So I'm trying to send and receive IR signals with ATTiny85s. The receivers I use are VS1838b working at 38khz.
Transmitter sends a Sony signal in a loop:
#include <Arduino.h>
#include <IRremote.h>
IRsend _irSend;
OSCCAL = 0x8A;
for (int i = 0; i < 3; i++)
_irSend.sendSony(0xa90, 12);
delay(40);
delay(5000); //5 second delay between each signal burst
Receiver prints any signal onto bitbanged serial:
#include <SoftwareSerial.h>
SoftwareSerial _serial(-1, PB2);
IRrecv _irRecv(PB0);
decode_results _results;
char message[32];
OSCCAL = 0x4F;
_serial.begin(9600);
_irRecv.enableIRIn();
if (_irRecv.decode(&_results)) {
sprintf(message, "Received %lu in %d", _results.value, _results.decode_type);
_serial.println(message);
_irRecv.resume(); // Receive the next value
Now I have a working remote and confirm the receiver works as expected for Sony and NEC signals. However when I point the transmitter at the receiver, the receiver begins to spill out garbage readings in -1 (unknown) IR protocol.
I've tried replacing the IR LED with a visible LED. To my surprise the light seemed to constantly pulse instead of the expected "pulse | delay(5000)" pattern.
Edit: I've also tried uploading blinking code on the same pin (PB1) to confirm the chip's timing is working as expected.
Can anyone point me out where I did wrong? Thanks.
