Topic: Understanding Fc-51 ir sensor power consumption (Read 1 time) previous topic - next topic
tracksuit_arduino
According to data I was able to find, the Fc-51 ir sensor consumes 43mA. What does this mean, in terms of power used over time? I'm trying to understand how to determine how much the sensor drains a battery over time.
groundFungus
#1
May 07, 2019, 05:04 pm Last Edit: May 07, 2019, 05:05 pm by groundFungus
This page has a schematic of the sensor module.  Note the 100 Ohm resistor in series with the IR LED.  At 5 volts the LED will draw approximately 32 mA.  The other LEDs on the board probably account for most of the other 11 mA.
tracksuit_arduino
Does the draw of 43mA mean per hour? It's the unit of time I don't understand. E.g. if my battery has 2400mAh capacity do I simply divide that over 43 to get a rough estimate of battery life? Using consumption rate of 0.7 I get about 40 hours. Is that more our less sounding right?
groundFungus
#3
May 07, 2019, 05:26 pm Last Edit: May 07, 2019, 05:29 pm by groundFungus
43mA means 43mA, there is no time.  If a circuit draws 43mA for an hour then it is 43mAh.  To get a rough estimate just divide the battery capacity by the current draw.  So 2400mAh / 43mA = 55.8 and change hours.  To get closer, consult the discharge curves on the battery data sheet.  Battery capacity is specified at a certain current draw.  Drawing more current than the spec will result in decreased capacity and less current draw than the spec will yield more capacity.
Quote
Where does 0.7 come from?
tracksuit_arduino
Thanks. 0.7 was just something I read that gives a rough discount of true battery life. This seems to confirm what I'm seeing, having this sensor on kills my battery in about 2.5 days or so.
groundFungus
OK I see.  And I agree that the manufacturers stated battery capacity can't be wholly trusted (note the underline under rough).  Their numbers are based on testing under specified laboratory conditions that probably are not duplicated in real use.
wvmarle
2 1/2 days is 60 hours. So that'd give a correction factor of 1.1 rather than 0.7.
It's also pretty close to 2400/43, much closer than it is to 2400/42*0.7.
Quality of answers is related to the quality of questions. Good questions will get good answers. Useless answers are a sign of a poor question.
