Topic: Using a bluetooth module to send/receive more than 1 information (Read 606 times) previous topic - next topic
Steewz
Hey guys,
I recently bought a Bluetooth module ( HC-05) to use it in a personal project but I'm wondering if we can send/receive multiple informations. I use MIT app inventor to create my app and send my data to the Bluetooth module. I also plug the Tx and Rx pins of the HC-05 to the pins Rx and Tx of my Arduino.
So can we to that or the limit is one information.
Thank you for your help.
Steewz
PaulS
Quote
What have you tried?
Is "<12,34,56>" one information, or more than one?
Steewz
This is my code here the goal was to turn on a led depending on which information ( 1 2 or 3 ) I send from my phone to the BT module.
I tried to control with a slider on my app the brightness of my led ( from 0 to 255 ), and there is the problem if the slider reaches the values 0 1 or 3 it will activate the other instructions, that's why I'm asking if there is a way to send two different information, so can we for example set two variables that read the serial at the same time, one for numbers(int) and the other for a text for example(char) or there is another way to do it.
int state = 0;
const int ledr = 8 ;
const int ledb = 9 ;
const int ledg = 10 ;
   pinMode(ledr, OUTPUT);
   pinMode(ledb, OUTPUT);
   pinMode(ledg, OUTPUT);
    if(Serial.available() > 0){
    state = Serial.read();
    if (state == '0') {
    digitalWrite(ledr, LOW);
    digitalWrite(ledb, LOW);
    digitalWrite(ledg, LOW);
    Serial.println("LED: OFF");
    state = 0;
      delay(1000);}
    if (state == '1') {
    digitalWrite(ledr, HIGH);
    Serial.println("Red Led: ON");
    if (state == '2') {
    digitalWrite(ledb, HIGH);
    Serial.println("Blue Led: ON");
    if (state == '3') {
    digitalWrite(ledg, HIGH);
    Serial.println("Green Led: ON");
Idahowalker
Yes.
Steewz
slipstick
Serial input basics - I think example 5 has everything you need but read the rest as well.
Steve
Idahowalker
Yes, I can give you an example. Here are 3 tasks that ae sending different data sets meant for different destinations over the same serial port.
Code: [Select]
void fLIDAR_Is_OK ( void *pvParameters )
  String sSerial = "<$>";
  TickType_t xLastWakeTime;
  const TickType_t xFrequency = pdMS_TO_TICKS( 1000 );
  xLastWakeTime = xTaskGetTickCount();
  for ( ;; )
    vTaskDelayUntil( &xLastWakeTime, xFrequency );
    bool LIDAR_OK = true;
    if ( xSemaphoreTake( sema_SendSerialToBrain, xZeroTicksToWait ) == pdTRUE )
      if (xHANDLE_LIDAR_ServoAspectChange == NULL )
        Serial.println ( " xHANDLE_LIDAR_ServoAspectChange " );
        LIDAR_OK = false;
      if ( xHANDLE_DoLIDAR == NULL )
        Serial.println ( " xHANDLE_DoLIDAR " );
        LIDAR_OK = false;
      if ( xHANDLE_SendLIDAR_InfoSerialToBrain == NULL )
        Serial.println ( " xHANDLE_SendLIDAR_InfoSerialToBrain " );
        LIDAR_OK = false;
      if ( xHANDLE_SendSerialToBrain == NULL )
        Serial.println ( " xHANDLE_SendSerialToBrain " );
        LIDAR_OK = false;
      if ( xHANDLE_TweakServoX == NULL )
        Serial.println ( " xHANDLE_TweakServoX " );
        LIDAR_OK = false;
      if ( xHANDLE_TweakServoY == NULL )
        Serial.println ( " xHANDLE_TweakServoY " );
        LIDAR_OK = false;
      if ( xHANDLE_GetIMU == NULL )
        Serial.println ( " xHANDLE_GetIMU " );
        LIDAR_OK = false;
      if ( LIDAR_OK )
        SerialBrain.println ( sSerial );
    xSemaphoreGive ( sema_SendSerialToBrain );
  vTaskDelete( NULL );
void fSendLIDAR_InfoSerialToBrain( void *pvParameters )
  struct stu_LIDAR_INFO pxLIDAR_INFO;
  for ( ;; )
    xEventGroupWaitBits (eg, evtGetIMU, pdTRUE, pdTRUE, portMAX_DELAY);
    xSemaphoreTake( sema_LIDAR_FOR_ALARM, xSemaphoreTicksToWait );
    xQueueReceive ( xQ_LIDAR_FOR_ALARM, &pxLIDAR_INFO, QueueReceiveDelayTime );
    xSemaphoreGive( sema_LIDAR_FOR_ALARM );
    int CellCount = 1 ;
    String sSerial = "";
    sSerial.reserve ( 300 );
    sSerial.concat( "<#," );
    sSerial.concat( String(ScanPoints) + "," );
    sSerial.concat( String(pxLIDAR_INFO.ServoSweepUp) + "," );
    for ( CellCount; CellCount <= ScanPoints; CellCount++ )
      sSerial.concat( String(pxLIDAR_INFO.Range[CellCount]) + "," );
    sSerial.concat( ">" );
    vTaskDelay( 10 );
} // void fSendLIDAAR_InfoSerialToBrain( void *pvParameters )
void fSendSerialToBrain( void *pvParameters )
  for (;;)
    xEventGroupWaitBits (eg, evtSendSerialToBrain, pdTRUE, pdTRUE, portMAX_DELAY);
      int CellCount = 1;
      xSemaphoreTake( sema_LIDAR_INFO, xSemaphoreTicksToWait );
      xQueueReceive ( xQ_LIDAR_INFO, &pxLIDAR_INFO, QueueReceiveDelayTime );
      xSemaphoreGive( sema_LIDAR_INFO );
      sSerial.concat( "<!," );
} // void fSendSerialToBrain( void *pvParameters )
