Topic: Servo with HC-12 Module is twitching (Read 918 times) previous topic - next topic
FBW921
The arduino NANO (my transmitter in this case) has two ports, pins 0 (RX) and 1 (TX)
My receiving device- the arduino mega has 8 -
Mega
0(RX), 1(TX)
19(RX), 18(TX)
17(RX), 16(TX)
15(RX), 14(TX)
Since both devices will be disconnected from any CPU (unless new code is being uploaded), I think I should be good on the number of hardware serial ports. The question is how to go about the coding?
PaulS
Quote
A serial port consists of an input pin and an output pin, so you have ONE port on the Nano and FOUR on the Mega.
Quote
To do what?
Quote
Then, just use Serial on each to talk to the HC-12.
FBW921
How do I use Serial (hardware serial) to communicate between the two hc-12s? I know how to use software serial to do it but not hardware serial. Here's some more direct questions since you like specific questions: Which functions can I directly swap out between software serial and hardware serial? Here's my controller code:
#include <SoftwareSerial.h>
int ROT ;
SoftwareSerial HC12(10, 11);
  HC12.begin(9600);
int ROT = analogRead(A3);
//Serial.println(ROT);
//ROT = map(ROT , 515 , 1023 , 1100  , 1800) ;
ROT = map(ROT , 0 , 876 , 760  , 1800) ;
HC12.println(ROT);
delay(50);
What do I #include for harware serial?
Does "SoftwareSerial HC12(10, 11);" stay?
Do I use Serial.read() anywhere?
PaulS
Quote
The public methods of the HardwareSerial class and the SoftwareSerial class are the same. So, any method of the SoftwareSerial class that you use can be used with the HardwareSerial instance (Serial) instead.
Quote
Nothing.
Quote
No.
Quote
If you want to read from the HC-xx, after you connect it to the hardware serial pins, yes. And, if you want to talk to the HC-xx, you use Serial.print() and/or Serial.println() and/or Serial.write().
FBW921
I will try to use hardware serial given this new information, thank you for your answers.
