Topic: IoTCloud stability & connection (Read 357 times) previous topic - next topic
Briandg
Hello,
I have often some problems with the connection between the device and the Cloud.
For exemple when I wait a moment (15-30min) before trying again then the device seems to not send data anymore and doesn't want to accept a new module. This result in needing to create a new device and linking it to the thing (the device is a MKR Wifi 1010 connected by USB). But even then sometimes the editor tells me that everything is okay and that the connection to the Arduino Cloud is done without the device sending any information!
I tried to create a new thing and same problem: sometimes it works, sometimes not.
One of my colleague can't even link to the cloud once and some of the overlay seems missing. We both are on the web version and on the same network (stable) so we can't figure out why there is those issues.
What can we try? Working like that is not possible!
ubidefeo
#1
May 08, 2019, 02:37 pm Last Edit: May 08, 2019, 02:38 pm by ubidefeo
hi @Briandg
can you post a link to your sketch?
also, at the end of setup() could you make a call to ArduinoCloud.printDebugInfo() (if you don't already have it) and paste the results here?
thank you
Ubi
Briandg
#2
May 08, 2019, 02:50 pm Last Edit: May 08, 2019, 02:56 pm by Briandg
Sketch:
https://create.arduino.cc/editor/Briandg/5e2eff1e-245e-48b5-81d9-e2193b84293c/preview
Debug:
[ 11252 ] Connection to "ROS-DEV-WIFI-1" failed
[ 11252 ] Retrying in  "500" milliseconds
[ 17326 ] Connected to "ROS-DEV-WIFI-1"
[ 17326 ] Connecting to Arduino IoT Cloud...
[ 20656 ] Connected to Arduino IoT Cloud
It works but the problem is that sometimes even when the editor shows the exact same informations (or sometimes get more time to connect) it doesn't work anymore.
I always wait for the debug to say that the connection to the IoT Cloud succeed.
