Topic: delay and mills on NANO + LCD  (Read 60 times) previous topic - next topic
laoadam
I'd like the LCD show aaa=bbb, and show xxx=yyy for a while when the button pressed.
The code below works well,  need help how to use mills replace the delay. Thanks.
Code: [Select]
LiquidCrystal_I2C lcd(0x27, 2, 1, 0, 4, 5, 6, 7, 3, POSITIVE);
// constants won't change. They're used here to set pin numbers:
const int buttonPin = 2;     // the number of the pushbutton pin
const int ledPin =  13;      // the number of the LED pin
// variables will change:
int buttonState = 0;         // variable for reading the pushbutton status
unsigned long interval5 = 5000;  // the time we need to wait
unsigned long previousMillis5 = 0; // millis() returns an unsigned long.
unsigned long interval = 10000; // the time we need to wait
unsigned long previousMillis = 0; // millis() returns an unsigned long.
unsigned long currentMillis = millis(); // grab current time
  Serial.begin(9600);  // Used to type in characters
  lcd.begin(16, 2);  // initialize the lcd for 16 chars 2 lines, turn on backlight
  //-------- Write characters on the display ------------------
  // NOTE: Cursor Position: (CHAR, LINE) start at 0
  lcd.setCursor(0, 0); //Start at character 4 on line 0
  lcd.print("Hello, world!");
  delay(20);
  lcd.setCursor(0, 1);
  lcd.print("testing");
  //delay(5000);
  // Set the PWM pins as output.
  // initialize the LED pin as an output:
  pinMode(ledPin, OUTPUT);
  // initialize the pushbutton pin as an input:
  pinMode(buttonPin, INPUT);
  button();
  test();
void button() {
  // read the state of the pushbutton value:
  buttonState = digitalRead(buttonPin);
  // check if the pushbutton is pressed. If it is, the buttonState is HIGH:
 // if (buttonState == HIGH) {
  if(currentMillis - previousMillis > interval) {
    // save the last time you blinked the LED
    lcd.clear();
    lcd.print("xxx=");
    lcd.print("yyy");
    //delay(2000);
  else {
    // turn LED off:
    digitalWrite(ledPin, LOW);
void test() {
  lcd.clear();
  lcd.print("aaa=");
  lcd.print("bbb");
