This is not actually a question, but rather a solution I had previously tried searching this forum for and wanted to post for the benefit of other newbies like me.
I have been using ESP8266 boards (LOLIN D1 mini Pro's specifically) for a project and recently started using ESP32 boards (LOLIN D32 Pro's) as well in the same project. When I set up the project originally, I needed a way for the boards to self-identify and found a solution using ESP8266's ESP.getChipId() along with a switch...case. (You can read the background
here.)
The chip ID works great for this because it is relatively unique, but still provides an easy to work with integer. However, when moving to the ESP32, I ran into a problem because it doesn't have getChipId. Fortunately, the chip ID for ESP8266 is just a decimal output of the last three bytes of the MAC address. So, you can extract those by truncating using a bitshift after calling the ESP32's MAC address with ESP.getEfuseMac(). You use a 40-bit shift because in the ESP32, the MAC address is defined as a 64-bit integer, but you just want to keep the last 24 bits (aka 3 bytes). Also, I believe ESP.getEfuseMac() is preferred over WiFi.macAddress(), because it's available even before starting the wifi.
Here's the code I came up with:
uint64_t macAddress = ESP.getEfuseMac();
uint64_t macAddressTrunc = macAddress << 40;
chipID = macAddressTrunc >> 40;
The code assumes you have 'uint32_t chipID;' defined in your universal variables at the beginning of the sketch.
If you want to load the same sketch code on both ESP8266s and ESP32s, you can use #ifdef
#ifdef ESP8266
chipID = ESP.getChipId();
#endif
#ifdef ESP32
#endif
