If they want to drive the digital masturbation to higher levels the following questions remain:
How many cycles will the flash memory need to drop below a retention time of 1s?
At which temperature will retention time drop below 1min while NOT destroying the processor? Both question for flash and EEProm.
At which voltage will the processor be destroyed?
At which temperature will the processor be destroyed?
Are there any differences for depending on the pin? E.g. do reset or ACC have a different threshhold?
Which is the minimum voltage / current to explode the processor?
Which is the minimum voltage / current to vaporize it?
And of course: does it blend?
