I wish I knew how to make changes or evaluate whether changes can be made to accommodate both but I'm clueless. Can someone give me some idea? Thanks.
BTW, are there any simpler LED drives that don't employ PWM but just has on/off instead? I just want something basic. I've done plenty 595 shift registers but they need too many resistors.
That could be an option, or the other way around I can design a TLC5940 shield with onboard atmega328 so the user can use all timers on the arduino and just use serial to change TLC5940. I've seen one TLC5940 shield but I don't think it has onboard MCU (it's using the same lib, Shirriff's).
Targettio,
Thanks. I will have that in mind for the IR remote + tones project I'm doing too I think the TLC 5940 uses both timers on my atmega328 so changing the IR remote library settings is not useful in this case.
Just tried to switch to TIMER1 for IRremote lib but same problem happened, 392hz, 440hz and their multiples won't play, just two weak "dah" instead. I tried the speaker and without IR lib it plays all frequencies. I changed remote key assignment for tones and still these frequencies don't play. I wish I could check if TIMER1 is really used. I changed all defs to use TIMER1, programmer's superstition. Here is the code:
#include <IRremote.h>
#define buzzer 16
int RECV_PIN = 17;
int tones[]={262,294,330,350,392,440,494,523,588,659,698,784,880,988,131,147,165,175,196,220,247};
IRrecv irrecv(RECV_PIN);
decode_results results;
irrecv.enableIRIn(); // Start the receiver
if (irrecv.decode(&results)) {
byte ret=find_key(results.value);
Serial.println(ret);
if ((ret<='9')&&(ret>='1'))
tone(buzzer, tones[ret-'1']);
noTone(buzzer);
delay(1);
else irrecv.resume(); // Receive the next value
char codes[]="ML1470ST258-Iv369TPVUCcR";
char find_key(unsigned long code)
static byte last=0;
byte col, row, temp;
if (code==0xffffffff) return (last); // Repeat
temp=lowByte((code-0x40BF00FF)/0x7f8)<<3;
for (byte i=0;i<8;i++)
bitWrite(col,i,bitRead(temp,7-i));
row=col>>2;
col=col&B11;
return (last=codes[col*6+row]);
if you need timer2 for remote control, you can move TLC5940 timer2 usage to e.g. timer5
Timer5 is free in most other applications:
Changes in TLC5940.cpp:
#if TLC_TIMER5 == 0
/* Timer 2 - GSCLK */
TCCR2A = _BV(COM2B1) // set on BOTTOM, clear on OCR2A (non-inverting),
// output on OC2B
| _BV(WGM21) // Fast pwm with OCR2A top
| _BV(WGM20); // Fast pwm with OCR2A top
TCCR2B = _BV(WGM22); // Fast pwm with OCR2A top
OCR2B = 0; // duty factor (as short a pulse as possible)
OCR2A = TLC_GSCLK_PERIOD; // see tlc_config.h
TCCR2B |= _BV(CS20); // no prescale, (start pwm output) #else
/* Timer 5 - GSCLK */
TCCR5A = _BV(COM5B1) // set on BOTTOM, clear on OCR2A (non-inverting),
// output on OC2B
| _BV(WGM51) // Fast pwm with OCR2A top
| _BV(WGM50); // Fast pwm with OCR2A top
TCCR5B = _BV(WGM52) // Fast pwm with OCR2A top
| _BV(WGM53); // Fast pwm with OCR2A top /* This line is new to get Timer 5 in same Mode like Timer2 */
OCR5B = 0; // duty factor (as short a pulse as possible)
OCR5A = TLC_GSCLK_PERIOD; // see tlc_config.h
TCCR5B |= _BV(CS50); // no prescale, (start pwm output) #endif
