Topic: SENSOR PROGRAM SAVED IN SD (Read 254 times) previous topic - next topic
0Avendano
Thank you for reading my question, I am trying to make my 2 sensors the distances that they measure keep it in a micro sd. Below I leave my code and could you please tell me if this is the case?
#include "Adafruit_VL53L0X.h"
#include <SPI.h>    // incluye libreria interfaz SPI
#include <SD.h>     // incluye libreria para tarjetas SD
// address we will assign if dual sensor is present
#define LOX1_ADDRESS 0x30
#define LOX2_ADDRESS 0x29
// set the pins to shutdown
#define SHT_LOX1 13
#define SHT_LOX2 12
// objects for the vl53l0x
Adafruit_VL53L0X lox1 = Adafruit_VL53L0X();
Adafruit_VL53L0X lox2 = Adafruit_VL53L0X();
//Sensors
#define SENSOR 11    // constante SENSOR en pin digital 4 (senal de DHT11)
int HORIZONTAL;    // variable para almacenar valor de temperatura
int horizontal;
int Flecha;
#define SSpin 10    // Slave Select en pin digital 10
File archivo;     // objeto archivo del tipo File
Adafruit_VL53L0X  dht(SENSOR,Adafruit_VL53L0X);
// this holds the measurement
VL53L0X_RangingMeasurementData_t measure1;
VL53L0X_RangingMeasurementData_t measure2;
    Reset all sensors by setting all of their XSHUT pins low for delay(10), then set all XSHUT high to bring out of reset
    Keep sensor #1 awake by keeping XSHUT pin high
    Put all other sensors into shutdown by pulling XSHUT pins low
    Initialize sensor #1 with lox.begin(new_i2c_address) Pick any number but 0x29 and it must be under 0x7F. Going with 0x30 to 0x3F is probably OK.
    Keep sensor #1 awake, and now bring sensor #2 out of reset by setting its XSHUT pin high.
    Initialize sensor #2 with lox.begin(new_i2c_address) Pick any number but 0x29 and whatever you set the first sensor to
void setID() {
  // all reset
  digitalWrite(SHT_LOX1, LOW);
  digitalWrite(SHT_LOX2, LOW);
  delay(10);
  // all unreset
  digitalWrite(SHT_LOX1, HIGH);
  digitalWrite(SHT_LOX2, HIGH);
  delay(10);
  // activating LOX1 and reseting LOX2
  // initing LOX1
  if(!lox1.begin(LOX1_ADDRESS)) {
    Serial.println(F("Failed to boot first VL53L0X"));
    while(1);
  delay(10);
  // activating LOX2
  delay(10);
  //initing LOX2
  if(!lox2.begin(LOX2_ADDRESS)) {
    Serial.println(F("Failed to boot second VL53L0X"));
    while(1);
void read_dual_sensors() {
  lox1.rangingTest(&measure1, false); // pass in 'true' to get debug data printout!
  lox2.rangingTest(&measure2, false); // pass in 'true' to get debug data printout!
  // print sensor one reading
  Serial.print("1: ");
  if(measure1.RangeStatus != 4) {     // if not out of range
    Serial.print(measure1.RangeMilliMeter);
    Serial.print("Out of range");
  Serial.print(" ");
  // print sensor two reading
  Serial.print("2: ");
  if(measure2.RangeStatus != 4) {
    Serial.print(measure2.RangeMilliMeter);
  Serial.println("Inicializando tarjeta ...");  // texto en ventana de monitor
  if (!SD.begin(SSpin)) {     // inicializacion de tarjeta SD
    Serial.println("fallo en inicializacion !");// si falla se muestra texto correspondiente y
    return;         // se sale del setup() para finalizar el programa
  Serial.println("inicializacion correcta");  // texto de inicializacion correcta
  archivo = SD.open("datos.txt", FILE_WRITE); // apertura para lectura/escritura de archivo datos.txt
  if (archivo) {
    for (int i=1; i < 31; i++){     // bucle repite 30 veces
      Flecha = measure1.RangeMilliMeter;  // almacena en variable valor leido de temperatura
      archivo.print(i);       // escribe en tarjeta el valor del indice
      archivo.print(",");     // escribe en tarjeta una coma
      archivo.print(Flecha);   // escribe en tarjeta el valor de temperatura
      Serial.print(i);        // escribe en monitor el valor del indice
      Serial.print(",");      // escribe en monitor una coma
      Serial.print(Flecha);    // escribe en monitor el valor de temperatura
      delay(1000);        // demora de 1 segundo
    archivo.close();        // cierre de archivo
    Serial.println("escritura correcta"); // texto de escritura correcta en monitor serie
    Serial.println("error en apertura de datos.txt"); // texto de falla en apertura de archivo
  // wait until serial port opens for native USB devices
  while (! Serial) { delay(1); }
  pinMode(SHT_LOX1, OUTPUT);
  pinMode(SHT_LOX2, OUTPUT);
  Serial.println("Shutdown pins inited...");
  Serial.println("Both in reset mode...(pins are low)");
  Serial.println("Starting...");
  setID();
  read_dual_sensors();
  delay(100);
srnet
Quote
Presumably you have tested the code yourself ?
If so what happened ?
http://www.50dollarsat.info/
http://www.loratracker.uk/
