Topic: 3.5 '' capacitive touch screen. (Read 1 time) previous topic - next topic
JLuc
Hello,
I recently purchased a capacitive touch screen with an internal flash memory, and Arduino compatible:
https://www.aliexpress.com/item/New-3-5-inch-HMI-I2C-IIC-LCD-Display-Module-Capacitive-Touch-Screen-480x320-for-Arduino/32904353978.html?spm=2114.11010108.01008.1.5199649b0RXOqT
I got from the seller a dedicated library for UNO and ATmega2560 and I adapted to an ESP8266.
But my problem is that the software "Visual LCD Studio" (also provided by the seller) that only allows to send the 2 demos (provided) to the screen or download to the PC, but impossible to create a new project.
I contacted the manufacturer and I just received an answer.
He says that the software provided does not allow to create a new project.
So I said I did not buy a screen just to run a demo.
This screen has 2 ports: I2C for Arduino and a serial port for "Visual LCD Studio" which must compile images and commands (usable then from I2C Arduino) I have no explanation about the serial protocol, and how to compile my own project.
If you have this screen and you can use it, please share.
Thanks.
@+ JLuc
JLuc
@+ JLuc
Pacowind9
Hello, Can you please share that software "Visual LCD Studio".
Thanks
JLuc
Hello,
This post dates a bit and since I managed to use this screen by doing with design bugs, thanks, but I dont need help anymore.
@+ JLuc
montyx
Hello,
I'd like to buy the same screen. Can you share your experience about, how were you able to manage it to use?
Have you found any arduino library for the screen?
Thanks in advance
JLuc
Hello,
For this screen, I used a library that was provided to me by the seller. I modified for this to work with an ESP8266. Otherwise, use is for UNO or AtMega2560 only. For me everything is fine, I managed to use it at my convenience. The principle is that you have to create screens with a dedicated application, then compile and send in the screen memory. A port of the screen is made for that. Then I use it in wire (SCL, SDA) Interceptions are managed by a subroutine.
If you need other explanations, maybe I can help you.
Do not count too much on the manufacturer, he never responds to messages.
@+ JLuc
sunlighting
Hello,
I've ordered the 5" lcd but cannot find the visual lcd studio software. No reaction from the manuf actor.
Can you tel me where to find the software to get it going?
Thanks in advance
JLuc
Hello,
5 "! I do not know this model ... I am curious and I would like to have the link to see, thank you.
For the software, it is "Visual Studio LCD" that the seller provided to me (Aliexpress) but I had obtained a more recent version by the manufacturer's site. But it was at the beginning of the existence of this screen (about 1 year) and since the manufacturer no longer puts a download link and does not respond to messages.
6u
@+ JLuc
sunlighting
Hello,
The link
Can i get that software somewhere or is it completely gone?
sunlighting
JLuc
Hello,
Ask the vendor for software and sample programs. Otherwise you tell me if he doesn't give them and I give you what I have. But it is desirable to obtain those of the seller who will certainly be newer.
Happy holidays.
@+ JLuc
ve2dx
Has anyone found the software and the needed library? Also some examples would really help?
