
if ( (( hi<=0 && vVert>=5 ) && vVert<8) ) // Damage
Serial.println(" !! Damage !!");
if ( hi<=0 && vVert<5 && abs(sTargm-sHorzm)>100) { // very good Landing but way off
burnPerc=0;
Serial.println("Very good but way off!");
if ( hi<=0 && vVert<5) { // Perfect Landing
burnPerc=0;
Serial.println("Perfect Landing!");
if ( hi<=0 ) // B L A S T
Serial.println(" !!! B L A S T !!!");
// setup
#if defined (SAM)
asm(".global _printf_float"); // sprintf() and dtostrf() for floats
#endif
delay(2000);
Serial.println("Serial started!");
sHorzm=0; // way flown
delay(dt*1000);
accVert=g-accBrake-accCentrif;
LogBook();
// loop
void loop(void) {
if (hi>0) {
LanderMove();
the questionable value is the last one in either Serial output line (TBase.m)
actually the M4 == DUE result
32.843750
is probably the correct one...!
edit, update:
could be confirmed for MEGA2560 too, also 32.843750 here!
so just faulty for ESP32, both for fp32 and fp64 double as meanwhile tested.
