Topic: ESP8266/Wampserver-error in conenctivity (Read 143 times) previous topic - next topic
samerou
Hello ,
I'm trying to connect to WampServer(PhpMyAdmin)  in order to send some data but without success  .
I pinged my server PhpMyAdmin ( ping 127.0.0.1) and it's fine
also pinged my pc and it's fine  and my esp also fine  but I could find the problem why I cannot log to wamp server  using PORT 3306
The code is below
Code: [Select]
// Created by: Dr. Charles A. Bell
#include "ESP8266WiFi.h"
#include <MySQL_Connection.h>
#include <MySQL_Cursor.h>
IPAddress server_addr(127,0,0,1);  // IP of the MySQL *server* here
char user[] = "esp";              // MySQL user login username
char password[] = "";        // MySQL user login password
const char* SSID = "alpha";         // Your network SSID
const char* PASS = "beta";
// Sample query
char INSERT_SQL[] = "INSERT INTO sogecdb (user) VALUES ('Hello, Arduino!')";
WiFiClient client;
MySQL_Connection conn((Client *)&client);
  while (!Serial); // wait for serial port to connect
  Serial.print("Connecting to "+*SSID);
  WiFi.begin(SSID, PASS);
  Serial.println("going into wl connect");
  while (WiFi.status() != WL_CONNECTED) //not connected,  ...waiting to connect
      Serial.print(".");
  Serial.println("wl connected");
  Serial.println("");
  Serial.println("Credentials accepted! Connected to wifi\n ");
  Serial.println("");
  if (conn.connect(server_addr, 3306, user, password)) {
    Serial.println("Connection failed.");
  delay(2000);
  Serial.println("Recording data.");
  // Initiate the query class instance
  MySQL_Cursor *cur_mem = new MySQL_Cursor(&conn);
  // Execute the query
  cur_mem->execute(INSERT_SQL);
  // Note: since there are no results, we do not need to read any data
  // Deleting the cursor also frees up memory used
  delete cur_mem;
and the error is below  :
Code: [Select]
13:59:53.616 -> d! Connected to wifi
13:59:53.616 ->  going into wl connect
13:59:54.619 -> ...wl connected
13:59:56.624 ->
13:59:56.624 -> Credentials accepted! Connected to wifi
13:59:56.624 ->
13:59:56.624 -> 192.168.1.5
13:59:56.624 ->
14:00:20.637 -> Connection failed.
14:00:22.626 -> Recording data.
14:00:22.626 ->
14:00:22.626 -> Exception (3):
14:00:22.626 -> epc1=0x402059fe epc2=0x00000000 epc3=0x00000000 excvaddr=0x402381e4 depc=0x00000000
14:00:22.626 ->
14:00:22.626 -> ctx: cont
14:00:22.626 -> sp: 3ffefaa0 end: 3ffefcd0 offset: 01a0
14:00:22.626 ->
14:00:22.626 -> >>>stack>>>
14:00:22.626 -> 3ffefc40:  4020137a 00000001 3ffe8ba5 40205a08
14:00:22.679 -> 3ffefc50:  3ffeead0 0000000e 3ffe893a 3ffeec9c
14:00:22.679 -> 3ffefc60:  3fffdad0 00000000 3ffeec70 40205121
14:00:22.679 -> 3ffefc70:  402381e4 00000000 3ffeec70 3ffeec9c
14:00:22.679 -> 3ffefc80:  3fffdad0 00000000 3ffeec70 40205169
14:00:22.679 -> 3ffefc90:  4020137a 00000000 3fff146c 402031a6
14:00:22.679 -> 3ffefca0:  40107108 00000000 3fff146c 402021b2
14:00:22.679 -> 3ffefcb0:  3fffdad0 00000000 3ffeec94 40205494
14:00:22.679 -> 3ffefcc0:  feefeffe feefeffe 3ffeecb0 40100710
14:00:22.679 -> <<<stack<<<
14:00:22.726 ->
14:00:22.726 ->  ets Jan  8 2013,rst cause:2, boot mode:(1,6)
14:00:22.726 ->
14:00:30.902 ->
14:00:30.902 ->  ets Jan  8 2013,rst cause:4, boot mode:(1,6)
14:00:30.902 ->
14:00:30.902 -> wdt reset
I tried a solution like creating new user and name it ESP and changing host name but no success
any guidnance please maybe I missing Something
Best Regards  ,
sterretje
127.0.0.1 is the local host; that's not the address of the PC that the WAMP server is running on.
If you understand an example, use it.
If you don't understand an example, don't use it.
Electronics engineer by trade, software engineer by profession. Trying to get back into electronics after 15 years absence.
samerou
thank you for your reply  ,
I did change the address from 127.0.0.1 to 192.168.1.5(PC)  But same thing :(
